Question about Maytag Performa PAV2200
Maytag Performa Plus-light out and dryer won't come on.
I had dried one load of clothes and was getting ready to put in another load when I noticed that the light inside was out. I went ahead and put the wet clothes in the dryer thinking it was only the light that had blown out but when I tried to start the dryer....nothing happened.
Thanks.
Yuvon
p.s. I don't find our product listed here. We have a Maytag Performa Plus Model# PYE4500AYW. I've selected the PAV2200 since ours wasn't listed. Thanks.
  • Kim Satterly Burton Feb 02, 2009
    I have Maytag Performa Dryer PYE4500ayQ I had put a load of clothes in to dry and it was working. When i went back later to put another load in that i just washed i opened the dryer door and the first load had only paprtially dryed. The dryer would not come back on and the light was not on. The electric breaker was on the dryer just would not work.. Please help me with this, as i love my dryer.
    Kim kimbo924@hotmail.com
  • buckwasp Feb 04, 2009
    If anyone has an aswer to the problem that the three of us are having then please let us know asap. One minute the dryer was running great and the next it won't do anything. Light is out and doesn't attempt to do anything. Thanks.
    Buck
    buckwasp@aol.com
    636-485-5803
SOURCE: maytag dryer won't heat up
i am having the exact same problem with this model as well just happened 4 days ago.
Posted on May 03, 2008
  • 21 Answers
SOURCE: Maytag Performa Dryer Mod PYE4500AYW Has power but will not start
check your door switch. if it is ok, get this kit part number LA-1053. This is a very common solution for this dryer. the thermostat fix kit will contain a thermostat and two other parts....one is for gas and the other is for electric. just read the instructions and you will know what one is for your dryer. these parts can be accessed by lifting the lid and looking to the rear of the cabinet past the drum. MAKE SURE TO UNPLUG THE DRYER FIRST
Posted on Dec 29, 2008
SOURCE: replace belt on pye4500ayw
i lifted up the top and unscrewed the front of my maytag dyer pye4500ayw a very thin belt was at the bottom. who do i replace this belt and where does it go?
Posted on Jul 10, 2009
  • 41 Answers
SOURCE: maytag performa PAV2200 - cold water fill does not
Try removing the cold water supply hose at the back of the machine. There are usualy screnes in the connection inside the water inlet valve that you can pull out. Look inside the threaded fitting on the machine. Clean and replace it. If that is not it. Open the cold water valve and make sure your home water supply flows through the hose. Check the wires at the water inlet valve on the cold side for voltage (inside the machine) when trying to operate in cold water fill cycle. You can also run it on hot and check the voltage for comparison if you aren't sure of what voltage you are looking to have. If it powers up on the cold fill, then the inlet valve is bad and needs replaced. Be cautious as there is AC power that can kill when testing.
Posted on Aug 04, 2009
dwrooker
  • 6 Answers
SOURCE: maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Posted on Oct 06, 2009
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
My Maytag Performa dryer is taking 2 and sometimes 3 cycles to dry clothes. Suggestions as to why?
Most of the time the dryer blower wheel part number 53-0106 gets loose and and cause this problem. I fixed one just the other day.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 24, 2010 | Maytag Performa PAV2200
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Dryer not heating as it should. Gets warm, but takes several cycles to dry clothes
Could be 2 things... either your heat source is out of repair or your vent is blocked. Since you say it only gets warm I'll assume the problem is with the gas coils inside the unit. These parts are replaceable
May 12, 2009 | Maytag Dryers
Electric drier takes 2 to 3 cycles to dry one normal size load
Have you tried cleaning the actual inside of the drier?
When you use drier sheets the wax on the sheets melts onto your clothes and makes them soft, but the wax often gets stuck in the holes of the drier making it incapable of drying the clothes in one load. Try scrubbing the inside of your drier with some hot water.
Apr 13, 2009 | Roper REX3614KW Electric Dryer
My Performa dryer stopped working.
Unplug the dryer.
Replace the thermal fuse and high limit switch located at the heater element.
The parts come as a set.
Raise the top lid of the dryer. The parts are at the back left side.
Mar 10, 2009 | Maytag Performa PAV2200
Spinning fast and furious, just doesn't wring clothes dry
It sounds like you need a water pump!
See if it's pumping water next time you do load by looking at the discharge hose going to the drainage pipe and get back to me!
jack
Feb 21, 2009 | Maytag Performa PAV2200
Dryer doesn't work.
Dry will not start, light is off. Power is on and working fine to dryer - is there a reset button?
Performa oversized Capacity Plus Model #PYE3360AYW .
Jan 18, 2009 | Maytag MAV3905EWW 13 Cycle Washer
Maytag performa dryer takes a long time to dry clothes on auto
What you have is a obstructed dryer vent. If you remove the vent hose from the unit you will see moisture inside it. This is why your unit isn't drying. If the heater has no air flow the overload is tripped. Check your vent for any blockage most of the problem is at the outside end of your vent. there's a flap or chicken wire you may find the obstruction there. Or you can use a leaf blower connect it to the inside vent, cover the outside vent with pantyhose. ( so you don't get lint allover your yard ) and you can clear your like that way. Good luck hope this helps
Jan 10, 2009 | Maytag PYE2300AY Electric Dryer
My Maytag Performa Oversize Capacity Dryer stopped working without a warning. It dried a load on the week-end without a problem. I put a load in on Wednesday, turned the dail to on
but there was no movement or sound.
HELP!
Jul 02, 2008 | Dryers
Washing Machines Logo
62 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
