Question about Toshiba SD-3980 DVD Player
DVD PLAYER My dvd player toshiba SD-3980 WHEN I INSERTING A DVD DISC IT APPEARS ON THE SCREEN OF THE TV THAT MY DVD DISC IS INCORRECT INSERTING WHILE THE WAY I INSERT IS CORRECT AND PROPER. AND IT ALSO APPEAR IN DISPLAY OF THE DVD PLAYER "BAD" WHAT IS THE CAUSE OF THIS PROBLEM? THANKS. I HOPE YOU REPLY TO MY QUESTION.
  • 1 more comment
  • bulzz4 Nov 07, 2007
    My DVD player Toshiba SD-3980, has worked well for the time I have had it. Until last week, when a friend came to visit from Spain. He had DVD's that he recording events while in Spain to show. I removed a disk I was watching, and we incerted his Disk. A message came on the TV screen indicating that the disk was incorrect. I removed the disk from Spain and replaced it with one of my own. Received the same incorrect disc message. The continued as I tried several disc of mine. Help
  • Houston234 Jan 21, 2008
    Same thing happening to my DVD. I followed #no 1 instructions and their sending me a new DVD player. Mine is a 2005 and it is still under warranty. Neat huh? And many thanks
  • Anonymous Mar 25, 2014
    i insert a dvd it says reading then says err. wrong disc
Tapped and banged to no avail. Took the top off, saw the disc wasn't spinning, tried to spin it with my finger (like turning a page) and it started spinning and the readout displayed four dashes like normal and now works!
My son said, "thank you, my glorious mother!"
Aww, shucks!
Posted on Nov 13, 2011
I tried the suggestion to tap the bottom of the DVD player... and that did work for us. Thanks for the solution.
Posted on Feb 23, 2008
I used the suggestions from post 1 and they are sending me a 2007 dvd player and I don't even have to pay shipping. This will at least get you a free replacement that works!
Posted on Jun 26, 2007
I have had identical problems to those noted above and to my utter amazement they have been solved by forcefully tapping the bottom of the player. It still sticks often so I guess I shall soon have to buy a new machine - not from Toshiba?
Posted on May 01, 2007
Mine did the exact same thing I hit it and it worked for a while not it dosent at all so yea I took it apart and threw it away
Posted on Apr 23, 2007
Go to http://209.167.114.38/support/ceg/Productnotices/dvdplayer.asp
Posted on Mar 30, 2007
    Welcome Back:
    Visited the website for 2 consecutive days.
I tried tapping(gently, but with authority) the case where all the mechanical parts lie, ie the center. It didn't work right away. But then I found success tapping from the bottom of the case! As it turns out, this does not require taking the cover off.
Posted on Jan 16, 2007
You know what? about the same time frame as you posted this, dec 25th, this happened to me too. it won't play discs. just says bad on the player and the tv screen says incorrect disc. tried using a dvd player cleaner disc and it won't read that. i wonder if their players were set to a timer to not work anymore.
Posted on Jan 07, 2007
Hi Koji, My Toshiba DVD player does the same. It stops playing the disc, and the icon for incorrect disc displays. Often I cannot even start a movie. I keep getting BAD on the readout display also. I try hitting the player, or the stand in which the player is sitting, and sometimes it goes away and the movie plays. I will never buy Toshiba again.
I have a Toshiba SD-3980 DVD player, how can i get a disc that is in the player (which no longer works)out?
If you don't care about the unit take out all the screws on the case until you can remove the whole top, you should be able to access the disk once you remove the case.
Apr 30, 2014 | Toshiba SD-3980 DVD Player
I own a Toshiba SD-3980SU2 DVD Video Player. I keep getting an Incorrect Disc comment, and bad comment. I an using DVD-RW discs. I have tried disconnecting and reconnecting the player.
You are probably using incorrect disc formats in this DVD player; try DVD+RW if you must use re-writables, or DVD-R (finalised in a recorder or burned on a PC). I doubt this model supports DVD-RW, so the problem wouldn't be with the player; it would be the formats of the discs you use.
Don't use DVD-RW discs in this player if it does not support that format.
Apr 22, 2011 | Toshiba SD-3980 DVD Player
After I insert the disc, the digital readout say bAd and the screen states Incorrect Disc.
There is an recall from Toshiba for "bad" problem in Toshiba SD-3980 dvd player.
"Toshiba is committed to customer service and to continuously improving the quality of its products. It has come to our attention that certain DVD players bearing the model numbers SD-3980 and SD-K750 may at some point in their life stop playing discs due to a component part failure. In such case, the error message "bad" will be shown on the unit's display. Affected units will have "SU2" at the end of the model name (e.g., SD-3980-SU2), which can be found on the back of the unit. If you own either of these models and experience the issue described above, please contact Toshiba Customer Solutions at 1-800-631-3811 for information on how to obtain a replacement unit."
Click Toshiba Support link for original message, please contact Toshiba and above number for replacement unit.
Hope these info will help you.
Thanks.
Feb 12, 2011 | Toshiba SD-3980 DVD Player
Toshiba DVD player SD3980 Keep getting an incorrect disc or bad message. Have turned it off & tried other discs.
check spindle motor,flexible wire, if this two is ok then your laser is at fault, note; be aware on installing flexible wire if its incorrect it may impair the operation of sled motor , clean clogs and dirts on sled gears
Oct 13, 2009 | Toshiba SD-3980 DVD Player
Problem w/dvd toshiba dvd player
it sounds like the dvd loader assy is faulty or the mpeg pcb.
Jul 04, 2009 | Televison & Video
Toshiba SD-K770 DVD player flashes error and BAD DISC
hi... the problem might be in ur dvd... If ur dvd is perfect and u found that ur player has some problem means the best solution is that to clean up ur dvd player lense which plays a vital role in reading ur dvd when u insert into it...For cleaning up ur lense all u need is a lense cleaner dvd available in electronic shops.. u can purchase it and play that dvd as normal one.. ur problem will get solved..
thank u rate me!!!
Feb 07, 2009 | Toshiba SD-3980 DVD Player
Toshiba DVD SD-3980SU2 or SC2 player loads every disc as "bad disc"
Toshiba says:
Information for Owners of Toshiba SD-3980 and SD-K750 DVD Players spacer.gif To ensure the satisfaction of our customers and to maintain the integrity and quality of our products, Toshiba America Consumer Products, L.L.C. is issuing an important product update. This is not a safety issue.
Mar 29, 2008 | Toshiba SD-3980 DVD Player
Disc Error
Simple issue, the lead laser cannot read any data, for better result please try to check with the DVD shop.
Hope you like my solution please rate me solved.
Best regards,
Philip
Nov 17, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-3980
If the disk is not dirty, smudged up or scratched -- it is likely the laser pickup getting weak or the spindle motor not keeping at the right speed. If you have to clean the disc, wipe from the center out with a clean soft cloth.
Jan 13, 2007 | Toshiba SD-3980 DVD Player
Toshiba SD-3980 DVD Player Logo
1,114 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
