Need code for remote control purchased separately from TV
Phillips TV, 27'', Model PRF227, w/o remote. Purchased RCA remote (universal) need to program to run TV.
    Genius:
  • 3,422 Answers
Please give me the model no. of your universal remote and i'll give you the codes for your TV.
I will be waiting for your reply.
Posted on Nov 22, 2008
  • Priya darshan Nov 22, 2008
    Please try this method first:
    1 Hold down the television and power button till it turns red
    2.
    Then press play once the light will blink once it stops if the t.v. has
    not turned on press again, continue until the t.v. turns on.
    3. Press reverse until t.v. turns off
    4. Hold down stop till light goes off
    This should fix your problem.If not try this:
    There are 4 ways to program your remote:
    -Brand Code search and entry
    -Direct code entry
    -Manual Code search and entry
    -Auto Code search and entry
    *ON
    TV/VCR(DVD) combos you must program each button individually and that
    button(ie. TV or VCR/DVD) will program that part of your device.
    *the DVD/VCR button programs DVD by default, in order to program it for VCR you must put it into VCR mode:
    1.hold down the DVD-VCR button-->the red led will stay lit.
    2.while holding down the DVD-VCR button press the number 2 --> the red led will turn off
    3.Release the DVD-VCR button--> the red led blinks 4 times and turns off
    4.The DVD-VCR button is now set to VCR mode-->program for VCR
    BRAND CODE SEARCH ENTRY:
    1. turn on device
    2. locate brand codes(sorry, I don't have it, try finding genaric RCA codes)
    3. hold down the component button--> led should stay on
    4.
    while holding component button, also hold power button--> the led
    will turn off, then after 3 seconds it will turn back on.
    5. release both buttons--> led will stay on
    6. enter brand code--> led blinks once
    7.
    press power button repeatedly until component turns off-->each time
    you press the power key the remote sends a different code for that
    brand. led blinks once
    8. if power on your device turns off press the stop button to save configuration-> led turns off
    9.
    if the led blinks 4 times and turns off, you have reached the end of
    the codes for that brand, try using a different method to program your
    device.
    DIRECT CODE ENTRY:
    1. turn on the device
    2. locate your device codes
    3. hold component key down-->led lights up and stays lit
    4.
    enter code while holding components key--> as first key is pressed
    the led turn off, then as 4th digit of key is pressed the led turns
    back on
    5. release component key-->led turns off, try using your
    remote, if it doesn't have all of the functions you need, try a
    different code
    6. if the led blinks 4 times after entering code you have entered an invalid code, try again.
    MANUAL SEARCH AND ENTRY:
    1. turn on device
    2. hold the component button--> led lights up and stays lit
    3. while holding component button hold power button-> led turns off then turns back on after 3 seconds
    4. release both buttons--> led stays lit
    5.
    push the power button a bunch of times until the device shuts off->
    each time the power button is pressed a different code is sent to the
    device, the led blinks each time.
    6. if the device turns off press the stop button to save your config.
    7.
    if the led blinks 4 times you have reached the end of the code list,
    there are hundreds of codes, you may be pressing the power button for a
    while...
    AUTO CODE SEARCH AND ENTRY:
    1. repeat steps 1-4 of "manual search and entry"
    2. press the "play" button--> led blinks 10 times, sending a code each time
    3. continue pressing the play button until the device turns off
    4. if the device turns off press the reverse key to until it turns back on then press the stop key to save config.
    5. if the led blinks 4 times you have run out of codes, try a different method.
I bought a GEMINI III Quik 40 universal remote U.S.PatentNo.D357,017 i need codes to program an Olin Ross sound system Model:OR860 and a RCA 5 disc changer model#RP8065 HOW DO I PROGRAM REMOTE
If you purchased the remote new, it should have come with a code list. Because it is universal, you can use code search to find something that can handle basic functions of both devices although the search would have to be conducted separately for each. If a search through all codes contained in the remote fails, you may have to try a different universal remote. All universal remotes do not contain all possible codes.
Nov 02, 2016 | RCA Televison & Video
Unable to program universal remote with phillips TV.
Todd, there is a web site you can go to. replacement remotes.com Use the top site when it comes up. At the top type in your remote model number. You can purchase a manual or maybe call the # I found the item# you want is 61369 for 3.95 Sorry this is all i could find. good luck
Feb 12, 2009 | RCA Universal Remote Control
Universal code for 27" phillips TV for large remote control
called my daughter and she was able,to find code out for 27" Magnavox/Phillips...its 0054....worked the first time on the large I think "living Solutions" remote for the elderly....
Jan 26, 2009 | Directed 434MHZ Remote Control
Cannot program new phillips remote to rca tv
[http://voxrightnow.custhelp.com/cgi-bin/voxrightnow.cfg/php/enduser/std_adp.php?p_faqid=1769&p_created=1209688350&p_sid=6-sdxLAj&p_accessibility=0&p_redirect=&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9ODE4LDgxOCZwX3Byb2RzPTE1OCZwX2NhdHM9MCZwX3B2PTEuMTU4JnBfY3Y9JnBfc2VhcmNoX3R5cGU9YW5zd2Vycy5zZWFyY2hfbmwmcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1yY2Egc3lzdGVtIDUgcmVtb3RlIGNvbnRyb2w*&p_li=&p_topview=1] follow this web link it will take you to the RCA customer support web page for programming universal remote controls and lists codes under system components. The television codes for the universal remote are listed under TV. This web page should be able to help you solve your problems with the programming of the universal remote control and give you the codes needed to use it with the components in your system. Thank you for using FixYa and have a nice day!
Dec 02, 2008 | RCA DIRECTV Satellite Remote Control
Phillips magnavox tv/vcr combo need codes to program remote
most universal remote controls will not operate the combo type units. Contact www.remotes.com for a repoacement remote.
Nov 24, 2008 | RCA Universal Remote Control
Need tv code for phillips model # pl5120 c121 for rcr311w i cant adjust color
There are a few codes you can try for the Philips TVs:
1002, 1003, 1004, 1008, 1012, 1019, 1062, 1068, 1069, 1075, 1076, 1087, 1219, 1238
To look up these and codes for other TVs, go here:
http://remotefinder.rca.com/default.aspx?site=rca
The manual for the remote can be found here (as of 06/07/2009):
http://www.remotecentral.com/cgi-bin/files/dl.cgi?file=others/rca/rcr311-manual.zip&area=other
Jul 19, 2008 | Universal Remote Control DIRECTV Universal...
RCA XL100 Remote Code?
I found a remote on the web for that model and purchased it.
Apr 11, 2008 | RCA Universal Remote Control
Need updated codes for RCA RCR860 remote control
I have a Phillips TV and need the code for that. I have the manual but it only lists RCA, Sony, JVC, Panasonic, Toshiba, and Sharp.
Jan 22, 2008 | Motorola Mobility DRC800 Universal Remote...
Televison & Video Logo
22 people viewed this question
Top Televison & Video Experts
Electro Med Services...
