Enter Key is damaged and will not work
SOURCE: Enter key on laptop
u can use an oncreen keyboard if ur running winxp. to do this, click on start,all programs,accessories,assecibility,onscreen keyboard or beter still use the tab key on yr laptop keyboard after typing yr password keep presing it untill the ok button or enter or next which ever one u want to activate when highlited, click the space bar key it should work as enter key.
guess this helps
thank u for using fixya
SOURCE: Cannot identify Battery
Hi
Please update your system using this file and if this does not work try to reseat the battery and check.
If you are using vista download the file to desktop. Right click. Click on run as administrator. Let me know if this resolves your issue or you need more help.
http://support.dell.com/support/topics/global.aspx/support/downloads/en/downloads_splash?c=us&l=en&s=gen&~mode=popup&file=264350
Thank you
Rakesh
Expert Dell Laptops.
SOURCE: Dell Inspiron laptop will turn on but wont take me to log in screen
Sounds like you need a FRESH Install or a NEW HARDRIVE!...Hope you did a BACKUP OF YOUR PERSONAL FILES!...GOOD LUCK
SOURCE: dell laptop key for left click (enter) is almost useless,
You could try to remove it. Clean it up. Look for the rubber part on the keyboard not to be broken. If nothing works go to a service. But know that laptop keyboards are not cheap :P
SOURCE: the enter key no longer works on my lapton Inspiron 1526
Pretty simple to fix, replace the keyboard
http://shop.ebay.com/i.html?_nkw=1501+keyboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Motherboards&_odkw=B130+motherboard&_osacat=0
