Question about HP Photosmart C6180 All-In-One InkJet Printer
Printer turns on, then goes off... Seems like its in a loop
The Printer turns on, then goes off... Seems like its in a loop... The screen lights up, the bar on the creen makes it look and sound like its getting ready to start print.... but then it dies and restarts again,
  • 1 more comment
  • sgerena Dec 18, 2008
    After shutting down and restarting the HP Photosmart C6180 AIO it says the printer was improperly shut down and to not just unplug or turn off the printer from a power strip (which I didn't do) and to hit OK. Even upon hitting OK it turns itself back off and on again, the loading bar appears and the error message returns. It seems to be stuck in a loop.
  • eqypt85 Dec 28, 2008
    My HP C6180 will not stay on. It starts and almost turns on, but then restarts. I've tried unplugging it for a while, moving it to another location, etc. The loop keeps running.
  • Anonymous Jan 20, 2009
    Same thing here. Whats the solution?
I have the same problem that tomilligan has. What is the solution to the problem?
Can someone help? 01/20/09 Inauguration Day!
Posted on Jan 20, 2009
  • 97 Answers
Hi tommilligan,
unplug the power cord from the printer and press and hold the ON button for 10 secs and try connecting to diffirent wall outlet directly.
regards,  raj_p5983
Miele Dishwasher stuck in drain mode, lights don't work, makes rattling sound from door. Model: G 2243 SCU
Anti flood switch has activated , check regeneration valve on right hand side of dishwasher , o ring may need hanging
Apr 08, 2017 | Miele Dishwashers
Keeps reseting itself
Dude check your A/V or HDMI cables or whatever you use. HDMI cables can be tricky. Make sure that the different shades of color are matched up exactly. Ex: make sure light blue isn't plugged into the dark blue slot. it may not appear as if it matters but trust me it does.
Jan 01, 2014 | Sanyo Dp32640
Printers LCD light stays on and blinks, printer will not turn on
Inkjet / Laser / Dotmatrix / Daisywheel / Make / Model?
Nov 18, 2017 | Office Equipment & Supplies
Scan light/bar will not move. It seems to be "stuck" It does light up, top feed vibrates but will not feed. Print command from screen works and unit prints
If making a copy on the printer does the same thing, it's a hardware problem in the copier/scanner area. You can try turning off the printer then powering it back on after 30 seconds. Make sure the printer is plugged in straight to the power outlet in the wall, bypass any surge device or power strip. If problem persists, I strongly suggest you contact Lexmark technical support to further investigate the problem.
Aug 10, 2010 | Lexmark X7350 All-In-One InkJet Printer
My hp laptop, the creen goes blank and the lights
This may due to laptop is in sleep mode or check whether the proper display driver was installed.
Dec 03, 2009 | HP Pavilion dv6000z Notebook
Can you help?
this has nothing to do with your printer. this sounds like a pc motherboard. good luck!
Sep 04, 2008 | HP LaserJet 3330 All-In-One Printer
It's not working!
It seems to be a software failure. Try using your recovery CD to sort it out. If it continuous then i would recommend a clean install if there's nothing that important on your laptop.
Aug 08, 2008 | Acer Aspire 3680 Laptop
My phone seems to have a glitch in it.If i close the phone the screen completely goes out.
This is because when you close your phone it pushed a button at the top of the phone thats blanks out the creen to save battery power.
please rate me. thank you.
Jun 04, 2008 | Cell Phones
Lexmark X1150 printer-fax
Try turning the unit off to reset it and see if this corrects issue.
Dec 13, 2007 | Lexmark X4270 All-In-One InkJet Printer
Making funny clicking noise and hour glass showing that it is processing won't go away
As a follow-on to solution 2 (thanks for the post BTW), I found the problem is indeed the light bar, but rather than breaking into the printer to move and lube the light bar, I found success by simply shaking the printer with the left side down, to move the light bar along it's track to the left. (the shaking motion is sort of like getting ketchup out of a bottle).
This worked better for me than dismantling the printer with a special screw driver and seemingly needing to break the panel to get to the third screw. Hopefully this helps.
Oct 11, 2007 | HP PSC 2510 All-In-One InkJet Printer
HP Photosmart C6180 All-In-One InkJet Printer Logo
342 people viewed this question
Ben Johnson
