Question about Mitsubishi VS-50501 50" Rear Projection Television
Mitsibishi ws-a65 will not turn on.
When you push the power button, the power button comes on and stays on (solid) green. When the set is powering up, only the green crt assembly turns on. this only last for a few seconds and the green goes off. I checked all the fuses and all the fuses check good. The last time the set was playing with video, sound and the screen was green. The next time I turn the TV on the screen turned green and then the green goes out. When I push the power button, there is no video and no sound, when the tv start the screen turns green and goes out in a few seconds. The power button stays on solid green. Thanks in advance for any assistance.
  • mreel Nov 22, 2008
    The main board has 4 IC on it. IC Audio out, IC video out and 2 CONV IC on the same heat sink. Which IC is the problem? Can you replace the IC individualy or do you have to replace the board?
    Brigadier General:
  • 3,614 Answers
You can doboth.. replace the faulty parts, or replace the whole board.
check and test the convergence IC.
Posted on Nov 22, 2008
    Sergeant:
  • 276 Answers
It sounds the problem withe ic on the main board.
When I push the on button the green light comes on for second or two then goes out.(will not stay turned on long enough to even get a picture on the screen.Mitsibishi Model # WS-55315
This set has a self check feature--if set has been unplugged it clears the error buffer--plug in and try to turn on set.
When green light comes on and then goes off ON THE FRONT OF THE SET press and hold BOTH the menu and input(device) buttons at same time for at least 5 seconds and release both buttons.
Power light will blink a 2 digit error code like 2 blinks, 2 blinks, a pause and repeat the code for a total of five times.
Let me know what error code you find and I will explain it.
May 27, 2012 | Mitsubishi Televison & Video
I just got a Mitsubishi WS-A65 that has a issue, when I turn it on I dont get a picture, I do get some faint glow and some faint curved lines, I get error cod 1-2 which says no error and I have...
Hi, if you have audio and any kind of a blank/darkened screen then you either have a bad video hookup cable, defective video input, or a bad backlight system-bulb or power supply to bulb is probably weak from symptom you described. Hope this was of some help-if you can find a You tube of someone adjusting brightness you may be able to blindly hit right buttons to turn down brightness then turn set off then turn back on with a picture again-it's actually not impossible to do, I know because have actually done it once. Good luck, prodzilla
Mar 31, 2011 | Televison & Video
When i go to turn the tv on the green light go on and then off. i did the coe test error code repeated 10 times
I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again
Jan 02, 2011 | Mitsubishi WS-55807 TV
Power will not stay on
u have a problem with the convergen ic , and 2 pico fuse on power supply , this repair normally cost about $300
Apr 13, 2010 | Mitsubishi WS-55511 55" Rear Projection...
S9000 canon printer ink tank full
Hi
Try this see if work for you.
may work
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Nov 02, 2008 | Canon i950 InkJet Photo Printer
Have a ws-42413 mitsubishi TV
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Mar 08, 2017 | Televison & Video
Mitshubishi WS-73907 won't stay on
I suspect you may have a short in the horizontal deflection circuits or High Voltage transformer. If the set had a "great" picture, it may be worth fixing providing you aren't planning to upgrade to a HDTV anytime soon, otherwise I would use this excuse to start looking for a new set. Worst case I can envision with this set would be one of the picture tubes having a Short, keeping the set from turning on. That would make it unreparable.
Aug 03, 2008 | Mitsubishi WS-73907 TV
This behavior could be an indicator of power supply problems or abnormal current drain from elsewhere in the set.
Modern supplies are, by design, able to shut down if voltage or currents aren't within the design limits of the circuits they are servicing.
Without some hands-on it is not possible to isolate the problem unless one of the forums deals with a series fault.
If the set had a reset button, it would be located on the outside of it where the user could reset it.
The reset buttons one finds on some sets is nothing other than a very cheap kind of thermal circuit breaker that trips when current is above its limit.
These are kind of prone to failure themselves.
Jul 13, 2008 | Mitsubishi WS-65905 65" Rear Projection...
Mitsubishi WS73713 - Now working - Timer light flashing.
My Mitsubishi WS-73713 had the same blinking green timer light problem and would not turn on. I tried the reset button and unplugging power to no avail. I found that by simultaneously holding down the remote control "power" button and "volume" button for about 30 seconds the blinking light would go out and a solid green light would come on. Even though the solid green light came on the unit would still not power up. After doing this several times however the unit did finally power up in a normal mode and appears to be working again. It's worth trying before calling in for an expensive repair. PS - From here on out I'm sticking with SONY or Toshiba sets which have given be great service.
Nov 09, 2007 | Televison & Video
Compaq Presario 4400us
Either the new power supply you purchased is not functioning correctly. But, assuming it is now that you are getting some form of power to your PC, it is very likely the motherboard. Whatever fried your old power supply (or it could have just been the power supply itself) most likely fried your motherboard in the process. Probably not the CPU since the MB can't even post.
Jun 21, 2007 | Compaq (388746-001)...
Televison & Video Logo
111 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
