Question about Roper REX4634KQ Electric Dryer
My dryer keeps shutting off, it is a Roper.
I have to keep turning the dryer back on it keeps shutting off during the cycle
  • Roper Master
  • 8,220 Answers
The motor is getting hot and shuuting down on overload. Checak see it the drum turns freely. If it does then motor replacement is imminent.To get int the dryer you yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way. Get the idler loose and remove the drum. Oil the wheels and idler and check the drum glides. Clean out the dryer. Sometimes you can oil the motor but it is tricky. Cheaper than a new motor though. Since yours does run a little it is a prime candidate for a little R&R. Drill out the endbells with an 8th inch drill bit. Careful not to hit the shaft. The manufacturer does not supply oil orts so you must make some. Get some high temp resistant HVAC zoomoil and refill the cotton wells on both sides. Work the motor till it turns freely. Good luck.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on Dec 16, 2008
I have a Roper RED4640YQ1 dryer and it will not advance to the cool down cycle on any setting. The dryer completely shuts off as if the cycle was over. I've replaced the thermal fuse, nothing changed.
Not familiar with the Roper unit but most dryers have TWO thermal sensors.
One to keep check of the Drum temperature and one in the coil chambers to regulate the coil temperature
Jun 05, 2015 | Roper Dryers
Dryer model Roper RED4340SQ1 rmy heater don't stay hot all the time during a drying cycle is it normal or i need to change it
You may want to do a thorough tuneup on your dryer. I worked on a couple and wrote a pictorial on it. ROPER DRYER TUNE-UP
My Home movie of a Roper dryer with a heat problem:
Sep 06, 2012 | Roper Dryers
The signal dings at end of drying cycle but dryer keeps on running without heat
The drier works fine and heats during the cycle and then when the cycle is over the heat quits but the drier keeps running? Does it shut off when you open the door?
Aug 08, 2011 | Samsung DV330AE Dryer
When one opens door ------dryer keeps running
Simple repair. e45a747.jpg5fc411d.jpgf1e9000.jpgIf you gonna remove the front to do the repair I suggest you lift up on the panel to keep from damaging the clips that hold the bottom secure46c7a66.jpg
Jul 24, 2010 | Roper Dryers
I have a roper dryer. I took it apart today
Remove all duct work connected to this dryer. Clean thoroughly. You will find amass of lint inside of it causing your problem. If not the moister sensor is not working properly and needs to be replaced.
I do hope you will find a clogged vent tube for it is easier to clean the tube than to replace the sensor. The sensor is a fail safe part. It keeps the dryer from catching on fire when the lint tube is clogged up
Apr 27, 2010 | Roper REX4634KQ Electric Dryer
Kenmore 80 series keeps shutting off. new motor and lint line cle
take off the vent line from the back of the dryer,if it runs fine your vent line is blocked or the outside vent where the flapper opens might have a cage on it to keep animals out of the line,it keeps the animals out but it's a lint trap.if you have a long run use a leaf blower and blow out the vent line,if that's ok check the t-stats on the heater box,
Nov 12, 2009 | Kenmore Dryers
My roper REX3514 Dryer will only dry on the time cycle.
If you use a lot of dryer sheets, it will build up an oily residue on the sensor strips causing a "false" reading. Light sandpaper and alchohol over the strips should clean them well. Another possibility, is if you have a mixed load, ie..towels, socks, jeans , if a sock or something light keeps hitting the strips, the dryer thinks the whole load is dry (it doesn't know there are different thing in there) Try keeping loads similar when using auto dry.
Mar 14, 2009 | Roper REX3614KW Electric Dryer
Roper Dryer model # RED4405Q shutting off
The motor may be getting hot due to bad rolers idler or glide. You need to take the machine apart and oil it. While you have it broken down you may want to turn the motor and see if it is stiff. The motor can be oiled but it is tricky. there are no oil ports you must make some. I use zoomspout oiler from ace hardware. Its high temp resistant formula and viscosity is perfect for dryers and HVAC needs.
75ddae3.jpgI have various essays on accessing these machines and diagnosis HERE
Mar 02, 2009 | Roper REX4634KQ Electric Dryer
Turns off during cycle
Motor is getting hot and shutting down. Probably have to replace motor or clean it.
Mar 26, 2008 | Roper REX4634KQ Electric Dryer
Roper REX4634KQ Electric Dryer Logo
703 people viewed this question
Top Roper Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Roper Dryer Expert? Answer questions, earn points and help others
