Question about Coleman Powermate Premium Plus 6250W Portable Generator
The fly wheel will not turn - Coleman Powermate Premium Plus 6250W Portable Generator
  • 169 Answers
Wow, this could be so many different things. Here is a general procedure that I'd use to figure out what is going on, it's written with the Briggs engines used on Powermates in mind but more or less the same for any small engine.
First thing to do is eliminate the possibility of hydrostatic lock in the engine. This happens if there is a liquid (Fuel, Oil, Water) in the cylinder above the piston. You should probably do this outside ;-)
Take out the spark plug, make sure the ignition switch is in the off position, stand clear of the spark plug hole and gently pull on the starter rope. If there was liquid in the engine you'll see it come squirting out of the hole. Don't pull too hard on the rope, we don't want to break anything. You should also look at the end of the spark plug when you take it out, it may have evidence of liquid in the cylinder. It's also a good idea to visually inspect the cylinder as best you can. If you find fuel in the cylinder, you've probably got a carb problem, fuel fills the float bowl and runs down the intake if the carb is really dirty.
If you found the cylinder to be nice and dry, you need to check for bits of the engine stuck below the piston. Get a clean drain pan and drain all of the oil out of the engine. You want to make sure to get it really clean in there so use a spray can of brake cleaner to wash the crankcase by spraying thru the oil fill hole. Inspect the stuff that comes out looking for bits of metal, shreds of bearing, etc. If you've got any significant amount of metal in the crankcase you'll have to disassemble the engine further to see what's broken. This is a much more complicated thing.
If you didn't find any hydrostatic lock, and there aren't parts of engine in the crankcase it's time to check for broken valve parts. Carefully remove the valve cover (it's the thing that says OHV on it) be gentle so as not to break the gasket that seals it so the head. Check that the push rods are both in place and don't look bent, also check that the valves are in place. If both valves happen to be in the closed position at this point I usually do a leak down test - pressurize the cylinder with air and see how much leaks out where. It is best to do this with a real leakdown test rig, but it can be done with the hose from a compression tester and very careful use of an adjustable air supply. If everything looks good you can leave the valve cover off for the next part.
If you've gotten this far without finding anything seriously wrong with the engine this may be a case of stuck piston rings. When the engine isn't maintained well enough (and sometimes when it is) the piston rings can get goo behind them that makes them bind against the cylinder wall. Get a socket that will fit the flywheel nut, a chunk of pipe that will fit over the end of your ratchet handle (about 24 inches is long enough), and a supply of your favorite brand of penetrating lubricant (WD40, PB Blaster, Jigaloo). Spray the cylinder liberally with the lube and let it work for a few minutes. Then using the socket and cheater pipe gently try rocking the crank back and forth. Keep an eye on the rocker arms while you do this so you can get an idea of whether or not the camshaft is also turning. The camshaft not turning would be a Very Bad Thing.
With a bit of patience you should be able to free up the piston. It's better to have too much lube than too little. Try and move the piston just a little bit at a time down, then up. You need to listen to the engine while doing this to be able to hear any creaking or other bad noises from the bearings inside.
If you get the piston free, put in nice fresh oil, set the valve clearances and reassemble the valve cover, put in a new spark plug, reassemble the rest of what was taken apart and see if it will run. If it does you need to pay attention to rod knocking, bearing noises, and any other unexpected sounds. A fair amount of white smoke out of the exhaust is normal at first but if it continues you need to check for worn out or damaged rings/cylinder wall.
If you can't get the engine freed up with the above procedure you'll have to do a major teardown to find out what's wrong. Do yourself a favor and get the appropriate manual for your particular engine before you go any further.
Please rate this solution so it'll get shared,
Posted on Dec 01, 2008
1988 chevy pick up 5.7 some times when I turn the key it wont start I have to turn the fly wheel a inch or so for it to start any I dear what it might be
There are teeth on the fly wheel and you may have broken one or more teeth. You may have to replace the fly wheel. When you turn the fly wheel by hand you make the good teeth so the starter will work.
Jun 14, 2017 | Cars & Trucks
Bad starter
It is either a bad starter or a bad fly wheel. What happens is the teeth of one or the other wear down. If you are turning the starter several times and it finally starts then you have a bad spot on your fly wheel. One way to check is to pull out the starter and look at the teeth on it. If it is your fly wheel it should be replaced but you will have some time. As the wheel turns you will probably not hit the bald spot on it that often.
Oct 07, 2012 | 1996 Chrysler Sebring
Washer belt 7 PJE 1303
Right size belt, just a bear to put on. Easiest way, zip tie belt to fly wheel (one each side of spoke/spine). Than run belt around pulley on motor, turn fly wheel, helps to guide belt as you turn. Takes a lil force but not much. Than slowly turn fly wheel to center belt. Be sure the ribs of belt are in troffs of pulley, if not easily pushed over, about 1 inch from pulley.
Jun 25, 2012 | General Washing Machines
The tiller stalled out and now won't crank. Why?
Was there oil in it? Check and see if a rock or other item is wedge in the tines. Take of the engine shroud, remove the spark plug and see if you can manually turn the fly wheel. If you CAN turn the fly wheel pull on the pull rope. It might just be stuck. If you CANNOT turn the fly wheel then the engine is probably blown.
Good luck hope this helps.
May 23, 2010 | Troy-Bilt Pony Garden Tiller
Sierra 1500 wont turn over 350. locked up???
Have the battery tested for a dead cell. It may test at 12 volts but that doesn't mean there isn't a dead cell. Also, if the motor has good compression you probably shouldn't be able to turn it over by hand at the fly wheel. Maybe an old school motor with V belt, but not a newer motor with all those accessories attached to the front.
Mar 14, 2010 | GMC Sierra 1500 Cars & Trucks
If you hand-turn the flywheel, and it fails to turn, it might be that your engine is 'frozen". Remove the starter-motor and use a sizable flat-end screw-driver to try to turn the flywheel, just to be sure! The starter-motor is behind the flywheel, and if it is worn, you should get at least a 'crink' sound to indicate that the starter-motor pulls out and spins a bit. Yes, it is a big job removing the flywheel. You must have oil in the engine at all times!
Jul 11, 2009 | 1990 Suzuki DR 650 RS
Starter turning engaging not start
 you need a shim, if its screaming your clearance is to great. Are you positive its the right starter?
Feb 19, 2009 | 2003 Ford Ranger Regular Cab
not sure if u have tried this my friend,, but on the fly wheel side of the bike,, or left of the bike as u r sat on it,,is the casing covering the fly wheel,, on that casing u will see a screw ,ie looks like a nut ,, undo that to reveal in the hole a little bit of the fly wheel,, shine a torch down it and turn the engine over by hand or put it gear and rock it ,so the fly wheel turns eventually u will see a tdc mark or line engraved on the wheel,, ,,in the hole u r lookin down will be a pointer or small arrow on the casing,, line the to up ,,and then take the spark plug out and just lightly put a screw driver down the hole of the cylinder, it should be at the top of its stroke,,turn the engine over once to make sure the piston is as top dead centre,and the mark on fly wheel line up,, if u r using a strobe light it will be 10% b4 top dead centre.. any probs ,,e mail me, 4 the other solution,,
Dec 20, 2008 | 2006 Yamaha DT 125 X
94 safary grainded fly wheel
You more than likely need a new fly wheel, your fly wheel and starter are probably not making contact
Oct 18, 2008 | 1994 GMC Safari
Coleman Powermate Premium Plus 6250W Portable Generator Logo
156 people viewed this question
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
