Question about NAD 712
NAD 7140 Have a NAD 7140 stereo receiver, about 20 years old. When unit is turned on, intermittently (every 3-6 seconds) lose sound. Sound returns for 3-6 seconds, then lost again. This is accompanied by a "soft clicking" noise within the unit. I opened up unit, unable to pinpoint source of clicking. This sympton happens regardless of source (CD, tuner).
  • Anonymous Mar 24, 2014
    CLICKING SEEMS TO BE COMING FROM BACK OF UNIT.The problem started just once in a while but now it is constant.
The clicking is the sound of a bad relay. A relay is an electrical switch that opens and closes under the control of another electrical circuit. There is no user solution for this. You'll have to take it to an electronics repair shop (~$150) or dump the whole unit.
Posted on Dec 19, 2008
I get static and distortion in Stereo mode.
if you are reffering to a radio fm receiver, the issue is the signal strength is too low.so the multiplex transmission cannot be correctly unscrambled.mono reduces the cross channel interference.
use a high gain 12 db or above external vhf antenna to solve this problem
Jul 29, 2014 | NAD 7140 Stereo Receiver With Phono Input
NAD 7140 input selector does not work
The selector chip is not working, either there is no B+ to the ic or the chip has malfunctioned or one of the surrounding components dead, for this type of problem a schematic will be needed to track the problem. try www.nad.com contact customer support and the technical department for additional help.
Jun 15, 2012 | NAD Audio Players & Recorders
Nad 7140 fm low frequency hum
This is probably a 60 cycle hum and the problem is more likely confined to the am/fm board, there is a bad ground due to poor solder joints, broken ground wire, an open capacitor, this may not be easy to find, but it is a start.
Apr 22, 2012 | NAD 7140 Stereo Receiver With Phono Input
NAD 7020e sudden volume drops, sudden distortion- intemittently
OK. I dont know the answer to your prob, but to let you konw that youre not in this alone, my amp used to occasionly lose considerable volume in one channel. this could be remedied by cracking the volume up to max for a half second or so. (Not a great solution!!) It has finally given up the ghost ...I have lost one channel and the doctor says it wont come back. Not only this but they claim that spares ceased to be sold back in the 90's. having said this I have enjoyed this amp for almost 20 years. I think its time to put it to pasture.
SNO
Apr 12, 2010 | NAD Audio Players & Recorders
My Stereo integrated hi fi amp is giving a crackle when output from certain devices - like a build up of static at intervals. It is quite old NAD amp - is this a sign of transistor failure, is it worth...
This sounds like you may have a lot of solder connections on the amp board and the power supply board to be resoldered. After a few years of using the unit they can get heat stressed and develop cracks in them. The sooner you get this fixed the better. NAD is a very good brand of stereo and in most cases they are well worth getting fixed. If the stereo is used for too long it can develope some component break downs that would cost much more money to repair.
Sometimes the static or crackle sound is just the volume control or other controls like the balance or teble or bass controls that just need to be cleaned with the proper type of electronic contact cleaner.
I hope this helps, have a nice holiday season,
Dave
Dec 13, 2008 | Audio Players & Recorders
NAD 7140
Hi okapi6
Use a 3.5mm stereo jack to RCA connector lead.
370a7a3.jpg Connect this to the AUX input on the back of the 7140, and away you go. Get the lead as an accessory from just about any electronics hobby store.
Dec 07, 2008 | NAD 712
Is there a reset button for the NAD Surround Sound Receiver T 751
The only reset that i know of is to unplug it for 15 to 20 minutes. Hope this helps.
Dec 03, 2008 | NAD T751 Receiver
Would like to know year of manufacture for Nad 7140 stereo receiver
Hi - You can download the manual by clicking the link underlined in blue below:
Nad 7140
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Sep 09, 2008 | NAD Audio Players & Recorders
Receiver (tuner) signal fade-out ---heat related
The main problem with the 7140 is that there are at least 3 versions that I am aware of. The varient is based upon the serial number. Can you post that here. I will look up the info for you. I have access to some NAD stuff. Post the part designations as well (Qxx) and I'll at least get you the exact part numbers etc.
Dan
Mar 23, 2008 | Audio Players & Recorders
Starting system cold, no sound for 2-3 minutes
Its not worth having it looked at. $100.00 for a new 400.00 unit? My unit is doing the same thing. Turn it on and 2 to 5 minutes later it may come on. Change to video 3 4 5 etc it stop again. Only works with a cold start. Something in the unit has failed and is heat related. My original Kenwood 20/20 recevier still works. Must be 40 years old. New products just last 5 to ten years max if your lucky.
Dec 17, 2006 | Kenwood VR-6070 Receiver
Open Questions:
See all NAD 712 Questions
NAD 712 Logo
725 people viewed this question
Top NAD Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a NAD Audio Player and Recorder Expert? Answer questions, earn points and help others
