Question about LaCie (300728U) 250 GB Hard Drive
Help Situation: The firewire cable accidentally got unplugged while FCP 5.1 was open, and my drive is no longer mounting on the desktop. I am fairly certain the firewire ports are still functioning on my lacie drive, as OS X Disk Utility still recognizes my drive. I am using Disk Warrior 3.0 to try to restore the Lacie, but i'm having problems getting Disk Warrior to recognize my lacie. OS X Disk Utility recognizes my lacie drive but says Mount Point: Not mounted When I try to verify and repair using OS X Disk Utility, i get an error message saying "Phase 1-Read FAT Unable to read FAT (Input/output error) Error: The underlying task reported failure on exit 1 non HFS volume checked 1 volume could not be repaired because of an error" I tried using Disk Warrior 3.0 but it doesn't recognize my lacie drive when it scans. What can I do to get Disk Warrior to recognize my lacie? My goal is to try to repair my lacie drive using Disk Warrior 3.0-how can I get Disk Warrior to recognize my lacie drive when it's not mounting but is obviously there? I am running Tiger 10.4.8, PowerPC G4 1.67 Ghx with 2 GB DDR SDRAM. Editing using FCP 5.1 Are there any possible solutions I am overlooking other than bringing my lacie into a local hardware dealership or downloading DW 4.0? I am desperate any help would be appreciated! Regards, jimmy wang
  • 42 Answers
Take it in, controller may have malf'ed when it got unplugged, been known to happen.
Posted on Dec 09, 2007
I have tried to connect my Canon XM2 to my IMac via firewire, but it is not 'seen' by IMovie, FCE or FCP, so I can't capture anything. Thanks
Open the System Profiler on the Mac and establish if the camera is connected to the Mac's firewire BUS. If not, try another cable and also test is the camera's firewire port is working. It's either a cable or socket issue. Some cameras require that the menu of the camera be set to output over firewire, check this as well.
May 05, 2011 | Canon DM-XM2 Mini DV Digital Camcorder
My Apple G5 and WD Passport 500Gb don't mount
You need to determine whether the problem is at the disk interface or at the computer interface. Will the drive mount on ANOTHER machine using FireWire? Will your computer mount ANOTHER device using FireWire? This will tell you which machine is at fault. It's not unheard of for the FireWire channels in a Mac to just go bad, and (unless it is a Mac Pro) it typically requires a logic board replacement to address. For a G5, this would not be cost-effective. On the other hand, as I say, it could just be a bad interface in the drive itself. It's up to you to determine which it is.
Sep 20, 2009 | Apple iMac G5 Desktop
Playback problem DSR 11
if you plug & unplug cable after turning off ,perhaps you can the conector firewire on the vcr inside there are 4 yellow cables if not the conector defect.try to push the cable firewire litle up down side just to make sure
Apr 29, 2009 | Sony DSR-11 DV / Mini DV VCR
My Porsche Lacie 160GB disk no longer mounts on my Mac OS X. OS is fully up to date at 10.5.6. I've tried it with different firewire cables and on multiple Macs. One is a dual G4 desktop, the other is a...
You need to back up data from the drive and then connect your drive on MAC you need to use mac utility to format the hard disk in Mac as some times it wont recognize a windows operating system...
Jan 08, 2009 | Computers & Internet
Maxtor 1Touch4 won't connect
FIXYA! Hey, found out my maxtor issue...pretty much by accident though, with a little pinch of desperation. I powered down my MacBook, disconnected the drives (2) from their firewire and power and waited for about, oh, I dunno....30-40 seconds. Upon stubborn study of the power supply, something told me to just switch one adapter for the other!
So...I did it. Once plugged back in to my power strip, both LED's lit up and stayed continuous. Then, I just reconnected their firewire ports and, voila!...I was back online. Hate to think all that stress was just a matter of swapping power cords...but...here I am.
Hope that helps someone else.
Dave
Jul 07, 2008 | Maxtor One Touch III 500GB FireWire/USB2.0...
External drive won't spin to burn CD but....
Thank you for the feedback. This issue seemed to start after I upgraded to Mac OS 10.4. Previously, I was running on OS 10.28 and had used the drive plugged in the same way for over two years.
Are you asking if I have a USB cable connected to my Firewire device or if I simply have other USB cables connected to my computer? Are you suggesting that I disconnect other USB devices? Your comment on "two cables" leads me to believe that.
The confusing part of this for me is that I can read a CD from the external drive and the CD does show up on my desktop.
Before I posted the first time last night, I turned off the drive, disconnected the Firewire cable from both it and my CPU, and reversed the process.
Could this just be a drive that has crapped itself out?
May 23, 2008 | EZQuest Boa CD-RW Burner
DV In flashing when plugged into computer
Dear njfire,
Test or change your cable !!
(Cable is IEEE 1394 and/or Firewire and/or I.Link, 4-4 pin)
Regards
May 19, 2008 | Canon GL2 Mini DV Digital Camcorder
Firestore FS-4 no longer recognized as external drive by Macs
bad firewire port try getting a new firewire card throw usb many or pcmia pci card for desktops
Jan 30, 2008 | Video Cameras
DSR-11 not recognized by FCP
Hello tommy_bee, Try the advice offered on this link. http://forums.creativecow.net/readpost/35/856108 It has helped me
Aug 15, 2007 | Sony DSR-11 DV / Mini DV VCR
LaCie (300728U) 250 GB Hard Drive Logo
395 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Marvin
Marvin
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
