Question about HP Photosmart 2575 All-In-One InkJet Printer
Printer won't print
My printer print to the current settings.
  • HP Master
  • 5,568 Answers
Try the following: Open the Control Panel, then 'Printers and faxes,' highlight and delete the printer and if also shown as a fax machine, delete that occurrence too. Then with the printer on, reboot your system and force Windows to reinstall a driver or give it the original installation disk when it is requested.
Posted on Jan 13, 2009
How do I turn off the date and time stamp on the camera so it does not show up on the printed pictures?
There is a setting for that on your camera.. Hard thing is finding it with all of the material that is in there.
Sep 17, 2017 | Cameras
Printer claims ink cartridge is expired and won't let me print
Hello, if you change the date on your computer to 3 months previous (say), then reboot, you can probably overcome this temporarily. Obviously, for normal operation it's best to restore the date to current, and only set the date back when you want to print something.Regards,nicam49
Jan 10, 2012 | HP Officejet Pro 8500 Wireless All-In-One...
Printer won't print. I went to printer and it says there are 9 items to br pringted in queue but they won't print Printer says it is ready
Good Day Nanawhit!
That happens all the times when first print job encounter a problem and stops printing and it was followed by series of print jobs. Some reasons for stop printing could be a printer out of paper and printer not set as default printer.
The best way to fix it is to cancel all pending jobs. When print jobs window is cleared off pending print jobs, restart your PC and your printer. Then go to your printer and make sure it is the default printer.
After that try printing a test page. Once a test page is successful, you can now print as many as you want.
Jun 10, 2011 | Lexmark X2670 All-In-One Printer
I have an HP officejet 4215 printer. I cannot get the cartridge (color) 57 to print color! It has been working fine with the smaller cartridge but due to high level of printing, I was told to get 57. I...
If all the the computers connected to this printer via network:
  • Shut them all down except for one.
  • Go to that computer and go to your printer and fax settings
  • Identify the Hp OfficeJet 4515 and right click on the icon and select properties
  • On the General Tab, click on the button that says, "Printing Preferences"
  • Select the "Features" tab and go down to Color Options and check to see that the radial button is green for Print in Color option
  • Underneath that, there is another setting thatsays, "Color Management".
  • Check to see that it is already selected with, "ColorSmart/sRGB or Adobe/rgb
  • Click Ok and return to the Properties
  • Go to Color Management Tab and check to see that it is set to Automatic.
  • Underneath that, you'll see "Color Profiles currently associated with this printer.
  • Look to see that the field is populated, if not click on ADD, and select each color profile that is available
  • Click apply, then OK
  • Shutdown Computer
Turn the printer off, unplug the power from it, wait a couple of minutes, then plug power back to printer, then power it up.
  • Restart the computer you were working with
  • Go to printers and fax options window
  • Select the HP OfficeJet 4515
  • Right click, select properties
  • On General tab, click on, Print Test Page
  • Go to printer to see if printing test page
  • Check to if the Microsoft Windows logo was printed in color
If it is in color, then print the color document you were previously attempting in color.
If it does not print in color, you will have to check your settings on the program that is being used for the document.
Jun 02, 2011 | HP Officejet 4215 All-in-One Color Photo...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
I have a HPC7280 all in one. it is asking to insert a memory card for copies. why? how do i get around that.
It sounds to me like you have selected an option to print directly from a memory card at one time. Here are excerpts from the user manual for your machine to change printer settings:
Change the print settings
You can customize the print settings of the HP All-in-One to handle nearly any print
task.
Windows users
Before you change print settings, you should decide if you want to change the settings
for the current print job only, or if you want to make the settings the defaults for all
future print jobs. How you display print settings depends on whether or not you want
to apply the change to all future print jobs or just to the current print job.
To change the print settings for all future jobs
1. In the HP Director, click Settings, point to Print Settings, and then click Printer
Settings.
2. Make changes to the print settings, and click OK.
To change the print settings for the current job
1. On the File menu in your software application, click Print.
2. Make sure the HP All-in-One is the selected printer.
3. Click the button that opens the Properties dialog box.
Depending on your software application, this button might be called Properties,
Options, Printer Setup, Printer, or Preferences.
4. Make changes to the print settings, and click OK.
5. Click Print or OK in the Print dialog box to print the job.
I believe that this should help you get around your issue. Here is a link to the entire user manual for future reference.
http://h10032.www1.hp.com/ctg/Manual/c00276605.pdf
Dec 22, 2010 | HP PSC 1610 All-In-One InkJet Printer
I want to print onto christmas cards, how can I set up my HP photosmart 2610 to do this
To apply the change to all future print jobs or just to the current print job.
1. In the HP Solution Center, click Settings, point to Print Settings, and then click
Printer Settings.
Dec 03, 2010 | HP Office Equipment & Supplies
The printer works but skips labels sometimes and causes some labels to be printing on two different labels instead of one. How can I fix this?
make sure the printer is calibrated. It should feed 1 label only. If it does not default it to force a calibration. hold pause and feed while off then turn on, count to 6 and release the buttons. You also need to set label height and width in the printer driver. Both zebra designer and zebra universial. goto printers and faxes and right click on your printer driver chose properties, this opens up on the general tab.
Configuration changes for current job and Default Configuration changes
There are two places in the driver configuration to change print configuration. In Windows 98, ME, 2000 and XP, go to the "General" tab and click the "Printing Preferences..." button. This menu of configuration parameters are the settings that are in effect for the current print job. Any changes made here will only affect the current, or next, print job. These settings are initialized for each print job from the configuration defaults.
Go to the "Advanced" tab and click the "Printing Defaults..." button. The displayed configuration menu describes the default settings for the driver. These settings are used to set the initial "Printing Preferences..." for new print jobs. It is a convenient place to set parameters that seldom change in you environment. Commonly set default parameters include Printer firmware, Media Settings, Device Options, and Page Size.
On Windows NT, these menus are available when you right click on the printer name in the Printers folder. The pop-up menu contains selections for "Printer Settings" and "Default Settings" which take you to these screens in the driver.
Aug 20, 2009 | Zebra Z4M Printer
Officejet 6110 all in one - printing problem with Mac Os X 10.5
I suspect this is not the printer problem. The problem may be the operating system issue. (Memory management)
Regards
Rafique
Jan 22, 2008 | HP OfficeJet 6110 All-In-One InkJet...
How to identify current font settings
Try printing the menu like this -With power on press the "Shift" tand "Select" button, a red menu light will pop up on the touch panel ! than press the "Print" button on the touch panel-this will print out the current settings of your printer.
Good luck
Dezzi
Sep 21, 2007 | OKI MICROLINE 520 Matrix Printer
HP Photosmart 2575 All-In-One InkJet Printer Logo
29 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
