How to remove ink cartridge for hp 4150 printer?
  • 57 Answers
Hi there
step #0
Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
Step #12Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer. Step #23Press the change cartridge button. It is at the top of the printer next to the power button. Step #34Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process. Step#45#4Recycle the empty inkjet cartridge or have it refilled at an ink refilling center. Step #56Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed. Step #67Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door. thanks Hamedo
Posted on Nov 22, 2008
  • 521 Answers
SOURCE: my hp photosmart 2575 says
open the front cover the cartriges will come in the centre position where you can remove the cartridges check which cartridge is on your right side remove and clean the brown dotted circuit on both the printer and cartridge with the tissue paper .insert it back in the proper position and then check if the same problem then remove and replace the cartride printer will work properly.thanks
Posted on Aug 14, 2008
  • 7 Answers
SOURCE: Replacing ink cartridge(s) in my HP Photosmart C4280 All-in-One
had the same problem
I just kept putting it in and taking it out until the msg stopped.
also sometimes when you see this msg you can push the ok button and the printer will go to correct mode.
Posted on May 27, 2009
  • 111 Answers
SOURCE: HP Photosmart 2575 printer - ink cartridge problem
Is this a Hp cartridge or a cheaper brand?
I got this error myself too with cheaper cartridges.
You cal solvo this error by buying the original Hp cartridges
Posted on Apr 13, 2010
SOURCE: Keep getting display check and remove cartridges,I
Clean the golden contacts on the ink cartridge and in the cartridge cradle using a soft tissue.
Posted on Nov 08, 2010
  • 544 Answers
SOURCE: My c4180 printer says Ink cartridge problem.
If the color cartridge contacts are clean and there is stil ink in the cartridge.
What you could try is to remove both ink cartridges.
Close cover and turn off printer and unplug the printer.
Wait at least 15 minutes for the printer to reset to clear memory.
Plug the printer back in and turn on and install the ink cartridges.
If you cartridge is not empty and has not expired.
You may call HP and ask for a free replacement.
Posted on Jan 09, 2011
Directions for inserting ink cartridges
Replacing the Ink Cartridges for Deskjet 6940 and 6980 ...
support.hp.com/us-en/document/c00569593
Selecting the correct print cartridge, and removing and installing print cartridges. ... Damage may occur to the HP Deskjet printer if the print cartridges are not docked ...print cartridges, or continue to the sections below for detailed instructions.
Replacing a Cartridge - HP Deskjet 2540 All-in-One Printer
www8.hp.com/.../printers.../replace-ink...toner/.../replac...
Hewlett?PackardLearn how to replace a cartridge in the HP Deskjet 2540 All-in-One printer.
Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ...
? 3:56
https://www.youtube.com/watch?v=oJVYTXaI6e4
Jul 11, 2014 - Uploaded by HP Printer Support
The HP Instant Ink program is only available in the following countries - United ... ... Replacing a Cartridge - HP Envy 4500 e-All-in-One Printer ... HP ENVY 4500 WIRELESS SCANNERCOPIER REVIEW - Duration: 13:52.
Jan 16, 2016 | HP Office Equipment & Supplies
I have replaced black ink on a hp deskjet 960c and the red light keeps flashing
I see you replaced the Black in on your HP printer but the light keeps on blinking still.
Make sure that you remove the silicon film from the ink cartridge before installing in the printer, if that file is not removed the contact to the printers ink will not detect the ink cartridge at all.
Also try to remove all the ink cartridges and install all of them at the same time , this is to reset the printer from detecting all the printer ink cartridges.
I hope this helps
Oct 26, 2011 | HP DeskJet 960c InkJet Printer
Cartridge error,refer to devise documentation to troubleshoot
Hello
Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridge and use a clean, lint-free, dry cloth to gently wipe the contacts.
Wipe from the top of the contact to the bottom. Do this for each contact.
Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
Turn on the HP printer, open the cover and remove both the black and color cartridge. Close the cover.
Remove the power cord from the outlet and disconnect the cables running to the computer and/or router. Wait one minute, and then plug in the power cord and then the cables.
Open the cover and install the black and color ink cartridges. Turn the printer on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, you will need to buy new ink cartridges. Office Max or Wal-Mart have ink cartridges for almost every model of HP Deskjet, Photosmart and Officejet printers.
Jun 10, 2011 | HP Officejet 5610 All-In-One InkJet...
Cartridse error
If you see a message saying that you have an incorrect ink cartridge, a flashing cartridge light meaning a bad color cartridge or you are told to remove the color cartridge, you should follow these steps to correct the problem if you are sure you have installed the correct color ink cartridge.
Instructions
Reinstall the ink cartridge
1. Turn on the printer and open the cover where the ink cartridge is located. Remove the cartridge.
2. Place the ink cartridge back in the carriage. Close the cover. Turn the printer off for a minute.
3. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Wipe down the cartridge contacts
2. Remove the cartridge an use a clean, lint-free, dry cloth to gently wipe the contacts.
3. Wipe from the top of the contact to the bottom. Do this for each contact.
4. Place the HP ink cartridge back in the carriage. Turn the printer off for a minute.
5. Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, continue reading.
Reset the Officejet printer
1. Turn on the HP printer.
2. Unplug the power cord from the back of the printer and wait one minute.
3. Plug the power cord back into the printer. Press the on button and hold until printer turns on.
4. Print a test page to see if this has fixed the problem. If not, you will need to buy a new color ink unit.
Jun 04, 2011 | HP Officejet 5610 All-In-One InkJet...
My c4180 printer says Ink cartridge problem. Remove and check colour cartridge. Cant get message to go away. I use original Hp ink cartridges
Jan 09, 2011 | HP PhotoSmart C4180 All-in-One Color...
HOw to install ink cartridge on HP Photosmart7760
Install the ink cartridges.
  1. Turn on the printer.
  2. Lift the top cover.
  3. Open both ink cartridge cradle latches by pulling each latch forward and then up.
  4. Pull the pink pull-tab to remove the clear tape from each ink cartridge. Do not touch or remove the copper contacts.
  5. Insert the HP #57 tri-color ink cartridge in the left stall. Insert the HP #58 photo ink cartridge in the right stall.
  6. Close both ink cartridge cradle latches by pushing down on each latch until it snaps into place.
  7. Close the top cover and press the OK button to print a calibration page. This verifies that the print cartridges are installed correctly.
Sep 13, 2009 | HP PhotoSmart 7760 InkJet Printer
HP C7280 Printer not priting wirelessly.
Solution Replace the indicated ink cartridge(s), or press OK on the control panel to continue. HP recommends the use of genuine HP ink cartridges. Genuine HP ink cartridges are designed and tested with HP printers to help produce great results, time after time.
NOTE: HP cannot guarantee the quality or reliability of non-HP ink. Printer service or repairs required as a result of printer failure or damage due to the use of non-HP ink will not be covered under warranty. Follow these steps to replace the depleted HP ink cartridge(s). Step one: Replace the indicated cartridge(s)
  1. Make sure the HP All-in-One is turned on.
    NOTE: The Attention light blinks when the product is turned on.
  2. Open the access door by lifting from the front center of the HP All-in-One, until the door locks into place. Figure 1: Opening the access door c01079714.jpg
  3. Squeeze the bottom of the latch below the ink cartridge to replace, and then lift the latch.
    • To replace the black ink cartridge, lift the latch on the far left.
    • To replace one of the five color ink cartridges, such as yellow, light cyan (blue), cyan, light magenta (pink), or magenta, lift the appropriate latch in the center area.
    Figure 2: Lifting the latch c01079715.jpg 1 - Ink cartridge latch for the black ink cartridge 2 - Ink cartridge latches for the color ink cartridges
  4. Pull the ink cartridge towards you out of its slot to remove it. Figure 3: Removing the ink cartridge c01079716.jpg
  5. Remove the new ink cartridge from its packaging.
  6. Holding the new ink cartridge by the handle, push the ink cartridge into the empty slot. Match the color and pattern of the ink cartridge to the color and pattern on the print carriage. Figure 4: Inserting the new cartridge c01079717.jpg
  8. Close the access door. Figure 5: Closing the access door c01079719.jpg
Step two: Align the new ink cartridge(s)
  1. Make sure paper is loaded in the input tray, and then press the OK button. The HP All-in-One prints the alignment page, aligns the printhead, and initializes the ink cartridges. This takes approximately 5 minutes. CAUTION: Do not disconnect or turn off the HP All-in-One during this time. You may hear the HP All-in-One making noises.
  2. Check the display for status, and then press the OK button. Recycle or discard the alignment page.
Cause The original HP ink in the indicated ink cartridge(s) has been depleted.
May 24, 2009 | HP Photosmart C7280 Laser Printer
Dial says to remove cartridges and check. Have replaced cartridge
After cleaning cartridges and replacing refilled black ink, I removed blck ink and replaced with HP 58 photo ink. this aborted the "check cartridges freeze". I still cannot align cartridges after removing #58 and replacing with new HP 57. the operation starts but will not complete.
Any suggestions on how to align cartridges?
dunbarj730
May 02, 2009 | HP PSC 2210 All-In-One InkJet Printer
Problem with refilled HP 27 cartridge
remove some ink from the cartridge and clean the contact point of the cartridge and inside the printer, then hold the cartridge. when the cartridge not drop ink fix the in the printer
Feb 27, 2009 | HP Printer Cartridges (Complete List): ,...
259 people viewed this question
jasbo
jasbo
