Question about Porter Cable Cable Brad Nailer and Compressor Combo Kit CFBN200A
My porter cable compressor isn't shutting off
When the compressor reaches the desired pressure, it doesn't shut off... any ideas what controls the shut off to potentially replace it?
    Problem Solver:
  • 7 Answers
Dear JG,
The probably is probably the pressure regulator switch. It's the box the 110 vac wires come from the outlet and go into. Reset the switch or replace it. Note! overfilling an air pressure tank is extremely Dangerous. The tank, fittings, compressor head and or related parts may explode resulting in property damage as well as serious and potentially fatal personal injury.
Good luck,
Posted on Nov 24, 2008
Porter cable pancake compressor will not shut off replaced manifold, still the same.
I would look at the pressure switch which shuts the electric off when the air pressure reaches its limit also check all wires going to and from this switch. Best checked with a multi-meter.
Feb 07, 2015 | Porter Cable Air Tools & Compressors
The over-pressure relief valve may be defective if the valve is opening before the desired tank pressure is reached. If not, then the shut-off pressure adjustment (if there is one) may be set wrong. You'll need to find out from the manufacturer exactly what static tank pressure the compressor is designed to provide and then determine if it is working correctly. If so, then the relief valve might be defective. DO NOT attempt to defeat the relief valve under any circumstances - it can result in compressor damage or a dangerous tank failure.
Oct 06, 2014 | Porter Cable 175 PSI 80 Gal. Oil-Lube...
A porter cable 135 psi 60 gallon upright
If the motor doesn't shut off at the desired pressure then your pressure switch is either set too high or is broken/stuck. The pressure leak at 150 psi is the safety valve doing its job opening when the pressure gets to an unsafe level in the tank.
Aug 27, 2012 | Porter Cable Air Tools & Compressors
Why my air compressor want shut off after building up pressure
If it is building up to the full rated pressure and there are no air leaks in the hoses then it is most likely the pressure switch. It is item 111 in this parts diagram.
Porter Cable C2002 diagram
Aug 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
I have a porter cable double stack 150psi air compressor that will run then shut off when it is suppose to but no pressure on the regulator guage and no air will come out the hose when you hook up to
Make sure the regulator is working and set to the desired pressure. There should be a knob and guage showing the pressure. It may also be a bad compressor.
Aug 03, 2012 | Porter Cable Air Tools & Compressors
I have a C2001-WK that does not auto shut off
A regulator controls the pressure in the air line leaving the compressor and does not affect when the compressor turns on or off.
The pressure switch monitors the pressure in the tank and turns the compressor motor on and off when the switch closes or opens in response to changes in the tank pressure. If the compressor does not shut off, it is possible the pressure switch has been set to a pressure level that is higher than the compressor is capable of attaining, thus it does not shut off.
The compressor is capable of developing 150 psi and is noted as having a "120 psi cut-in pressure". When you say it doesn't shut off, does that mean it will generate 150 psi or more of pressure and fails to shut off or it develops less than 150 psi and does not shut off.
If the compressor does not generate 150 psi, then it is probably somewhat worn out and not capable of developing enough pressure to meet the factory high pressure limit. I would try adjusting the pressure switch upper pressure limit down to 130 psi or less (less if the compressor will not develop 130 psi) and see if this solves your problem If it doesn't,
If the compressor will develop 150 psi or more, then try adjusting the high pressure limit to less than 150 psi. If you can't adjust the high pressure limit then the pressure switch is defective and needs to be replaced.
My porter cable pancake PSI 150 keeps running will not shut off
The compressor has a max psi setting of 150.If the pressure is not reaching this or is only stabilizing at a low pressure you have an air leak around a gasket somewhere.If it is reaching 150psi and not shutting off your pressure switch is bad.Replace it.Check your owner's manual for a part number or go to to find the part.
May 05, 2011 | Porter Cable Air Tools & Compressors
Pressure switch dows not shut off motor when
Pressure switch has gone bad and needs to be replaced. Part runs around $25. Go online and put in model number, pressure switch. You will find companies that sell replacement parts. I had to replace mind, it did the same thing.
May 03, 2010 | Porter Cable 18 - Gauge Brad Nailer and...
Will not shut off after pressure is reached, must shut off with switch
it sounds like the pressure switch is malfunctioning and should be replaced. I would recommend going to and typing in your model number for a breakdown for this compressor and replacement parts.
Nov 19, 2009 | Porter Cable 18 - Gauge Brad Nailer and...
Porter Cable Cable Brad Nailer and Compressor Combo Kit CFBN200A Logo
374 people viewed this question
Top Porter Cable Air Tools & Compressors Experts
John Trevino
Are you a Porter Cable Air Tool and Compressor Expert? Answer questions, earn points and help others
