Question about Mtd 22" Yard Machine Push Mower
Oil change i cant figure out how to change the oil in my mtd yard machine snow blower
  • Anonymous Jan 14, 2009
    nope
    didn't work
    Problem Solver:
  • 5 Answers
If this model has a fill tube on it- turn the unit on its side to drain.
Posted on Feb 06, 2009
  • 37 Answers
Hi, at the base of your engine there is what you call a plug. it has a square top and it is screwed in motor casting. just un screw it and the oil will come out.
If this doesn’t work for you please write back. Thanks,
Posted on Nov 23, 2008
My mtd yard machine snow blower gear turns freely, doesn't turn with the wheels. found problem when blower would not move
if u ck the pins in the center of your wheel hubs , you may see one or both missing , these pins are to allow one to free wheel the blower to "push " it easier , they do rust and break off over time
Dec 13, 2016 | Garden
Need manual
769-06277 Parts Manual, 769-06032 Operator Manual, 769-06052B, Engine Manual. You can find them here,
Yard Machines Snow Thrower 31AS62EE700
Feb 10, 2016 | Mtd Yard Machines 24" Two Stage Snow...
Where is neutral? wheels are locked & won't push forward
there could be a loose or stuck gear in drive system.
press the helpful button below and check out the link below
How to Repair Stuck MTD snowblower drive system
Jan 15, 2016 | Mtd Yard Machines 24" Two Stage Snow...
How do you mix the gas for a 3 horsepower 21 inch yard machine snow blower
Most newer machines say to mix 50:1
Do yourself a favor and mix 40:1 the machine will last longer. There is no ill effects by running a little more oil. They instruct you to run 50:1 so they can make the clean air ( EPA) people happy .. meanwhile your engine is not lubricated properly.
Dec 14, 2013 | Mtd Garden
Have a 22 inch yard machine snow blower the belt that turns the blades broke what size belt does it take
MTD has made many 22" machines over the years. Please repost your question indicating the model #
Dec 27, 2010 | Mtd 22" Yard Machine Push Mower
MTD YARD MACHINE SNOW BLOWER DOES NTO SHIFT INTO
Many times moisture attacks the hexagon shaft that the friction disc assembly slides on. It slides from side to side on the shaft to create Reverse 1 & 2, and the other end creates 1-6 forward. With a wire brush and sandpaper, clean the rust from the hexagon shaft, at the same time lubricate the friction disc bearing with penetrating oil and with a soft hammer, tap gently until the assembly starts to slide on the hexagon shaft. After all the rust is removed and disc assembly is sliding, apply a light film of graphite grease on the shaft. You may want to re-lubricate on a yearly basis.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Jul 09, 2009 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
I HAVE A 660 SERIES MTD YARD MACHINE 17.5HP 42
If the speed seems to be different after changing the belts, it should return to normal after they break in.
The 600 series has a top speed of about 5 - 6 MPH, see:
http://support.mtdproducts.com/cgi-bin/mtd.cfg/php/enduser/std_adp.php?p_faqid=79&p_created=1027096447&p_sid=tq2XafGj&p_accessibility=0&p_redirect=&p_lva=68&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9MTYsMTYmcF9wcm9kcz0zMDEmcF9jYXRzPTAmcF9wdj0xLjMwMSZwX2N2PSZwX3BhZ2U9MSZwX3NlYXJjaF90ZXh0PXNwZWVkIGNvbnRyb2w*&p_li=&p_topview=1
Apr 24, 2009 | Mtd Products Yard Machines 158CC Tiller
Mtd 22" Yard Machine Push Mower Logo
1,083 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
