Indesit we125. F-05 comes on screen. What does this mean?
  • Anonymous Mar 05, 2009
    f-05 comes on screen
  • Washing Mach... Master
  • 3,463 Answers
Hi.
F05 mwans pressure switch jammed on full, check that pump is working o/k, if it is, and still showing fault, then you will have to call an engineer
Hope this helps.
Posted on Nov 22, 2008
Indesit idl40
Here is the manual
http://www.indesit.co.uk/indesit/_pdf/manuals/19504287203_UK.pdf
If you look at the trouble shooting page, flashing lights mean a clogged filter . If 2 flashes it needs to be turned off , and turned on again after five minutes. There is a call number -
Mar 20, 2014 | Dishwashers
I have an f-02 fault code on my indesit evolution 1200 we12 wasing machine.do you know what this means? Julie
In my lists Indesit's 'F02' stands for 'motor jammed/ tacho problem, check leads' meaning that it is requiring a service engineer's attention I suggest. Sorry ;-0(
If this has assisted and/or clarified the situation for you please consider a 4 thumbs up on our rating.
Thanks and good luck!
John C
Jul 21, 2011 | Indesit Washing Machines
H20 is showing on my display on my indesit
H20 means not filling with water properly.
Check hoses and that taps are fully turned on , make sure water pressure is o/k, no kinks in hoses
Mar 13, 2010 | Indesit Washing Machines
Indesit evolution 1200 showing (F 01) Does anybody know what this means????
F01 means short circuit motor triac.
Check all connections on motor, motor plug and leads, and the control module.
Hope this helps.
Thankyou.
Nov 27, 2009 | Indesit WA 125 Front Load Washer
Indesit wise 127 x F-10 error on the screen
F10 means no cold fill.
Check cold water supply, and check drain out let hose is not kinked.
Please rate my soilution.
Thanks.
May 20, 2009 | Select Brands Washing Machines
Error F10E comes on my indesit WIE1375 washing machine what does this mean?
first check that your drain pump is working,reset appliance and put on drain only,listen for the pump to pump of hum,if it hums there is a blockage,remove filter and check,this is discribed in you manual
Feb 27, 2009 | Indesit W 123 Front Load Washer
I need a wiring diagram for a indesit wn657wz washing machine.
Unfortunately you cannot down load these on line..
It means you would have to purchase a sevice manual from Indesit.This is the only source.
Try---; www.indesit.co.uk
Good luck.
Plz rate my solution.
Thanks
Dec 29, 2008 | Indesit W 123 Front Load Washer
Fault f05
F05 means pressure switch jammed on full, firstly check that pump is working and that there is no blockage anywhere,
if it still does not work, then you are going to have to call an engineer.
Hope this helps.
Please leave feedback.
Nov 24, 2008 | Indesit W 123 Front Load Washer
Indesit IDL 530 Dishwasher Prewash and Drying Light flashing
Ours was doing this and it was because there was water leaking into the base because a crocodile clip had come off
Oct 22, 2007 | Dishwashers
Washing Machines Logo
219 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
