Question about GE GSS25LGM Side by Side Refrigerator
GE side by side fridge TFX22JR not staying cold
Hi, our side by side fridge got warm on the fridge side about three weeks ago, and was iced up on the freezer side. We thawed it out and it worked after that, but now we have the same situation again.
I understand it could be the defrost heater, the defrost timer, or the defrost bimetal strip. What do you think? We want to fix it ourselves. Thanks!
The Kanes
  • 1 more comment
  • kanes_tucson Dec 16, 2008
    Thanks, that's good information to know and I'll keep it for future reference. We decided just after posting the message that we would go ahead and replace the defrost heaters, because we found a corroded and broken wire on one of them. The fridge has been working great ever since. =Kanes
  • Anonymous Apr 19, 2009
    Hi, our side by side fridge got warm on the fridge side, and was iced up on the freezer side just like what you describe. We are currently thawing it out. I wonder what checking continuity with a meter across the defrost heaters means, don't even know what the defrost heater look like. Where does it locate ?
  • haroldt May 24, 2009
    Our Freezer side was left open for an entire day and defrosted itself. We uplugged the unit and plugged it back up and it began to make a huge ice block on the rear wall of the freezer side.
    Scholar:
  • 111 Answers
You need to unplug the unit and check continuity with a meter across the defrost heater/s. If they are open, that's your problem. The defrost termination thermostat HAS to be below 20 degrees (varies model to model) to close. If at room temp it will read open. Doubtful it is your defrost timer.
Posted on Dec 16, 2008
Why does The freezer side stays cold but the refrigerator side gets warm
Your problem is more than likely a defrost issue. There is ice building up in the freezer coils and when it gets blocked with ice the cold air cant blow into the fresh food section. When you shut it off the ice melts and it gets cold again for a few days. remove the freezer back panel and check the defrost heater and defrost thermostat. if they check OK then check the defrost timer. It is best to replace all three components at the same time. This way you will be starting out with new components rather than one failing then the other.
Jul 16, 2014 | Kenmore Side by Side Refrigerator
What is causing the items in the vegetable bin to freeze and the ice maker is not working,(ice melted in the bin) and the water dispenser is not working and the filter was just replaced a week ago /
Sounds like the source of your refrigerator freezer temperature problem is due to a faulty evaporator fan motor. This fan circulates the air from the freezer to the refrigerator and back to the freezer. When it fails, temps are warm at the top, cold at the bottom, so the ice melts, and the water tank inside the fridge, near the bottom, freezes. I looked up your model #, but it shows no results so i cannot give you a part number.
Also, its possible if you have a control board microcomputer, its bad as well. Some model GE refrigerators the fan burns out part of the computer, necessitating replacing both.
Oct 05, 2010 | GE Adora DSS25KSTSS Stainless Steel Side...
Talkwhy is my ge refrigerator model gss20 iepaww side by side ( freezer not staying cold enough after i defrosted it after 3 weeks my refrigerator is also luke warm. after i unplug it and defrost it works...
Hello and Welcome to FixYa!
Check for the defrost unit working... There should be a periodic defrost cycle running to melt the frosted ice. If not, then the thermostat unit along with the timer and the heaters needs to be examined. Check for the drain channel for any blockage/clog... If there is some dust on the condenser coils, vacuum the coils to remove the dust/lint else ignore that too... Carefully diagnose the tripping of the thermostat/defroster unit as it seems to be faulty.
Hope, now you got a better picture,
Best of Luck,
Concerned.
Sep 19, 2010 | GE Refrigerators
I have a Kenmore Cold Spot Model 70192000. Having
HI, I can help you with this. It sounds like the defrost drain is plugged. If you will get me the model# from inside the fresh food section of the refrigerator, I can look up this model and instruct you on how to repair this.
Thanks
Vic
Jun 08, 2009 | Kenmore 50522 / 50524 Side by Side...
Compressor not working warm fan inside frezer run
Heat exchanger was iced over, took a hair dryer and melted ice. I think defrost heater element is bad will check it this week end. I put a new computer in the frige about 3 mounths ago and will check if it has gone bad. The compressor is working fine.
Jun 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
GE side by side not working
Defrost cycle not functioning. Could be defrost timer, timer motor, or defrost heater. I detailed this for someone else. see other solutions.
Nov 05, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Samsung Fridge side by side
It sounds like you have a defrost problem. This will either be the defrost heaters the defrost thermostat or defrost timer. In order to check the heater if you are competent enough you can check that you have resistance across the heater. Alternatively you can rotate the timer (normally in the fridge section abov the thermostat control) around to a defrost cycle (you will normally hear a click) and check to see if the defrost heater kicks in. Please note the cabinet has to be cold in order for the heaters to work. The defrost sensor should also have zero resistance across the terminals when the coil is cold. Please do no attempt the above unless you are practically skilled. A good fridge guy should be able to quickly identify the problem and remedy it. Defrost heaters are generally the first part to fail. Hope this is of some help.
Sep 10, 2007 | Samsung RS2630SH Side by Side Refrigerator
GE GSS25LGM Side by Side Refrigerator Logo
726 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
