Question about Hitachi DZ-MV730A DVD Camcorder
How Do You turn It On
I just got mine for christmas and i dont have a manual and I cant turn it on and when i try to charge the battery the charge light doesnt lite up
0 characters
1 Points
NS-DCC5HB09 High Definition Flash Media Camcorder: mine wont turn on and i dont have a charger!!! Hel...
You should be able to recharge this unit by connecting to your PC and charging through your USB connection.
If your battery is faulty or unable to recharge, here's a replacement battery that's available:
Just about any AC to USB charger will work to recharge this unit, so if you have an iPod with the iPod wall charger, use the correct USB cable with the wall charger and you will be able to recharge the battery in the camcorder.
Hope this helps!
May 11, 2010 | Insignia NS-DCC5HB09 High Definition Flash...
No Power Using AC Power or Battery
I had this same camera. If you have a power fluctuation it can really damage the batteries. make sure it was not exposed to fluctuations
Jan 26, 2010 | Panasonic VDR-D100 DVD Camcorder
My Aiptek keeps coming on then shutting off! It's brand new, I've tried taking the battery out but it still does the same thing
Mine does this if the battery is not charged. Make sure the battery is installed with the contacts lined up (my daughter is a pro at putting the battery in upside down, and it doesn't connect to anything that way!) and charge it up overnight.
If it's still giving you trouble the next day, post back and we'll try something else.
Jul 30, 2009 | Aiptek PVR Camcorder
Charging the Jazz HDV188...
I have the same camcorder but my problem is i cant get it to come on , Ive been had it on the charger its like its not charging can any one help me
Jan 11, 2009 | Jazz HDV-188 Camcorder
DXG 506V
keep trying new batteries or unplug from computer same with mine but after i put new batteries in a second time it worked
Mar 26, 2008 | DXG Technology DXG-506V DV Digital...
Charging Battery
maybe your battery is dead, put your battery in your freezer for one night and charge it again.
Jan 21, 2008 | Video Cameras
Canon DC20 wont charge or turn on.
I wouldnt buy a new one when we get ones that are water damaged we throw them away and dont reuse anyhting sorry.
Dec 26, 2007 | Canon DC20 DVD Camcorder
White screen
I don't have a solution, but I have the same problem. Actually, I have that problem after I get it to turn on. The first part of the problem is that I can't get mine to turn on - with a fully charged and fucntional battery - without removing and rplacing the battery and switching on/off numerous times. Then, when it does come on, i get the exact white screen problem you decribe in your post above.
Dec 08, 2007 | Panasonic PV-GS39 Mini DV Digital...
RCA prov712 battery will only last 5 minutes
Be sure to charge for AT LEAST 14 hours on the new battery, even if the charger light goes out - it's still trickle charging. It's normal for most camcorders to auto-shut off after 5 minutes, if it's not recording. But if your batt light comes on, the problem is probably with the battery.
Dec 19, 2006 | RCA PROV712 Camcorder
Hitachi DZ-MV730A DVD Camcorder Logo
14 people viewed this question
Top Hitachi Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Hitachi Video Camera Expert? Answer questions, earn points and help others
