After a power failure I rebooted but can not get beyond the BIOS readout. I am instructed to press F2 for set up but none of the keys appear to work. Pressing F8, F10 Ctrl Alt Esc have no effect. I am unable to boot from a recovery CD or floppy although both drives are recognised by the BIOS. Removing the battery and runing from mains supply results in the same problem. Has anyone got a solution to this problem. Does anyone know the location of the CMOS battery for this model as I have been told that removing the battery may clear the BIOS settings but as a novice I have no idea what effect that will have on the machine.
During bootup, press and hold the DEL key for a few seconds. your system setup should appear. In the system setup,find the first boot device and use the pageup key until CDrom appears. then quit and chose Y to save changes. Now put the restordisk in the CD drive and reboot. I don't think Cleaing the CMOS will help you with this problem.
Download the latest BIOS update from your computer manufacturer's website onto a USB flash drive. Refer to your user manual to obtain the manufacturer's website address.
If the downloaded BIOS file is a zip archive, unzip the contents onto your USB flash drive.
Jumper settings may need to be reconfigured on some motherboards to enter BIOS recovery mode. Most Intel-based motherboards have a jumper setting or switch near the on-board
CMOS battery.
The procedure for setting the jumpers will vary depending on your motherboard make and model, so refer to the motherboard documentation for specific instructions.
Power on the computer and press "F2" to access the Setup Mode menu.
If you are unable to access the setup menu, you will not be able to proceed with this repair. Take your computer to a repair shop, as the motherboard may need to be replaced.
Use the arrow key to select "Boot Priority" or a similarly named field. Press the "Enter" key.
Scroll down until "First boot priority" or "First boot drive" is selected and press "Enter."
Select the USB flash drive as the first boot priority device. Press the "F10" key to save this setting and exit from the setup menu.
Connect the USB flash drive to an open USB port on your computer.
Then let your computer fully reboot.
The USB flash drive should be detected and the BIOS should update automatically.
When the update is complete, you may be prompted to restart your computer, or it may reboot automatically.
If you are able to use your computer without any further problems of overheating or failure to recognize drives, your failed BIOS update has been resolved.
hope this helps
CMOS battery.
hope this helps
