Question about Acer n30 Pocket PC
Acer n30 Screen Tap Freeze
My acer n30 has developed a problem - tapping the screen to bring up a menu has almost stopped working altogether. It works fine with a mouse attached. Tapping 'Start' for instance has no effect, but will work intermittently.
What to do?
    Problem Solver:
  • 6 Answers
Sounds as if the touch screen membrane is defective, which is a darned nuisance, but not impossible to fix .... if you are confident of dismantling the n30, you can buy a new touch screen membrane from Ebay for about 4 pounds/6 dollars.
It is a very skilful job to remove the old touch membrane from the actual display screen below it, not really for a novice, and all internal components are very delicate, so i suggest you find a tame technician before you buy the new membrane. The touch membrane connects to the motherboard via a tiny flexible 4 or 5 pin membrane ribbon cable, it's a miracle of miniature engineering inside the n30, so do ve very careful if you decide to do it yourself, best of luck!
Posted on Apr 09, 2009
How do I fix my acer aspire touch pad?
some touch pads have a tap to turn off, and a double tap to turn back on... also check you F keys.
Jun 03, 2014 | Acer Aspire Computers & Internet
Screen come on / but not showing anything
Try to reboot your computer choose the option restore to my working state. If this does not work. Open the laptop in safe mode and goto system and see if some device is stopping the system from running properly.
Also try to remove any freshly removed devices or software
Sep 18, 2013 | Acer America - Notebooks Acer Aspire...
Acer desktop with black screen and line blinking
I'm thinking from what you describe that you are just looking at the cursor blinking in the upper left corner of the screen.
You haven't said what you did or what you are trying to do, but I suggest you turn the computer off (just push the power button in for about 7 seconds) and then restart it after about 15 seconds. If it doesn't start, go through the process again but this time, after you turn it on, tap on the F8 key. Like tap---tap---tap and keep doing that until you get a black screen with a white menu on it. Use your arrow keys to select "repair your computer" that you will see if you are using windows 7.
This should repair you startup problem.
Mar 22, 2012 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
I have acer n30 pc pocket. when i connect the usb cable for chasrging it dosen't get start and i can see the message on the scree "align screen" so what is a exctly solution pls tell me...
This happens when you get new one or after reset. It wants from you, to touch 5 points on the screen to calibrate touch screen.
Start acer without connecting usb cable and calibrate it first.
Jun 10, 2011 | Acer n30 Pocket PC
My acer aspire one net book wont boot up
You can try safemode by Tapping F8 when the system turns on
if the system boots into the Safemode try System Restore
1.Start menu
2. All Programs
3.Accessories
4.System tools
5. System Restore
6. Select a Date which the system worked fine
Or Else
Tap F8 try Last Know Good Configuration
if it did not help
Try re-installing the Operating system
Steps to Re-Install OS
At the Acer splash screen, you can press Alt and F10 to bring up a DOS style version of eRecovery. The unit is able to reload Windows from this mode faster then from CD. If the hard drive is replaced the system loses its eRecovery features. These features are on the hard drive and cannot be reinstalled
Jul 18, 2010 | Acer Aspire One PC Notebook
Acer Travelmate 4000 Won't Load HELP OHMYGOD.
when you boot up next time tap the F8 key. This will bring you to a screen that gives you a bunch of boot up options. Choose the one that says use last known good configuration. this should solve your problem.
Please remember to rate me.
Feb 01, 2009 | Acer TravelMate 2300 Notebook
Pd n30 new canot align screen with tapping it
I had a similar problem. I sorted it by doing 3 hard resets and a soft reset. You could try that.
Dec 29, 2008 | Acer n30 Pocket PC
Would u plz tel me wat to do
I looking for Charge Cable for Pc Pocket Acer n30-B
Dec 30, 2007 | Acer n30 Pocket PC
Acer N30 battery problem (even new battery does not last enough)
try checking your power saving options, you can drop down the backlight a little lower to extend battery life. Also you can lower down the volume of the system sound and check if the bluetooth is on, then turn it off. Recharge it and then check if the battery life extends. You also need to occasionally soft-reset the n30
Oct 21, 2007 | Acer n30 Pocket PC
Acer n30 Pocket PC Logo
299 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
