Question about Amana Heating & Cooling
The electric heat kit for my amana air handler is not coming on. I am looking for simple checks that a I can perform to see if it is something simple. Primary Power is fine. I am looking for direction on what to check next.
  • 3 more comments
  • V2A2 Nov 22, 2008
    Model number is an EDK07A.
    Primary power is at 240V.
    All Connections are solid.
    Control board fuse is intact and verified.
  • V2A2 Nov 22, 2008
    The fan comes on, but the heater assembly does not
  • V2A2 Nov 22, 2008
    Transformer control voltage has been verified good (25V)
  • V2A2 Nov 22, 2008
    The blower motor spins fine. I have placed an AMP meter on the blower motor and it is running well within specifications. I have also tested the low voltage side with the AC, and it operates normally, controlling both the AC unit and the blower motor.
    The problem appears to be limited to the Electric Heater Kit.
    -The fusable links on both heater elements are intact
    The only components remaining are:
    -TL (Temperature Limit)
    -2x Relays (one for each heater element)
  • V2A2 Nov 22, 2008
    Thank you for the insite. Since the thermostat was operating for the cooling side, I never though about checking to ensure all the heating side wiring was properly installed. It was not.
    The house is a 4 year old home with a secondary air handler for the FROG. The original owners must have had the thermostat set so low, they never noticed the lack of heat, as we have mild winters in eastern TN. Wiring for the heater element relay was not attached, thus the fan would kick in, but the heater elements would not turn on.
    Thanks Again ......... You Rock!!!
    Brigadier General:
  • 6,966 Answers
As you posted, it would seem that the issue is limited now to just the:
  • temperature limit (TL), test is continuity, it is a thermally activated fuse;
  • heater relay which is activated by the control board. Some of the relay contacts could have burned and would require cleaning/scrapping.
Could you please confirm that the wires leading from the control board to the heater relay are orange and brown? If yes, a possible wiring diagram that maybe of reference.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 22, 2008
  • Amana Master
  • 19,396 Answers
All you need to check is the heating element (test for continuity), and the thermostat (check if thethermostat is switching on power to heating element)
The job should be done by a technician.
If there is power, but no heat at all, 9 on ten it is a faulty heating element.
    Genius:
  • 1,011 Answers
Dear Sir/Madam,
Check the motor. Since the fuse in the unit is good you can probably rule out the low voltage side.
The fact that the motor will only spin once isn't very good.
You need to have this tested by someone with the proper test equipment. Also check both the motors and the control board.
Thanks
good luck
    Sergeant:
  • 276 Answers
I hope the manuals can help u
Howto hook up th8320R1003 to heat pump
Byron, unless you have thoroughly familiarized yourself with the terminal designations on all three components, t-stat, air handler and heat pump you shouldn't attempt connection of the control. There are many variations of what will work and many more variations of what will NOT work.
No mention of outdoor sensors, so fine tuning of the electric heating stages to match the heat loss of your house (for most efficient operation) doesn't sound possible.
I know, this answer didn't help but there is no simple answer without having all the components in hand.
Mar 05, 2015 | Honeywell TH8320R1003 VisionPRO 8000 w/...
HKR-10C FURNACE BLOWER WONT KICK ON
if you have change the thermostat it has to have the option for electric heat the thermostat has o turn the fan on in heat mode on air handlers
Jan 07, 2013 | Goodman Manufacturing Goodman HKR-10C 10kW...
HE heat pump won't talk with old air handler?
The fact is, the air handler supplies the voltage, blower, and electric heat. In order for the heat pump to work correctly, the wiring from the thermostat and heat pump need to be hooked up right to the air handler. The thermostat is what tells which component to come on. If the fan stops, but the condenser keeps going, you either have a faulty fan relay on the air handler, faulty thermostat or wiring, faulty wiring at the heat pump, or the contacts on the new unit are sticking, which is highly doubtful considering it is working now. I hope I have helped you understand this a little more. Good luck and don't let them push you around, get someone that knows what they are looking at.
Jul 18, 2012 | Goodman Heating & Cooling
WIRING THE THERMOSTAT TO AC UNIT THEN FROM THE UNIT TO HANDLER
Generally, you would go from the thermostat to the air handler, and then, from the air handler to the outdoor unit. I don't know if you have a heat pump or not, so I will give you a simple diagram and you can contact me if you need more.
Thermostat : Y G R W and sometimes C
Air handler: Y G R W and C
Outdoor unit: two wires connecting to the contactor ( not heat pump)
Thermostat; Y--------------Y(air handler cooling)------------------one side of contactor, outdoor unit
G-------------G (air handler, fan)
R--------------R (air handler ,hot)
W-------------W (air handler, heat)
C--------------C (air handler, common)------------other side of contactor, outdoor unit
This is a typical wiring diagram. Just contact me if you have something different. Hope this helps. Stay cool. mark
Jul 10, 2011 | Heating & Cooling
AIR HANDLER FAN NOT COMING ON AFTER COMPRESSOR TURNS ON ?
Is this a split or packaged sysyem? In a heat pump condensing unit or package unit the indoor fan motor may be delayed due to a timer or program. Otherwise you may have a weak capacitor or a bad motor. The air handler is generally a 230 v unit due to the heat strip operation, have you checked line voltage from the main breaker
May 22, 2010 | Amana Heating & Cooling
Looking for manuel reset on heater amana ptac unit heat won't come on new control board
I dont know about this model but in general electric heat wont have a reset button the heat is controled by a sequencer and each elememt has a safty limit switch incase the sequencer sticks in the on mode here is a link to where you can get more info on this model http://www.fixya.com/support/p51773-amana_ptc153b35aj_air_conditioner
Oct 30, 2009 | Amana PTC153B35AJ Air Conditioner
1997 Amana 2 or 2.5 ton heat pump, 13 seer - air handler only blows 4-5 min
do you have a totaline t-stat. they and some other brands have a fan recirculation setting in the installers menu.
this is assuming that this happens in addition to the heating or cooling normally
Jul 02, 2008 | Amana PTH123B25AJ Heat Pump Air...
Air handler only blows air for 3-5 minutes before shut off & not cycling frequently
Sounds like it could be a very weak run capacitor on the blower motor. Run capacitors are sized specifically to the needs of the motor. When a run cap gets weak, the motor trys to compensate for it by drawing more power. More power draw = more heat in the motor, then the motor will overheat and shut off to protect itself. When the motor cools off it will automatically restart and run until it overheats again. Keep in mind that I am a technician that normally diagnoses equipment in a hands on manner. There are many practices and concepts that transcend all air conditioning systems but it is a constantly evolving industry. I live in south eastern WA and I don't see Amana units except as window units. It is possible to have something else causing this problem (faulty thermostat, failing thermal relay(if used), problem with electronic controls(if used)) there are a lot of potential variables
Heating & Cooling Logo
Top Amana Heating & Cooling Experts
Bill Long
Pete Norton
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
