Question about HP - HP Photosmart 8250 printer
I have a paper jam and can not get to the paper
I have a paper jam in my printer. I can only open the top so far, I only see a corner of the paper in here. I can not get the paper tray out so I can not get to it that way. Any suggestions?
  • Anonymous Nov 25, 2008
    I have a paper jam. The suggested solution is to disassemble the printer. How do I do this?
  • harvey57329 Dec 14, 2008
    How do you remove the tray assembly without breaking it!
    Scholar:
  • 130 Answers
If the machine says paper jam then the machine will not function until the paper is removed. The machine has to be disassembled and the paper removed.
Posted on Nov 22, 2008
Can see the paper jam from the back at the top - folded tightly, no way to grab a corner, how far can it be taken apart? No moving parts visible.
It'd probably be better to get pliers or tweezers to pull the paper out from the back, instead of trying to take the printer apart further.
Jun 06, 2011 | Dell 1710n Laser Printer
Right corner paper jam fixes?
This error message is displayed by the printer when paper is jammed in one or more locations. In such a case, users are recommended to remove the jammed paper from the specified location. The entire paper path must be checked for any pieces of paper. To stop the message, open and close the top most cover of the printer. Lastly, verify the flags and the sensors. If the problem persists, the cause of the error message could be a broken sensor or sensor lever.
Nov 09, 2010 | Canon PIXMA MP460 All-In-One InkJet...
My printer will not print from my lap top. Printer will let me copy, but not print from the computer. Someone suggested that I uninstall and then reinstall program, but I cannot locate the disk. Anyone...
If it worked fine and it indicates a ppaper jam, open the top of the printer and check the left and right corner where the rollers are to make sure their is not a piece from a corner of a sheet. A small piece of paper will give paper jam.
Unplug the printer, replug back in. It should work. If not, open the back to make sure their is not a sheet sutck there by accident. thanks
Mar 11, 2010 | HP PSC 1315 All-In-One InkJet Printer
The paper jams into the right corner when
if you can get it out consult a technician to do that, because it is the cause of the paper jam and could also damage the drum if you continue.
Feb 06, 2010 | Canon Pixma iP2600 Photo InkJet Printer
Paper Jams in Right bottom corner
it must be a small piece of paper inside your paper tray...
you need to open your printer cover...
its easy,you just need a screwdriver...
believe me,its easy to do it....
Jan 06, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Paper Jam
Usually with lexmarks its the sensor in there, it either has something going across it
Ths other thing it can be is the pinch roller that is in there if you can clean it with a qtip and achohol
Aug 13, 2009 | Lexmark X5150 All-In-One InkJet Printer
Brother printer, paper inside, but I do not see paper inside.
PAPER JAMMED INSIDE THE MFC
1. Remove the Jam Clear Cover located in the back of the machine..
Squeeze the plastic tabs located on the right and left side of the cover
and pull the cover off.
2. Remove any paper you can see jammed in the machine. If you cannot
remove the jammed paper from the back of the unit follow the in
structions listed below for reinserting the cover and then continue to Step 4.
3. Re-insert the Jam Clear Cover. The top of the cover has a slotted
opening in the center approximately 1/4 inch wide. Hold the cover by the
plastic tabs located in the front of the cover on the right and left side and insert the cover into the opening until it securely
clicks intoplace (both sides).
4. Open the scanner cover by pulling up on the lower right corner of the
cover until it locks into place.
5. Remove the jammed paper. If the paper is jammed underneath the print
head, unplug the machine from the AC power outlet. Gently move the
printhead to the far right side of the machine (the "home" position) and
then remove the jammed paper.
6. Lift the scanner cover to release the lock and then gently push the
scanner cover support down and close the scanner cover.
To test print the Help List by pressing Menu/Set, 6 (Print Reports), 1
(Help List) and then Black Start. The Help list should begin printing.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Oct 12, 2008 | Brother MFC 420CN All-In-One InkJet...
HP 6210 All-In-One
Open up the top and look into the cartridge/paper print area. Look in the corners, Sometimes little pieces of paper can still be stuck there. Once you are convinced that the paper and cartridge path is clear then...
Pull out the paper tray. Look inside the opening. If there is paper there then pull it out.
Take all of the paper out of the paper tray.
Turn it over (paper on top is now on the bottom of the tray)
Try it now.
Jun 20, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Curled corner causing a paper jam
Try replacing all paper. Sometimes paper that is overly humid or has gotten wet will curl. Replace with new paper and report results.
Dec 17, 2007 | Dell 1600n All-In-One Laser Printer
114 people viewed this question
Seeker5211
Seeker5211
