Question about Amana PTH153B50AE Air Conditioner
Our heater blows cold air.........
We have proper 230v to mother board......don't know if there are any fuses in this unit......we have no manual......are there any in line fuses or limiters on the unit? we replaced the mother board last year because the unit wouldn't run at all (lightening) in our has worked since mother board was replaced
  • 1 more comment
  • bg453wire Nov 22, 2008
    when I had the mother board out......I didn't see any fuses (that looked like car fuses) on it.....but thanks for the effort
    vague? the proper voltage is there.....and the unit goes on and the fan blows but no heat comes out.......I don't know how to explain in more detail...........I noticed what looks to be a transformer under the mother board......I don't see that to be the problem as there is 230v at the mother board.......there appears to be a large capacitor like (tank shaped) unit behind the transformer looking object.......could that be bad or is there another fuse somewhere else or could the sensor that is attached to the fins on the front of the unit that goes to the thermostat dial be open all the time telling the mother board to keep the voltage off of the heating element?
    I see that by that on the initial post......but the heading (our heater blows cold air) I thought that was the title of this help me post.........sorry
    Problem Solver:
  • 25 Answers
Most boards have a small 3 or 5 amp fuse on the board it looks just like a car fuse. do not put in wrong size fuse it can allow damage to the board.
Posted on Nov 22, 2008
  • 1 more comment
  • cotillionsor Nov 22, 2008
    your description of a problem is very vauge. If we had more info on exactly what is happening we can better assist you.
    actually now that i read it again you did not even state a problem only asked about fuses
  • cotillionsor Nov 24, 2008
    oh good it sounds like your flames are not igniting. there are two kinds of ignitors. hot surface which you can see get cherry red and then the gas valve opens. or a spark ignitor that you can hear clicking repeatedly before gas valve opens. i believe your ignitor is bad or your gas valve is not opening to allow the ignitors to do the job. if you can tell me if you hear or see the ignitor working i can further advise. you may need a volt meter for further diagmnosis.
I have a Frigidaire FAM18HS2A and when I turn on the heater, sometimes it blows hot air but most of the time it blows cold air. what is wrong and can it be fixed
if your frigidaire is not a inverter,he doesn-t work at outside temperature down -5.if it is a inverter you don-t have enought freon .
Dec 18, 2013 | Frigidaire Heating & Cooling
Heater unit doesn't blow any air
If you have no air blowing out it sounds like the blower motor has quit
Dec 28, 2012 | 2005 Jaguar Vanden Plas
My 1993 Z28 camaro blows strong air but not cold in summer and defrost will not clean the windows. What could be the cause of this problem?
My Camaro's are all victoms of the air flow control vaulve. My 77 had a cable that phyisically opened and shut off air flowfrom the heat and cold side and operated as I moved it from cold to heat. Then they came out with Vacuum assisted air control units that when the rubber vaccum tube dehydraded, it would be stuck in what ever it was in last, say A/C, or if u had the heater on that day. You have either cables or air hoses that open and close certain doors under your dash according to where you place the enviromental control to. 9 times out of 10, that control mechinisim froze up, a plennum door could have broken off leaving that area always open and the heater is always off. Check the book, im not 100% but it may be all electronic in the 93's if so, first check your fuses. Also check the passenger floor board for dampness. If the passenger floor board is wet, then your heater core ruptured also. It's a mini radiator under the pass. side dash. But the real deal is the air vents that open and close according to your input are not moving at all, and if they are electronic well Don't rip the dash out, that is a pain to reinstall LOL, Best bet is to take it to the chevy house because if you get the book, u'll see theres quite a few moving parts and with old plastic and them dehydrating, you can easly brake a door control and make matters worse. Good luck.
Sep 18, 2012 | 1993 Chevrolet Camaro
1992 Dodge Dakota 2wd 3.9L V6 Air conditioning/Heater dosent blow? when i turn the air or the heat on i can hear the compressor kick on but it dosen't blow cold or hot? any help would be appreciated
Roger it sounds like the blower motor is not comming on. There is a resistor network located in the engine compartment on the passenger side mounted to the firewall, that controlls the blower motor. The connections may have corroted or the unit itself is bad. That was the first thing I had to relpace when I got my used 92 Dakota. There is also a 30 amp fuse in the fuse box under the dash board . If that is blown I would suspect the blower motor is seized up or just pulling too much power.
Nov 29, 2011 | 1992 Dodge Dakota
How to check fuses
check the water level in our radiator. If water level is low, it won't get to the heater core.
Nov 26, 2011 | 2003 Chrysler PT Cruiser
My 1999 Chevrolet Suburban heater and a/c switch not working properly. When I have my fron a/c unit on, it does not blow as cold as the back unit. It feels like it's blowing warm air like if the...
You are going to need to use a multimeter and have a professional test the relay voltages. This should probably only take an hour, make sure they have the proper electrical schematic for your vehicle year make and model.
Jun 30, 2011 | 1999 Chevrolet Suburban
Heater blows cold air ac blows warm air
Your problem is the air temp control blend door actuator is defective and not controlling temp u set. to change/access this part the dash assembly must be removed from the car.
Mar 24, 2009 | 1998 Ford Taurus
No heat
there is a main dryer fuse and a heater box fuse,the heater box fuse is the small bimetal fuse on the heater box,replace that and you should be ok,let me know how it goes-mike
Oct 12, 2008 | Zanussi TC7114W Electric Dryer
Mitsubishi MSH12TH heat pump air handler 110v
Wireing this type AC with the wrong voltage, will damage more than the circuit boards. I think the installer wil need to be responsible for the damage he created. The factory will also try to get out of the replacement because of the installers lack of know how.
Oct 20, 2007 | Mitsubishi Mr. Slim MXZ30TN Air...
Heating & Cooling Logo
572 people viewed this question
Top Amana Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Shehu Pro
Shehu Pro
Are you an Amana Heating and Cooling Expert? Answer questions, earn points and help others
