Question about Freezers
Need correct setting for 30 yr old upright Kenmore freezer
Just defrosted freezer.
forgot to check setting before turning off.
what is the correct number for max efficiency?
    Sergeant:
    Champion:
  • 291 Answers
Depend on the type of control you have on your box ,,,, best is if it shows 1-7 set it on 3-4 ,, if it has letters set it on C ,,, eather way set the control on mid-point and it will work fine.
Larry
Posted on Nov 25, 2008
I accidently turned off freezer.How do i turn it back on?
Turn the interior temperature control back on by setting at approx halfway between "off" and "coldest". (Make certain the branch circuit is hot - you should hear the compressor turn on when you set the control, possible an interior light will come on as well).
If the freezer does not run, check to see if you accidiently pulled the flash defrost plnger (if equipped). (See age 8 in your manual).
If you don't have a manual, you can download one here:
ShopYourWay KENMORE Upright Freezer ShopYourWay
(This is for Kenmore model 253.23024-101 or -102).
Apr 22, 2014 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Defroster get red hot
Kenmore Frostless Upright freezer model# 23971. The alarm sounded, all contents in freezer is frozen solid. We turned the alarm off, but the red light continues to blink. How do you reset the alarm and stop the red light from flashing? It has been 3 days now and every time we have check to see if the contents has started to defrost, there is no signs of defrosting, everything inside of the freezer remains frozen solid.
Sep 01, 2010 | Kenmore Freezer 20.6 cu. ft. Manual...
Setting
4 in winter 5 in summer depending on how often the door is opened per day i would set it at 5 all yr round
Jul 04, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Freezer will not come back on
First check the thermostat. It might have gotten turned up when you were cleaning it. If the thermostat is set correctly, the problem might be the defrost timer. It controls cycles the compressor off periodically to turn on the defrost heater. There are wires connecting it to the compressor. It is a little box, a bit smaller than a pack of cigarettes with about 3 to 4 wires connected to it. On one side is a hole with a plastic cam. The cam can be turned with a coin or a flat screwdriver. If it is turned about an quarter turn, it should click. If the compressor turns on after you turned the cam, then the problem is the defrost timer.
Jul 01, 2010 | Frigidaire 14 cu. ft. / 396 liter Upright...
I have a Kenmore Upright Freezer. I need to
I unplug mine and let it take several days. You break a line or punch a hole in a line and the freezer will be ruined. Just let it thaw out on its own to prevent damage.
Feb 10, 2010 | Freezers
Your best bet is to start in the middle. Guesstimate and let it run. The test is to see if water freezes solid in 6-8 hours. If not, you can turn about 1/4 turn or less. Then you can try hamburger meat which a lower freezing temp and see if it gets solid. Your perishable items should be put somewhere else until you are ready. At least the water frozen will keep the meat safe from bacteria growth or spoilage. Let me know how you do.
Feb 17, 2009 | Frigidaire Upright Freezer FFU12F2H
In addition to the popping noise/coils are froze with orignal
turns out the coils were not defrosting or at best working intermittently. I defrosted the coils and ordered a defrost timer the old timer continued to pop from intermittently.I replaced the defrost timer
and it quit popping and noew the freezer works fine temps range between 9 degrees F and
14 degrees f.
Jan 19, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Defrost problem
If a defrost system is not working you will get, either no cool or frost build up.
Aug 07, 2017 | Magic Chef 19.6 cu. ft. / 555 liter...
Freezer does not work
almost certainly a problem with the defrost timer - just replace complete. doesn't matter what position you set timer to when replaced
Sep 06, 2008 | Frigidaire 12 cu. ft. / 340 liter Upright...
Kenmore upright older freezer coils frost up
the tech was telling you to put it in defrost and if ater the time you didn't hear the click the defrost timer is defective but like you are describing the defrost thermostat (bimetal) could be bad. here's a simple test (if your handy with a screwdriver) just dissasemble the panel and you will see the coil and defrost heater. if your handy with a voltmeter (please disconnect power first!) locate the two wires to the defrost element put the meter in "audible" mode and check for continuity on the defrost heater if you hear a beep it's good if it dosen't beep it's bad just replace heater w/ bimetal and your ready 2 go! email me @ hvac.tech7872pr@gmail if you have any questions
Jun 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
60 people viewed this question
Top Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
