Question about Toshiba 2060 Copier
Paper Jam Papers keep getting jammed in the machine. I constantly have to open the copier and remove the jammed papers. Is there something I can do to correct the paper jam problem? Please advise. Thanks, jackob
    Problem Solver:
  • 7 Answers
Some basic non-tech questions:
  • Are you using paper that's been allowed to sit open for weeks? It might have absorbed water.
  • Are you in the habit of reusing paper that's double-fed? I used to, but it's more likely to jam
  • When was the last time the technician was in to do a preventive maintenance? The machine may need a basic clean-and-check.
  • Check your manual, and check what the machine is telling you (on the display, if it has one). The location of the jam may give you an idea of the reason for the jam (jamming at the fuser may indicate a cold fuser, jamming at the drum can be caused by broken separation fingers, etc.) If you have a technician, this will be useful information.
Posted on Nov 23, 2008
CM2320 MFP PAPER JAM
Bad problem , check if there is some piece of paper ... otherwise yuo need a thecnic , may be is a paper sensor damaged .
Aug 28, 2014 | HP Laserjet CM2320nf All-In-One Color...
My HP DeskJet is jammed how can i remove the jam and print
Paper jam is very common problems for all printer . It can occur due to strayed, stuck bits of papers in pathway of paper tray, outlet, roller etc. I would recommend cleaning the paper inlet, outlet, and other possible areas to avoid a paper jam situation. I have observed that most people fan the paper pile to keep them dry or non-sticky. It's a wrong method because fanning the pile of papers make them go haywire and often lead to paper jam.
***You can also solve the common printer problems....read more
Aug 29, 2012 | Office Equipment & Supplies
Paper Jam HP OfficeJet 8500
etechrepair.jpg Constant jam indication. This gear is more than likely the cause after exhausting all other avenues. Also nearly impossible to get to let alone replace even if HP offered the part. There is a black cover over the clutch assy that can be removed to reveal the gear. In most cases the gear is either sitting in the bottom of the machine or split down one side. This is the second machine that I have diagnosed with this problem in a very short time. If you have this broken gear, consider it toast. Matt / E-tech Copier and printer repair.
Mar 28, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Paper jam
The way you describe your error, it seems that there is still some residual paper stuck inside the printer that may cause subsequent paper to be mis-aligned.
Paper jams can be tricky to solve. The paper is usually stuck inside the printer mechanism so even if there is no visible paper jam, you will still get the paper jam error. Try this:
1. Turn off your printer
2. Open all trays and remove any paper stuck there
3. Locate the button to open the printer, open it and remove any paper stuck there also.
4. Repeate the above step for all buttons that you can find to access the inside of the printer
5. Close all doors and put back all trays
6. Turn on your printer
NOTE: Please rate our help to keep this free service online.
Jan 07, 2010 | Lexmark X5150 All-In-One InkJet Printer
We keep getting a paper jam problem, How do you
First and foremost make sure the paper you are using is dry, if the paper you are using is damp you will continue to have this problem. Removing jam papers involves you first removing the cartridge then you'll find the paper compartment.
Good Luck.
Oct 02, 2009 | Lexmark X3650 Printer
Canon imageclass mf6530 paper jam error wont go away
check where that u removed the paper and see if one of the sensors is stuck or out of place. also look for a piece of paper. you may have to get a flash light to see better
Aug 05, 2009 | Canon imageCLASS MF6530 Monochrome Laser...
MY PAPER IS JAM IN MY HP DESKJET D4160 PRINTER
Open the paper jam cover at the back of the printer and remove the jammed papers, be sure you return properly the cover afterwards. Re-start your machine.
Mar 02, 2009 | HP DeskJet 3745 Printer
Error code on Ricoh FT5733 copier
Open ALL paper jam locations on the machine. The jam code only means the paper jam is somewhere BEYOND the paper drawer. Check ALL jam locations including duplexer, bypass, and ALL paper drawers.
Nov 12, 2008 | Office Equipment & Supplies
Paper jam
remove papers fixed in printer than,
service your printer at service center of branded showroom
use quility papers for printing some time low quility paers make your printer donkey,
try to use best for long life span of printer.
THNX
May 16, 2008 | HP PSC 1315 All-In-One InkJet Printer
Paper jam
well part inside your product (paper handler/sensor) got damaged. must be serviced / non-user serviceable part.
Jan 22, 2008 | Epson 1000 ICS All-In-One InkJet Printer
311 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
