Question about Planar PL2010M 20" Flat Panel LCD Monitor
Planar 2010M auto adjust
My Planar 2010M just started staying in a locked auto adjust mode, constantly adjusting the screen and will not stop, can not open the screen menu, will not turn off, any ideas?
Thank you, James
    Problem Solver:
  • 13 Answers
This may be related to a power supply problem that these monitor have. I think you need to fix the power supply board inside the display itself. It's giving the logic board and backlights fluctuating power and they have weird / intermittant problems.
There is a supplier of power boards online, you can google them with numbers from the board but I don't suggest using them. Look for information on the company before you buy from them. I've seen a lot of complaints for this "international" company.
First check that you are getting a strong 12V from the external power adapter. If so, the problems may be as simple as changing out a few capacitors. (about $8 in new capacitors, plus shipping)
On the PL2010M monitors you need the following parts. I've added digikey part numbers to make life easier:
P10271-ND 220UF 25V Capacitor (3 or 4 depending on PS)
P10275-ND 470UF 25V Capacitor (1)
P10221-ND 470UF 10V Capacitor (4)
If you're not comfortable with soldering and de-soldering electronics, take it to a local technician for the work and give them the parts list above. That should work to fix your issues. I've fixed several of these monitors so far. All the problems were related to the power supplies having bad capacitors. Same with the Planar PL1700 LCD monitors.
There is also a single capacitor on the display logic board, but I haven't seen this one go bad yet.
-Chip
Posted on Dec 06, 2008
Error (co3ff) please answer
SOLUTION: To set Adjustment mode 11 to proper value, perform the following:
1. Enter Tech Rep mode (Counter, Stop, 0, 0, Stop, 0, 1).
2. Press Stop and then Start. AJ- will display.
3. Enter 11 from the keypad.
4. Press Start. Current value will display.
5. Press Clear.
6. Enter a value of 1 from the keypad.
7. Press Start to save the setting.
8. Press Auto Reset to exit Adjustment Mode.
Jan 04, 2015 | Office Equipment & Supplies
Tip
ERVICE MODE AND POWER SUPPLY CIRCUIT
SERVICE MODE AND POWER SUPPLY CIRCUIT
Purpose: To bring the color adjustment of each component into standard alignment.
Symptom of Misadjustment: If this adjustment is incorrect, component signals do not reproduce the corresponding color.
1. Input 1080i 100% Color Bar signal.
2. Enter the service mode.
3. To enter the Auto Calibration adjustment mode, press [6] button on service the remote control unit.
4. To start auto adjustment, press [1] button on the service remote control unit.
- In the auto adjustment mode, "Please wait" appears on the screen.
- Upon completion, "OK" appears on the screen.
TO KNOW MORE CHECK THE LINK BELLOW
http://electro-medical.blogspot.in/
google.com/+AjinGopakumar
on Feb 18, 2015 | Emerson Used Original LC195EM82 Remote...
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
1990 automatic 85,000 miles- Shifter will not stay in park and will start jumping ahead if parked on an incline. Also, when starting the car, the key stays in start position- starting the engine and...
Check the shift cable for proper adjustment. Remove the console, put shift selector in N (make sure wheels are blocked), remove lock pin from cable adjuster, check that the hole in the adjuster is perfectly in line with the hole in the shift cable. (there are 2 holes in the end of the shift cable positioned 90degrees apart to allow for 1/4 turn adjustments) If not perfectly aligned, loosen the lock nut on the shift cable and adjust as necessary. Tighten the lock nut and install the lock pin in the adjuster. If the lock pin feels like it's binding when being installed, it's still out of adjustment and must be adjusted again.
The key staying in the start position: try spraying wd-40 or similar lubricant into key hole, if condition is the same, you will need to change the key ignition assembly, as it is worn out,
Aug 04, 2009 | 1990 Honda Accord
Problem in Auto adjust mode
Auto Adjust work on the basis of resolution to which Windows set. It occurs mostly if Video drivers are not installed. Please check and install video drivers and also try to change screen resolutions from display properties in control panel.....
Nov 06, 2008 | Dell E176FP 17" LCD Monitor
Code erreur
CAUSE: Adjustment mode 11 is not set to correct value.
5. Press Clear.
HOPE THAT HELP
Oct 20, 2008 | Konica Minolta DiALTA Di183F Copier
Auto adjust
i have had the same prob with a pl1700 would like an answer also
Jul 21, 2008 | Planar PL1700 17" Flat Panel LCD Monitor
Oh, it's the colors you are having a problem with. Then you probably want to perform an Auto Gradation Adjustment. It's on pages 162-163 of the manual found here: http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Here is what it says:
Auto Gradation Adjustment is a color calibration for the copier and printer. An Auto Gradation Adjustment compensates for differences between the actual and the expected toner densities for each color. An Auto Gradation Adjustment should be performed whenever there is a noticeable change in the appearance (quality) of the output, particularly changes in color
tones or densities. Performing an Auto Gradation Adjustment on a regular basis will help to maintain consistent color quality over time.
NOTE: Since an Auto Gradation Adjustment can affect all jobs for all users, it is recommended that this procedure be performed only by the Machine Administrator.
Copy Job - Text Compensates tones when a text original is copied.
Copy Job - Photo Compensates tones when a photo original is copied.
Print Job Compensates tones when printing with controller line screen.
Network Controller - 1 Compensates tones when printing with Network Controller screen type 1.
Network Controller - 2 Compensates tones when printing with Network Controller screen type 2.
NOTE: Printing the chart for Auto Gradation does not increase the meter count.
NOTE: When gradation adjustment is executed, the following
changes will be made to default copy settings set in System Settings mode: Copy density = Normal or Auto, Color Shift = Normal, Saturation = Normal, Color Balance = 0, Sharpness = 0.
NOTE: When Print or Network Controller gradation adjustment is executed, the printer’s output profiles for the available screen types are compensated.
1 On the Image Quality Adjustment screen, select Auto Gradation Adjustment.
2 Load 8.5x11 inch or A4 paper into Tray 5 (Bypass). Move the paper guide to gently touch the edge of the paper.
3 Select the desired gradation adjustment screen:
• Copy Job - Text
• Copy Job - Photo
• Print Job
• Network Controller - 1
• Network Controller - 2
Press Start. The Adjustment Chart is output.
4 Place the Adjustment Chart face down on the Document Glass with both Magenta color patches against the left side of the glass.
5 Place 5 sheets of white paper on top of the Adjustment Chart and close the DADF. Select Start.
6 To continue Auto Gradation Adjustment with other screens, repeat steps 2 to 5. When you are finished, select Close until the System Settings screen is displayed.
7 Select Exit to exit the System Settings mode.
Jun 24, 2008 | Xerox DocuColor 3535 Copier
Planar PL2010M 20" Flat Panel LCD Monitor Logo
715 people viewed this question
Top Planar Computers & Internet Experts
William Miller
William Miller
Joe Goldman
Joe Goldman
Jay Plesset
Are you a Planar Computer and Internet Expert? Answer questions, earn points and help others
