Question about Averatec 3200 Notebook
Averatec 3280 unmountable boot volume
Averatec 3280 windows XP OS
unmountable boot volume screen on startup.
recovery software is embedded in partition of drive. Instructions say at Post. Does not work. How can I get to the software and or if not can I just install windows XP from anywere.
Thank You Bill
  • fun4drj Nov 25, 2008
    i am getting a constant boot disc error at startup.
    It says i need to check cable or reload software
  • Averatec Master
  • 32,281 Answers
You can install Windows XP from your CD drive, you may have to change the boot order so you can boot up from the CD first.
Posted on Nov 23, 2008
Will not boot up after hard power down / reboot bsod unmountable boot volume stop error screen STOP 0X000000ED do not have SR1030NX compaq pc RECOVERY CDs thinking of ordering fm hp /...
From the sounds of it you may have to just reinstall windows. If you do not have the recovery disk you can purchase them from HP for 5.oo USD.
Dec 27, 2010 | HP Compaq Presario SR2030NX PC Desktop
No complete starting
Unmountable boot volume means your harddrive has gone out.You will have to get a new one and load your os again.Sorry:-(
Apr 08, 2010 | HP Compaq Presario C502US Notebook
Unmountable Boot Volume Win XP
u need to reboot it .I mean yu need to have a system disk and then install it
Oct 07, 2009 | Compaq Presario 2195US Notebook
Startup repair won't run
"Unmountable boot volume" this problem is your hard disk partition which is failure to recognize & identify the operating system running on the hard disk. Reformat your hard disk and put another operating system to run again your computer.
Jul 27, 2009 | Computers & Internet
Unmountable Boot Volume BSOD
0xED is not just specifically present on HP computers but all PC-based computers which has XP or later using NTFS on it. It can be resolved by doing a chkdsk /f /r or by performing a repair installation using windows. This is caused by software corruption (which is repairable using the steps aforementioned) or hardware failure, which may lead to OS reinstallation or harddrive replacement
Jun 10, 2009 | HP Compaq Business nc8000 Notebook
Blue screen during booting
Yes, unmountable boot volume usually means you need a new hard drive. However, if you have a windows xp cd, you can boot to the recovery console (press R at the first prompt) and try running a chkdsk /f command. Sometimes that will help. Thanks and good luck! Oh and if you could remember to give this solution a rating of fixya. Thanks!
Jan 18, 2009 | HP Pavilion ze2000 Notebook
have to re-install windows
to boot from CD, check your BIOS setting and have the computer to boot from the CD FIRST
Jan 11, 2009 | HP Compaq nx7010 Notebook
I have a Averatec 3280 is there a website that I can get a XP recovery disk downloaded for free?
No unfortunately. You will have to purchase an XP retail CD or call Averatec for a replacement disk. It is illegal to post Windows install disks for free download. Sorry.
Maybe there is someone you know that has the same version on XP you do and you could reinstall from their disks and use your license # for activation. Unfortunately the drivers for your machine will not be on their CD and you will have to go to the Averatec support site to get the appropriate drivers for your model computer.
Best wishes
Jan 04, 2009 | Averatec 3200 Notebook
Boot volume err
Computer Crashes, they seem to happen at the most inconvenient times. Always when you need the computer the most. I've run across this boot error message many times since Windows XP was released and luckily most of the time this problem can be solved with a few simple steps.
Basically the error means that Windows XP is having trouble booting from Drive C. Following the steps below, you should be able to troubleshoot this problem and get your computer back and running.
Causes of Unmountable Boot Volume
Many times this error occurs when I have swapped a hard drive and used the wrong IDE cable to connect it. If your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and you use a standard 40-wire connector cable to connect the UDMA drive, you may experience this error. Make sure you are using the correct IDE cable.
Also, if your BIOS settings are configured to force the faster UDMA modes, this error may occur. In this situation, restart your computer and enter the BIOS and load the "fail-safe" default settings and reboot.
If neither of these issues are the cause for the Unmountable Boot Volume, then the issue most likely is caused by a damaged BOOT.INI file in the root directory of the boot drive or file system corruption.
Follow the steps below to correct these file system issues:
1) Start your computer with your Windows XP CD-ROM, or with Windows XP boot disks
2) When the Welcome to Setup screen appears, press R to Repair the installation using the Recovery Console
3) If you have a dual-boot or multiple-boot computer, select the Windows installation you want to access
4) Type the administrator password when you are prompted, if no administrator password is set then just press Enter
5) At the command prompt, type CHKDSK /R and then press Enter
6) Once CHKDSK has finished checking and repairing the hard drive, type EXIT and press Enter to restart your computer
If this procedure does not work, repeat it and use the fixboot command in step 5 instead of the chkdsk /r command. FIXBOOT writes a new partition boot sector to the system partition. The fixboot command is only available when you are using the Recovery Console.
Oct 18, 2008 | Computers & Internet
Hi everyone...my windows xp wouldn't start up at all..(unmountable boot volume).kept restarting with the blue screen...I had ** xp disk (came pre-installed)....finally was able to get to my files by downloading K**ppix to a CD and running that on my broken xp ...just downloaded it, ran it, and I was able to access all my folder/files that I didn't want to loose...**w I can use my recovery disks to get my computer running again..I would recommend this option to anyone with ** xp disk...it saved me from loosing important files that I needed...just thought I would share this with you since I k**w many pc's do NOT come with the windows disk these days....
Mar 02, 2008 | Casio QT-8000 Network Terminal
Averatec 3200 Notebook Logo
400 people viewed this question
Top Averatec Computers & Internet Experts
Rommel Balcita
Are you an Averatec Computer and Internet Expert? Answer questions, earn points and help others
