Is the audio technica at2020 a sealed unit - Audio Players & Recorders
No it's not a sealed mic... there are three Philips head screws under the label ring just below the pop screen. You can either peel up the ring and loose the Audio Technica logo and markings or, as I did, simply use a razor blade to cut out around the screw holes.
After opening your mic you can GENTLY peel the foam from the condenser film to boost performance and response but only if you have a very good pop filter.
Justin
Posted on Dec 25, 2008
I just bought an audio technica at2020 cardioid condenser mic its the 20 series and i cant figure out how to get it to work on my toshiba laptop
Unlike 'Dynamic' microphones all condenser microphones require some sort of power supply to make them work. Sometimes this can be by way of an internal battery but many of them work on an external 'phantom' power supply.
I am not familiar with the exact model number you quote but AT make 2 types of AT2020 condenser microphone.
1) If your AT microphone is fitted with a USB plug then you can connect it directly to the USB socket on your computer, which will provide it with the power that it needs to make it work. The USB bus should automatically recognise the microphone and allocate an audio channel to it but you may still have to select this device as your input source in your recording program. How you do this will differ from one program to another.
2) However if the microphone is fitted with a standard jack-plug then it will not work by you just plugging it into your computer microphone input socket as this is not powered. You will need a separate 48volt DC power supply to power the microphone.
You will almost certainly also need some sort of microphone pre-amplifier to match the output voltage and impedance (electrical resistance) of the microphone to the levels required by your audio input socket on your computer.
Probably the best way to achieve both of these requirements at lowest cost would be to purchase a small audio mixer with a phantom power option such as the Phonic AM220 http://cpc.farnell.com/phonic/am220/mixing-console-am220/dp/DP29303
WARNING - most audio mixers only have one on/off switch for phantom, power - thus the power is either on or off for ALL channels. Some other devices - like radio microphones, keyboards and electric guitars may be damaged by having 48v dc current supplied to them
Here is a link to the technical specs sheet for the AT2020 http://www.audio-technica.com/cms/resource_library/literature/49f63e6efc082082/at2020_english.pdf
More information is available here http://www.dolphinmusic.co.uk/article/40-why-do-i-need-a-microphone-preamp-.html
Jan 28, 2011 | Audio Technica Audio-Technica AT2020 -...
I dropped the audio technica at2020 mic and when i record it doesn't pick anything
Most likely it could be two things either a connection is not getting current anymore. my 2020s have went through hell and no problems. or the other suggestion is that your phantom power is not being sent from your preamp to the microphone (not to make you feel stupid, just a reoccuring problem on this board.)
Good Luck, Cody J.
Dec 17, 2010 | Audio Technica Audio-Technica AT2020 -...
What drivers can i download to make my at2020 usb work with windows vista
i hav just bought a at2020 mic and i tried recording bought it's not workin for my dell inspiron i forgot the model anyway it's running on windows 7 so please help me out am screwed with this ****
Mar 13, 2010 | Audio Technica Audio-Technica AT2020 -...
Audio-Technica AT2020 low audio output
Pins 2&3 are the correct ones to use for checking the voice coil. Pin 1 is chassis ground and should always read infinite resistance to the other two.
That microphone has an impedance of 100 ohms, so if you are reading 30 ohms you clearly have a problem with the voice coil.
Good Luck
BB
May 16, 2009 | Audio Technica Audio-Technica AT2020...
AT2020 Not showing in recording software
find the drivers online then restart your computer. hook up the mic then restart again
Feb 21, 2009 | Audio Technica Audio-Technica AT2020 -...
59 people viewed this question
 Grubhead
Grubhead
