Question about Nikon D700 Digital Camera
Camera will not turn on
I charged the battery and reinserted it. I also removed the memory card and reinserted it. I reinserted both the correct way. When I turn the camera on, nothing happens.
  • robmmprod Nov 22, 2008
    Thank you. It appears that the battery and/or the CF card didn't have a complete connection because I kept taking them both out and putting them back in and it finally started working again.
  • 71 Answers
Check lens contact. Remove lens, clean contacts, but them back and try again.
Posted on Nov 22, 2008
Canon Powershot A3400 won't turn on
Hi Jessie,
I looked at the troubleshooting section of the Canon Powershot A3400 Is manual and it suggested the following:
  • Confirm that your are using the correct type of battery, and that there is sufficient charge (p. 163). Sounds like you did this.
  • Confirm that the battery is inserted facing the correct way (p.17)
  • Confirm that the memory card/battery cover is fully closed (p.18)
  • Dirty battery terminals reduce battery performance. Try cleaning the terminals with a cotton swab and reinserting the battery a few times.
The manual also said that the batteries can deplete quickly in low temperatures. "Try warming the batteries a little by putting them in your pocket, for example, ensuring that the terminals do not touch any metal objects."
You can find the manual online here: http://aggregate.org/CACS/psa4000is-a3400is-a2400is-a2300-a1300-a810-cug-c-en.pdf
I also uploaded the manual to FixYa's Canon Powershot A3400 Is Product Page:http://www.fixya.com/support/p2861926-canon_powershot_a3400_16_megapixel_16_mp
Lastly, you can also check out Canon's Service & Support page for the camera: http://www.usa.canon.com/cusa/support/consumer/digital_cameras/powershot_a_series/powershot_a3400_is#ServiceAndSupport
Best of luck!
Dec 20, 2013 | Canon Powershot A3400 Is 16 Megapixel...
Cannot format my memory card.
Try with a different Memory Card
Try the same Memory card with another compatible device to confirm whether the issue is with the Card or Camera. Please make sure that you're using fully charged battery pack.
Remove the battery and reinsert after 1 minute.
Reset the camera by following the reset procedure from the manual of the Camera.
If the issue persists again, service is required
Dec 31, 2010 | Kodak EasyShare C743 Digital Camera
Won't turn turn on. A red and green light comes on, but nothing on the screen.
Step one: Reset the camera
  1. If you have an optional memory card installed, remove it.
    NOTE: Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.
  2. Remove all batteries from the camera for at least five seconds.
  3. Reinsert the batteries and close the Battery/Memory card door.
  4. After verifying that the camera works without an optional memory card, reinsert the card if you removed one in Step 2.
Try to turn the camera on. If it now works properly, the camera experienced a temporary electrical problem and should now work properly.
  • If the issue is resolved , you do not need to continue with the rest of the instructions in this document.
  • If the is not resolved , continue with the next step.
Step two: Check for damage or corrosion on the batteries
  1. Open the Battery/Memory card door on the camera.
  2. Remove the batteries.
  3. If the batteries are damaged or show corrosion, replace the batteries.
Step three: Recharge the batteries
  1. Recharge the batteries or replace the batteries if they are damaged or will not charge.
  2. Try turning the camera on after the batteries are fully charged or have been replaced.
Step five: Ensure the batteries are installed correctly
  1. Re-insert the batteries correctly into the camera by referring to the image on the Battery/Memory card door for proper battery placement.
  2. Try turning the camera on.
Step six: Turn on the camera without the memory card
  2. Remove the batteries and optional memory card from the camera.
  3. Wait 15 seconds.
  4. Re-insert the batteries into the camera, but not the memory card.
  5. Try turning the camera on.
    • If the issue is resolved , format the memory card in the camera and then you do not need to continue with the rest of the instructions in this document.
    WARNING: Formatting the memory card in the camera will erase any images stored on the memory card. To avoid losing the images on the memory card, first save the images to a computer or another disk.
Step seven: Service the camera If the camera still will not turn on, service the camera.
Mar 04, 2010 | HP Photosmart E327 Digital Camera
Sound on the zoomlens and writing error # 45
To remove the error, follow the instruction.
1) Turn OFF the camera.
2) Remove the memory card from your camera.
3) Reinsert the memory card, then push down on the card until you hear a click. check the memory card is firmly fitted in your camera.
4) Turn on your camera.
This will clear the error. For noise install a fully charged battery or new battery in your camera.
Rating the solution in highly appreciated.. Good Luck
Mar 02, 2010 | Kodak EasyShare Z700 Digital Camera
Camera wont turn on
  1. Step one: Reset the camera
    1. If you have an optional memory card installed, remove it. (Although removing an optional memory card is not necessary for performing the reset, it eliminates the memory card as a possible cause of the problem.)
    2. Remove all power sources (batteries and AC power) from the camera for at least 5 seconds.
    3. Reinsert the batteries and close the Battery/Memory card door and/or reconnect the HP AC power adapter to the camera.
    4. After verifying that the camera works without an optional memory card, reinsert the card, if you have one.
    Step four: Ensure the batteries are installed correctly
    Step five: Turn on the camera without the memory card
    3. Wait 15 seconds.
    Step six: Connect the camera to the optional AC power supply
    1. Connect the camera to the optional AC power supply. Ensure that the AC power supply is connected to a working power outlet.
    Step seven: Service the camera If the camera still will not turn on, service the camera. Cause The following conditions can cause the camera to not turn on:
    • Improperly formatted memory card - memory cards should be formatted in the camera they are going to be used in
    • Corrupt images on the memory card
    • More than 300 pictures on a memory card
    • Damaged batteries
    • Dead batteries
    • Incorrectly installed batteries
    • Damaged camera
Jul 19, 2009 | Leica C-Lux 1 Digital Camera
My Photosmart E327 won't switch on.
Resetting the camera
If your camera does not respond when you press any
buttons, try resetting the camera as follows:
1. Turn off the camera.
2. If you have an optional memory card installed, remove it.
3. Remove the batteries from the camera for 5 to 10
seconds.
4. Reinsert the batteries and close the Battery/Memory card
door.
5. After verifying that the camera works without an optional
memory card, turn off the camera and reinsert the card if
you have one.
Mar 03, 2009 | HP Photosmart E327 Digital Camera
Samsung s1030 will not retract lense and bleeps 3 times then no response - batteries are fully charged
Try hard reset . Remove the batteries and insert new batteries . Sometimes this may work
Another chance is that lens is struck
* Carefully inspect around it for dirt or debris
* If you see any dirt or debris around the lens, use canned air to gently blow it away
* After removing dirt and debris, turn the camera on and off
This should work.
Try this alternate solution (got information from HP )
  • Turn off the camera, if possible.
  • If an SD memory card is installed, remove the card.
  • Remove power from the camera as described below:
  1. If you are using only batteries for power, open the battery/memory card door and remove both batteries.
  2. If you are using only the AC power adapter, disconnect it from the camera.
  3. If you are using both batteries and the AC power adapter, remove both batteries and the power adapter.
  • Wait for 15 seconds. Then reinsert the batteries and close the battery/memory card door or reconnect the AC power adapter to the camera. If you are using both batteries and AC power, try each method separately.
  • Turn the camera on and off. If the lens does not retract correctly or the camera does not turn on,
You need to take to service center .
Thanks for using FIxya
SAM ANDERSON
Dec 09, 2008 | Samsung Cameras
Nikon D40X quit working - memory card access lamp flashing??
As per the Samsung digimax range, internal memory seems to be faulty. Insert an external memory card and try to power up the camera.....
Oct 08, 2008 | Sony Cyber-shot DSC-S730 Digital Camera
HP Photosmart M627
Try first removing battery and putting back.
Aug 01, 2008 | HP PhotoSmart M627 Digital Camera
Canon eos digital camera, display err 2 in window. will not take any photos. The battery is fully charged and istalled correctly.
ERR 02 usually indicates a problem with reading the memory card. Remove and reinsert the memory card (check the pins in the camera with a strong light to make sure no pins are bent). If that doesn't work, try another memory card. If it still doesn't work, the camera may need to be serviced.
Jul 24, 2008 | Canon Cameras
Nikon D700 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Are you a Nikon Camera Expert? Answer questions, earn points and help others
