Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi WD 52525 & PS 3
I have owned and enjoyed my Mitsubishi WD 52525 for 3 years now, and I just got a PS 3 for Christmas. There is an HDMI input on the rear panel of this TV, but for the life of me I cannot figure out how to select/activate it! I have tried everything, but there is no way to select the HDMI input on the device menu. Can somebody please help me??
  • 2 more comments
  • Ben Creighton Dec 28, 2006
    JD318, thank you SO MUCH!! I have been fooling with this d@mn thing for 3 days, and now I'm embarrassed that it was so easy, but still thankful to have it working. I've never needed to use NetCommand before, so even though I've had the TV for 3 years, I found myself unable to get the PS3 set up. Now it's working perfectly, and I can play Resistance : Fall of Man in 108i HD!
    Thank you again,
    Ben
  • Anonymous Jan 14, 2008
    i have the same problem but i cannot use the a/v (red white and yellow) because the ps3 was pre programed to hdmi before i got it so... i cant switch it to analog to get to the hdmi...confused yet?
  • Anonymous Nov 08, 2008
    thanks alot!
  • hoffmas Jan 18, 2009
    I'm having the same problem. I've connected the ps3 to the tv via the hdmi, but when I change the ps3 output to hdmi and then go to monlink, all I get is the blue screen that shows there being no input on that device.
First make sure your hdmi cable is connected from the PS3 to the TV. Then go to netcommand, review, and make sure "monlink" is checked, click next, and finish. Select "monlink" from your device manager and turn on your PS3. If the screen is blue, go to the next step. Connect the PS3 via regular a/v cables to the front panel "input-3". Create a net-command device for input-3 as well. Switch to the input-3 device you created and turn on your PS3. Choose display settings, and change the settings to HDMI. Then click change. You'll have 30 seconds to hit device manager, change the device to "monlink", and let the PS3 unit know the setting has worked. From there you can configure. Good luck!
Posted on Dec 28, 2006
I have a 4 year old Mitsubishi WD-57831. Lately, when connected to my cable DVR via a HDMI, the picture flashes on and off and some stations don't come in at all. I changed the cable box 4 times, changed...
I have run into this issue alot. I believe its because of a older version of HDMI 1.1. Quick solution is to hookup the cable box with component cables(yprpb) to utilize the HD picture still and then do some research to see if Mitsubishi has a firmware update on your particular model.
Aug 18, 2010 | Mitsubishi WD-52525 52" Rear Projection...
How to conect dvd player to my mitsubishi tv model WD-52525
You have several options with your TV depending on your DVD player. The best quality video will be achieved with an HDMI cable if your DVD player has an HDMI output. Next best would be to use a component video connection which consists of 3 RCA cables for video and two for audio. The third option is S video (round connector with pins inside)
Dec 05, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Our Mitsubishi WD 52525 goes to blue screen and shuts off.
It sounds like you TV is overheating and the video is suffering and the lamp is overheating as well. Also, if your TV is over 2-3 years old, the mirrors (behind and below the big front screen) desperately need to be cleaned. Clean all filters and fans as well. (Look on side and behind the unit). Is the TV in a "hot" environment and/or dirty environment? DLP TV's are NOT sealed units. They need to be cleaned every few years to work well to have a good, clear, bright picture.
Jun 24, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Normal 0 The Mitsubishi WD-52525 has a serious capacitor problem as discussed in this forum overseen by a Mitsubishi certified repair technician: http://www.hometheatershack.com/forums/mitsubishi/11703-problem-mitsubishi-wd-52525-scrambled-picture-no-picture-2.html. There has been a worldwide problem in computers and TVs over thepast several years with faulty electrolytic capacitors (from Taiwan) thatdecay, dry out, swell and die. The power supply is often the firstcomponent to go bad, but other systems also degrade over time. As theforum explains , this problem is widespread in these sets causing multipletypes of display problems after several years of use. On my set, I also got a blue screen with a lighter blue ball in the middle. Mitsubishi is awareof the problem and will cover most of the cost of repairing the chassis, evenyears out of warranty, but apparently ONLY if you get an estimate from aMitsubishi certified repair station and contact their customer support BEFOREdoing any work on the set. I just followed the recommended procedure onthat forum and Mitsubishi is covering half the cost of my $700+ repair when my3+ year-old set recently died and showed only this blue screen on all inputs.
Mar 31, 2009 | Mitsubishi WD-52525 52" Rear Projection...
4yr old Mitsubishi DL 52525, HDMI input vide problem
Are you sure its the TV and not the source? Are you sure its only the HDMI port on the TV? The only reason why you must HDMI is to get 1080p and your TV doesn't support 1080p. Its supports up to 1080i. Your TV has a native resolution of 720p which means it can accept a 720p image and not need to scale it, so the picture will look the best at 720p but will support 1080i. I would use component cables to connect your sources and set them to output 720p.
Mar 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi with monlink new DVD player HDMI How to make work
the monolink is the hdmi on the mitsubishi. it acceps up to 1080i
Dec 16, 2008 | Mitsubishi WD-52525 52" Rear Projection...
The blinking status & Time LED lights
DM board n/l/a ....
the only and best way to fix this TV ! ! !
you need to replaced the chassis !!!!!!!!!!!!!!!!!
Nov 20, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525
Good Day;
A service manual will not help, but look for at other advice given and please respond.
Good Luck, big IRISH. PS: If again you need more info , come back.
Aug 30, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 - Picture is not horizontally level
You would need the service manual for that adjustment. It is outlined in the service manual on how to adjust the tilt. It is a mechanical adjustment. You can get the service manual emailed to you instantly after purchase at this link.
http://servicemanuals.vstore.ca/
Apr 18, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
717 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
