Question about Honeywell Heating & Cooling
Honeywell manual thermostat t87F, how to take off dial
    Problem Solver:
  • 25 Answers
Ring around clear number section pulls off then there are three small flat head screws undo those aand the outer face with the dial comes off. if you are just trying to clean out the clear dial from bugs or small debris simply lift with small screwdriver and blow into it.
Posted on Nov 22, 2008
T6360 dial not working
Turn system off then back on and see if it is working. The manual can be obtained at:
http://historical-products.ecc.emea.honeywell.com/2008_1/pdf/en0r8281uk07r1204.pdf
There is not enough information to give you any more help. What does "Dial not working indicate", the Honeywell T6360b1028 is a heating and cooling thermostat with the potential of having a heat anticipator.
Mar 16, 2014 | Honeywell T6360b1028 Room Thermostat
Honeywell t6360
I am trying to replace a Honeywell thermostat model #T87F with a model RTH 111, which Honeywell advises is compatible. After following all instructions, I have cooling, but no heat. This is a one zone...
Hi, Have you jumpered Rc and Rh??? I bet you just have the red wire under the Rc terminal only...heat goes on when power goes from Rh to W... the white wire should be on W and energized (24v) when the t-stat is calling for heat...
Here is a list of each common terminal and what their commonly used for. Alsolisted is what colors are commonly used. NEVER ASSUME these are what youhave. Verify all your wires by following each to each piece of equipment. Thiswill help you to be able to match your equipment with the terminal.
Here is the rest of the tip that I wrote...
Thermostat Wiring and Terminal Designations
heatman101
Aug 23, 2011 | Honeywell Heating & Cooling
I want to replace programmable thermostat with old dial style
The terminals should be the same on both thermostats, except for C- common.
R- usually RED, goes to hot side of transformer,
W- usually WHITE, goes to heat
Y- usually YELLOW goes to outdoor unit
G- usually GREEN goes to furnace blower
Any of the other wires just cap them off you don't need them. If you have an Rh and Rc terminal instead of R and don't have them on the programmable then put a jumper from Rh ro Rc.
If you need more, then let me know what terminals you have on both t'stats and brand of furnace and AC, if you have a heatpump then there's more wires let me know.
Oct 13, 2009 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell round thermostat Model #T87F continuously running
you either have 2 thermostat wires bare and touching or a zone valve stuck open
Feb 28, 2009 | Honeywell Programmable Thermostat Heater
Honeywell T87f 3855 Doesn't Activate Heater
thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Jan 25, 2009 | Heating & Cooling
How do i uninstall my old honeywell mercury thermostat
There are three parts to a T87F thermostat. Outer ring, thermostat body, and base mount. Remove the snap on ring that goes around the dial. Remove three screws from the thermostat that mount it to its base. Remove the thermostat. Disconnect and record what screws each wire attaches to. Remove the screws holding the base to the wall.
Jul 12, 2008 | Honeywell Heating & Cooling
AC fan not blowing/ Honeywell T87F thermastat
ok heres a test i want you to do carefully remove the thermostat cover and you will see the 3 wires one is red the other one is yellow and a green one turn off the thermostat and remove the wire from thermostat labeled G and carefully touch it on the R terminal if fan turns on, thermostat is defective if it dosen't turn on there should be a fan section on control board that's defective
Jun 26, 2008 | Weather King 10AJA2501AH Air Conditioner
My Honeywell T87F Thermostat doesn't shut the A/C off when the temp in the room gets down to the Thermostat setting. I have it set on COOL and AUTO. I have to shut the A/C off; then later turn it back on...
Remove the thermostat and disconnect the r and y connection. If the A/C continues to run ya got a short in the wiring somewhere. If it shuts down then your tstat is hooped.
Jun 09, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
1,159 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
