Question about Sony MHC-ZX10 CD Shelf System
Problem with turning my system on....
When i come to turn on my MHC-ZX10 it loads up and after about 4 seconds comes up with the following message: "Push Power" and "Protect" and i cant do anythnig but turn it off again. I have tried reconnecting it but my knowledge on music centers is very limited. I hope someone out there can offer some help on this issue. Cheers.
    Scholar:
  • 119 Answers
Whan a unit goes into protect, it could be a bad speaker, shorted speaker wires. or the most common fault is a blown audio o/p ic in the unit. due to being compact units they are more difficult to work on than the full size unit. the part typically runs between $25.00 to $75.00 usd. if you are good with working on small places and are good with soldering give it a try. the ic will be on a heatsink. good luck.
Posted on Jan 31, 2007
SOURCE:
When i play a cd no sound comes
check the speaker cables are correctly in the speakers and the main
unit
Jun 30, 2012 | Sony MHC-ZX10 CD Shelf System
Water Damage/Power Protect...
Something has happened to it. Might be an IC fault. Seek assistance of any experienced service technician.
Jun 07, 2012 | Sony MHC-GS300AV CD Shelf System
Im having problems with my Sony MHC-GX9900, when i turn it on it it shuts down after a second or so, what can i do to fix it?
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Apr 01, 2011 | Sony MHC-GX9900 Shelf System
My Sony stereo system keeps turning off ten seconds after i push the power button to turn it on and I have no idea whats going on with it.his problem has also just started. The type of stereo is a...
Apr 01, 2011 | Sony MHC-LX1000 Shelf System
So when I turn on my sony MHC-GX8800 shelf system, it stays on for a few seconds and then turns off. The power button flashes red as well
I had a extremely similar problem with that model the only difference is that it used to turn off whenever I put the volume up. Anyway there was a peace of stranded wire behind the speakers terminal block connector, so be sure to check it out.
Feb 02, 2010 | Sony MHC-GX8800 CD Shelf System
Retrieving messages over phone
when your greeting answers, punch in your code, usually a 4 digit code, each manufacturer has their own default code that it comes with.. check the manual or website
Apr 14, 2009 | Lands Phones
Protect power keeps coming on - rdx5 MHC
protect usually means a speaker wire problem. remove all connections and redo them making nice tight twists in the connections the spliced end should be no more than 1/4 inch long. make sure to do this for all speakers as well as on the back of the unit.
Feb 23, 2009 | Sony MHC-RXD5 Shelf System
Additional Speakers
hello my frien let me tell you that the system wont accept more speakers or diferent loads per ohm if the total load says 16 ohms by channel thats the total can handle so if you ad more speakers the system turns off before it burns or or have a severe damage........saludos
Nov 17, 2008 | Sony MHC-GX250 CD Shelf System
Protect push power
yea i have the same problem. i dont know but i think maybe the amp brd is faulty.
joe.
Apr 22, 2008 | Sony MHC-GS100 CD Shelf System
Sony MHC-ZX10 CD Shelf System Logo
190 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
