Question about Cookshack SmartSmoker SM150
Over temp just changed the element and when I pluged it in I got an over temp. I pressed the rest and I got a TT69
Why does the water temp delivered from two Visu-temp valves in back to back bathrooms turn lukewarm after about 4 minutes.
personally I would change the temp setting to hotter water .isn't that why we have a cold water valve also to mix you will use less hot in the long run
Jan 15, 2015 | Water Water Heaters
Control Board or Relay Board?
If you are talking about oven bake and broil elements, the board is most likely the problem if both elements test good
Sep 28, 2017 | Frigidaire Kitchen Ranges
This mouse is a lx7 model It is pluged into the computer, the batteries are good , but the mouse will not move the arrow.
Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it to Reset/Connect the mouse to the receiver and work properly.
If not, try pressing the receiver button and then press the mouse. This should be done whenever you change batteries or glitch.
Dec 05, 2010 | Logitech Computers & Internet
Electric hot water heater not heating
If this all of sudden happened and you had hot water. Check for power to the heater and to thermostat. Thermostat may have tripped out to reset it just press red reset button on it.
If you have done all this and you have power to heater, thermostats and to the elements. Then the elements need to be replaced and you need to turn off power and drain heater before changing elements out.
I hope this will be some help to you.
Jun 01, 2010 | Rheem Water Heaters
Changine a heating element on a washing machine Indesit WIA 101
Sam. The small nut and bolt which protrudes between the element ends should be loosened but not taken off. Press on the bolt, which will relax the compression on the rubber sealing block. This should allow you to extract the element. Once you have done this it will become clear..
Feb 20, 2010 | Washing Machines
Wiring for dual 30 gal heat element. changed both elements. need to put wiring back
Go to this link and page down, it gives you the wiring diagram for a dual element hot water heater.
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Dec 09, 2009 | Element Water Heaters
Lower oven will not heat above 230
The lower element is defective, either it is burned out (replace) or the relay that drives it is defective, have the same problem here (unless you know electronics you would replace the control board in this case). When the unit is preheating it uses both top and bottom elements to reach temp, in this case the bottom element is not doing its part so it never rises over about ~220. Rest of stove will work fine until this is repaired.
Oct 18, 2009 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Clean light flashing 7 times. Can't start the machine
The cleam light blinking means that the unit was not able to reach a proper heated wash cycle. Either your heating element failed orthe actual sump/pump motor system has failed. Check the element in the botton and see if it looks broken anywhere. If you can see a broken spot, you will k now that is the trouble.
Good Luck!
Oct 20, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
Cookshack SmartSmoker SM150 Logo
62 people viewed this question
Top Cookshack Grilling Experts
Are you a Cookshack Grilling Expert? Answer questions, earn points and help others
