Question about Dryers
Intermittent heat in our GE electric dryer
When we first turn the dryer on the heat seems to be OK but after a short time it diminishes to barely warm. It takes 2½ hours to dry a full cotton load that used to dry in 70 minutes.
  • 706 Answers
Hello Makathi,
Your problem may be related to a few things.. Depending on the age and use of your dryer, your heating element may be on its way out ( meaning that the element itself is eroding to a point of it not getting hot enough and will eventually open and need replacement) but.. you could have other issues too that affect the dry time.. You need to verify that your exhaust system is free from lint and is NOT restricting air flow out. You could have something in the blower itself that restricts air flow. Those are the basic components associated with your system dry process. If I were there, the very first thing I would check is the exhaust path out of the dryer ( including the end diverter to make sure that isn't restricting flow) Since yours is an electric dryer, you could do a simple test indoors by detaching the exhaust line and running the dryer inside for a short time.. The byproduct of electric dryers isn't as dangerous as a gas system so its ok to run it that way to check the flow coming out of the dryer,... Chances are one of the things I mentioned will solve your problem.. I'll keep an eye out for your feedback.. Hope this helps you
Regards,
Rick
Posted on Nov 22, 2008
Have a whirlpool dryer type dwsr ele 2406026-cv54 / mod wed4900xvo , we get a burning smell on all items
  1. Ok, bare with me...
    Is there any visible SMOKE with the smell? If so turn it off and call a repairman.
  2. Verify that the clothes drum is turning freely. If it is not, call a repairman.
  3. Otherwise;
    I recommend removing all clothing from your dryer and to carefully follow these instructions.
  4. With the machine off, Clean the dryer filter well. Set dryer to the MAXIMUM heat setting on a 30 min TIMED cycle.
  5. Start the cycle.
  6. Make close observations in short intervals of time.
  7. At the end of your timed cycle determine if the smell has changed more or less.
  8. With the dryer off, Locate the electrical socket/plug of the device if it is an electric machine. place your hand on it to determine it's temperature. It should be no more than Luke-warm to touch.
  9. If it is uncomfortably warm to touch you should consider contacting an electrician to determine the working load of the wiring to the device.
  10. If the wiring/plug test is deemed adequately cool, ventilate the dyer area well for an hour and repeat steps 3-7, the hot - empty test again. The smell should diminish.
Lint and other clothes debris can get pulled into contact with the dryer's heating element and it will burn or smolder. If a piece of elastic rubber gets into contact with the heating element, the smell will be strong and may last a long time.
If it is still bothersome after the burn-out procedure, it will have to be taken apart and at least cleaned or the element replaced. This is not usually covered by warranty as it is considered a USER PROBLEM. Sorry.
Mar 29, 2017 | Whirlpool Dryers
GE dryer model dwsr405eb0ww has intermittent heat problem associated with centrifugal motor switch. Interior drum light goes off with door open when centrifugal switch disengages. This is intermitte
First thing I would do is un-plug the product and remove the line cord access plate and check the terminal block/cord connections, a lot of times the installer of the product does not get the terminal block 'nuts' tight enough and it either burns up or cause erratic operation. If this checks out ok check your home electrical supply system.
Jan 09, 2015 | GE Dryers
My electric amana dryer heats up but does not seem to blow the heat around and the lint is only gathering at the bottom of the lint trap, so it takes forever to dry my clothes. What do I need to do?
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
May 28, 2012 | Amana ALE230RAW Electric Dryer
Needs two cycles to dry clothes!
May 19, 2012 | Kenmore Dryers
There is a loud rumbliing sound that seems to be coming from the motor (haier hlp140e) it's ability to heat also seems diminished. The rumbling used to happen on and off, but now it happens all the...
sounds like bearing noise and drum hitting on inside of outer body - naturally the drying process will be somewhat diminished and eventually the whole drum will compromised and collapse . Advice is to purchase a new dryer .
Jul 25, 2011 | Haier HLP140E Electric Portable Dryer
I have a GE dryer mod# DCVH680EJOMS, and it runs but no heat. I have checked the power supply, thermostats, and the coil. they all seem ok. Any advice? Thanks, Jason
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 19, 2010 | GE DCVH515EF Electric Dryer
2year old ge dryer trips breaker when it's turned on, but sometimes will run a complete cycle before it shuts off.
HELLO THERE
Electric dryers require the use of a 220 volt line. The dryer heating elements run off of 220 volts. An excessive draw of electricity, or a short in the wiring can blow a fuse or trip a breaker. This happens to protect sensitive components from damage, and to help prevent fires. Every other dryer component operates off of 110 volts, the timer, motor, etc. Usually when a fuse blows or a circuit trips, it's because there's to much draw on the power line.
It is very possible for one part of your dryer to work fine, and yet another to have a problem, such as a short circuit. A short circuit may be caused by the heating element, internal wiring, or the main power cord.
To troubleshoot this problem, unplug the dryer and check to see if the circuit breaker or fuse remains on when the dryer is unplugged. If they stay on, it's more than likely the problem is somewhere in the dryer.
If your fuse blows, or the circuit breaker trips when the dryer is unplugged, it's likely the problem is with the circuit breaker, fuse box, or house wiring; contact a professional electrician.
OK I hope this is very helpful for you
Best regards Michael
Dec 01, 2009 | GE DBSR453EBWW Electric Dryer
New GE Profile Dryer makes intermittent loud squeeking or rubbing
Your drum may be out of round. The drum belt on the outside of the drum may be rubbing against the cabinet. When the cabinet heats up, the side walls of the cabinet may be bowing inward, thus making contact with the belt on the drum. This would explain why it is intermittant. When the heater turns off, the cabinet cools and the sides bow back out.
Jul 11, 2009 | GE Profile Harmony DPGT750EC Electric...
GE dryer barely heating
If this is an ELECTRIC dryer, you're supposed to read 120VAC at both L1 and L2. With the cord UNPLUGGED, check the voltage across L1 and l2 at the wall receptacle. You should read a cumulative of 220-240VAC. If you're only getting 120VAC, the problem is at your receptacle, which would explain why the dryer is not heating. The heating circuits and timer require 220VAC, while the drive motor only requires 120VAC. If the power at the receptacle is good, leave the dryer unplugged and check the continuity of the power cord from the end of the plug at L2 to the terminal block at the back of the dryer. You should read a short or 0 ohms. If the continuity of the plug is good, the problem may be a loose connection at the terminal block or a broken wire. If the continuity is bad (open), then it looks like you may have a bad power cord. Please post back if you have questions. I hope this helps you.
Jan 03, 2009 | GE DVLR223 Dryers
Long drying time
Check directly behind dryer to see if there is squished flex vent. Also keep vent as short and straight as possible. Avoid flex venting, or use as little of it as possible.
Jul 17, 2008 | GE Profile Harmony DPGT750EC Electric...
Dryers Logo
89 people viewed this question
Top Dryers Experts
