Question about Hitachi 53UDX10B 53" Rear Projection Television
Help please,.... I saw that you were reated hi in the answer section. i have a question. i have a hitachi 53udx10b rear projection tv. I had a convergence problem, my red went every where. it was stretched out like it was on a different aspect ratio. after some research i found out that the most likely problem was the Semiconductor STK392-110. i ordeered two up, spent some time replaceing them adn fired up the old beast. after the install, the picture was much better, but it still wont line up the red light, i pushed the service only button and came to the realization that the red projection was still slightly wider than the others, my question is this. is there a programer, or procedure that needs to be done if the magic focus is still not able to get the convergence in line?? thank you in advance for any help you might have.
  • 1 more comment
  • James Nov 23, 2008
    where might i find info on what hitachi recomends?? thank you for the help.
  • James Dec 05, 2008
    thanks to all for the great help, i fixed the tv tonight, my resistors were on back order, i recieved 3 of the 6, i ended up replacing only one, it looked burnt and measured out of spec. after that, magic focus and shazam!!! i hooked everything up and heard the wife call from upstairs "HONEY, THERE IS WATER IN THE BOTOM OF THE DISHWASHER!!!" WILL IT EVER END???
  • rails0404 Dec 09, 2008
    Hi I have the same Hitachi all of a sudden when I turned it on the red doesn't match up and is shadowing everything. What did you have to do to fix this problem? Any help would be greatly appreciated. Thanks
  • Hitachi Master
  • 8,617 Answers
Did your replace the convcergence feed resistors along with the ICs? As Hitachi recomend replacing the six feed resistors along with the ICs as often the old resistors will blow or increase in tolerances when the old ICs go out.
Posted on Nov 22, 2008
  • Sonny Berry
    Sonny Berry Nov 23, 2008
    The resistors are;
    RK42 3.3 ohm 1watt
    RK46 1.8 ohm 1watt
    RK50 3.3 ohm 1watt
    RK54 1.8 ohm 1watt
    RK58 3.9 ohm 1watt
    RK62 2.2 ohm 1watt
Hitachi TV 51 "
Tv is not turning on....you can hear it click....model # 51zx24k Hitachi...
Jun 19, 2011 | Hitachi 53UDX10B 53" Rear Projection...
Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Oct 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Help! It's stuck. Stubborn Convergence board.
Did you remove the screws off the board.? That should do it. !!
Jan 07, 2009 | Hitachi 53UDX10B 53" Rear Projection...
I have a Hitachi 53UDX10B 53 in. Rear Projection HDTV.
Hello iehoryna,
The answer is yes, you will be able to pick up and display HD channels. You will have to use your component video cables between your cable box and your TV. Component video will allow you to view low to medium end HD pictures.
I hope this helps,
Thank you,
Shuttle83
Nov 21, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi tv
the 53udx10b was changed in production - the change was to the lenses on the picture tubes all else in the set remained the same
thanks
scott
Jun 13, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Problems with my 50 inch hitachi ultravision projection screen tv
check the solder around the area of the vertical IC. solder is either cracked or else cold. Cold solder appears as dull. Resolder anything that isnt shiny.
May 20, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi tv, model 53udx10b
Sounds like you need to run Magic Focus.
Sep 22, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Is it possible to hook up a Playstation 3?
No ,The set Does not have the Proper Dital Setup for it Sorry ttech
Jul 29, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Hitachi 53UDX10B 53" Rear Projection Television Logo
80 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
