Question about Kenmore 79012 / 79014 / 79019 Gas Kitchen Range
Kenmore Oven I have been having a problem with my Kenmore Oven. Sometimes it will not hold temp or pre-heat. I see the ignitor glowing when I set the temp, but it is slow to fire. I have been strating the oven at broil, it ignites, and then I set to temp. Sometimes it holds temp for a while but then falls out of temp. could it be the ignitor??
  • steavensu Jan 04, 2009
    Glow element visibly operational but this 7 year old kenmore take 10-12 minutes to fire the oven.
    temp run 75 degrees above dial setting.
  • 15,935 Answers
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Oct 01, 2010
Bake cycle wont work gas kenmore with electric controls you can set temp it goes to preheat and nothing happens broiler works and all the tops work
here is a tip i wrote covering that
What the problem is when your gas oven ignitor glows,but no heat for the...
MessageRate.ThreadID = 9947539; MessageRate.ProductID = 0;
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
Aug 03, 2011 | Kenmore Ovens
I HAVE A kENMORE GAS RANGE MODEL 665.75776890. tHE OVEN DOES NOT IGNITE. YOU CAN SEE A GLOW BELOW BUT IT NEVER IGNITES TO PRE-HEAT. CAN THIS BE FIXED BY REPLACING A PART?
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 12, 2010 | Ovens
Magic Chef CGR3742 Hi, I't has been pre heating, but took a very long time. Now it sometimes will heat up a little, but will not hold that temp. for long. I removed the bottom pan to see the burner and...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Nov 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Kenmore 362.75507001 Oven ignitor comes on but gas will not reliably flow in the burner. Had earlier moved all connectors on the upper panel, then gas flowed fine, oven came up[ to temp and seemed to be...
Just because it glows that does not mean it is not bad...
heatman101
Sep 06, 2010 | Kenmore Kitchen Ranges
Oven does not heat. Glow bar ignitor glows but no flame.
usually this means that your ignitor is weak and needs to be replaced. When the ignitor glows and NO gas flows through you need a new ignitor.
Jun 22, 2009 | Amana ARGS7650SS Gas Kitchen Range
Gas oven not keeping temp consistant
Hi. this is a failing oven temp sensor. the sensor probe is not responding to the oven control. this will cause erratic temps in this oven. it will also damage the control board if the sensor isn't replaced soon.
May 20, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven won't broil
You probably have a bad broil ignitor. When you turn the oven onb to broil the ignitor on the top of the oven should glow bright orange. If it doesn't glow or glows a dull orange, it is probably bad.
Apr 08, 2009 | GE 30 in. Gas Self Clean Slide-In Range...
Kenmore 30425 Oven will not reach target temp
the ignitor is moast likley bad, look for a hot spot on the ignitor showing a open on the filament.
Dec 25, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Model # fgf347awj propane oven will not pre-heat.
Sounds like gas valve is bad and the thermostat also. I would change the gas valve first. But when you said oven would not lite sure sign the gas valve is bad. New gas valve is about 50ish t-stat could be another 20. I would almost just get another gas stove at a used appliance store for 125 or something like that if unit is very old.
Nov 25, 2008 | Ovens
Oven doesn't heat
sounds like you have a bad oven ignitor, although oyu see it glowing orange its not hot enought hoopen the gas valve, very common occorance. 2 maybe 4 screws and 2 wires, order aand replace the bake ignitor
Mar 26, 2008 | Kitchen Ranges
Kenmore 79012 / 79014 / 79019 Gas Kitchen Range Logo
176 people viewed this question
Top Kenmore Kitchen Ranges Experts
Sal De
Justin Duby
Justin Duby
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
