Question about JVC HD-52G786 52" Rear Projection HDTV
Lamp/Program led blinks
When you push the on button the blue light turns on and then the red lamp/program led blinks over and over. I changed the lamp, had a new back up lamp but the old one didn't look broken. and still doing the same thing.
  • 1 more comment
  • dalance Nov 22, 2008
    Should I only be looking at the board that the power goes into?
    The board looked OK and all the connections looked good. Any other ideas?
  • dalance Nov 24, 2008
    Nothing is wrong with the boards, could it be sensors that are bad?
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Initially, if you have change the lamp to a known good/new then the lamp indicator should no longer blink. Not unless the light engine itself is faulty. If so, this is a major repair and might be best to seek professional repair. Other related areas and ideas you could explore/check would be:
  • fan;
  • the new lamp itself maybe faulty if it is with the same batch/inventory as the original. I was made to understand that JVC has since then replaced these lamps with improved versions;
  • ballast;
  • power board;
  • there is also a known common problem - "intermittent connection in crimp of CN307". This would be the cable assembly, one specifically for a 'DIN Cord Assembly' and is described as a 17 pin JVC Cable;
  • ambient temperature has known effects on the life of the old bulbs.
It would be to your added advantage access to a service manual, service bulletins or at the very least a schematic diagram with voltage readings if you are considering further DIY (do-it-yourself) repair.
Just a start, do postback how things turned up or should you need additional information. Good luck and Thank you for using FixYa.
Posted on Nov 24, 2008
    Sergeant:
  • 276 Answers
I understand your examination that board looks good but sometimes it seems to look good but the tracks which moves from 1 point to another are just getting broken at a point and that needs to be checked with a multimeter.and also if any of the capacitor getting loose on the main board can give such problems so resoldering all the capacitors and ics properly can make this problem solve if it is due to loose capacitor or ICs.but if its due to short track in the board it needs to repaired to make it proper. thanks
    Novelist:
  • 98 Answers
If all else fails, you can probably bet that your power supply has gone bad. Many people make the mistake of hooking up TV's to surge protector strips when the set actually has an internal surge protection device. This will cause the power supply to work harder as the power strip limits the amount of power going to the supply. In addition, many people don't plug their TV into surge protectors although certain sets DO NOT have internal surge protection. This could cause the smallest power spike tp fry out your power supply as well, If the TV is still under warranty, I would suggest going that route. If not, try calling around to get a few estimates to see if you can find a decent price to get it repaired. Hope this info proves useful. Have a wonderful evening!
    Master:
  • 505 Answers
Make sure air vent cover in the rear of the tv is properly installed. if the back cover is not connected properly the red light will blink
Posted on Nov 22, 2008
  • Indrajit Roy
    Indrajit Roy Nov 22, 2008
    First make sure all the cable at the back of the TV is connected properly.
    The problem you referred means that the TV is going in protect mode because it detects an internal problem, try leaving it unplugged for a longer time, let say one hour or two.
    Basically, what happens is that the TV does not start because it detects that there is an internal problem, such as a wrong voltage, a bad component, overheating etc.
    When you unplug power and restart it, you reset the internal circuit, and the TV will restart, not detecting the internal problem.
    As soon as the TV gets hot, after staying on for a while, the defective part start giving troubles, as the defective component (probably an IC, starts overheating).
    From description, the Digital Processing Board can be cause for the problem as there is no video.
    However all the following parts can be involved.
    Parts involved can be
    LCD Controller
    Contact some local tech shop or geeksquad to get the unit repaired.
    Thanks
    Brigadier General:
  • 3,614 Answers
Check all connections. check the changes made inside check the connector and the connections. check for any bad soldered on the mainboard.
  • micromaster
    micromaster Nov 22, 2008
    yes. check that area
When i turn on my tv it tries to boot, blue mitsubishi home screen come up, i hear fan then it all shuts off while green light blinks.
Try a reset. Start by unplugging for 1 minute, then plug back in & if still won't restart try the following. If none of the following work, you will need a technician.
Initializing the TV in many cases can remedy a problem.
In the 2006 product line Initialization is now a user function.
Pressing the front panel "INPUT' and "FORMAT"
buttons at the same time activates Initialization. When
complete all user settings will have to be set again. The
table in Figure 4-3 list the User Initialization procedures.
Note: Pressing INPUT and FORMAT is the same as
the Initialization in the Option Menu (MENU-2-4-7-0)
Order Name Procedure Results Notes
1 System Reset Press <System Reset>
on Front Panel
Hardware & TV operating
software reset.
POWER/Timer LED flashes for 60
seconds. No customer settings
are changed.
2 User Initialization
Press <INPUT> &
<FORMAT> on Front
Panel at the same time.
All customer Audio &
Video settings are reset to
factory default.
All customer settings will need to
re-configured.
3 Reset System
Defaults
From the remote, press
<MENU> <1-2-3>
<ENTER>
except V-Chip are reset to
factory default.
Netcommand, Channel Memory,
etc., will need to be re-configured.
SERVICER
PROCEDURE 4 Initialization
<MENU> <2-4-7-0>*
select "INITIAL" press
<ENTER>
All customer settings are
reset to factory default.
re-configured.
MITSUBISHI RESET / INITIALIZATION CHART
CUSTOMER
PROCEDURES
Figure 4-3
Figure 4-4
LED Indications
The front panel LEDs, refer to Figure 4-4, also assist in
determining the cause of a symptom. Figure 4-5 illustrates
normal LED operation. Figure 4-6 shows the
LEDs response when a problem is detected and indicates
the possible cause.
Power/Timer
Indicator
Status
Indicator
Lamp
Indicator Condition
Off Off Off Off (standby)
Blinking green
fast Off Off Initialization (10 - 65 seconds)
Off Off Blinking
green fast Lamp runs for 1 min after PTV off
Green Off Off Power On
Blinking green Off Off Power On Timer is set
NORMAL LED INDICATIONS
Power LED Status LED Lamp LED Condition
High Temperature - check ventilation air flow.
(Temperature sensor is disconnected.)
Off Off Blinking yellow Lamp cover is open.
Lamp failure (Lamp fails to turn on)
Off Off Red (Lamp turns off after lighting)
Lamp is broken
Off Blinking Red Off Fan Stop
Off Red. Off Circuit failure. (Run Error Code Check)
Apr 08, 2015 | Mitsubishi WD-65731 65-Inch 1080p DLP HDTV
Installed new lamp. When powered up blue solid light and yellow blinking light (15x) , tv would torn off and on several times trying to light lamp. Once that failed red blinking light and yellow solid...
Hi Genaro,
Blue led light lit solid and yellow led light flashes is an initial attempt of the set to re-light the lamp.Red led flashes and yellow led light solid means that the lamp won't light up that's why it only has sound without the picture.
Since you've replaced the lamp twice and still the symptoms persist, I suspected that the fault came from the ballast board and not on the lamp itself. If the ballast board gone to malfunction, there's no high voltage will produce to light up the lamp and will sensed by the processor and trigger the error code (Flashes/solid led light with color code).
To verify whether the ballast board is faulty or not, check if the lamp will lit by looking through the lamp door louvers at the rear of the cabinet upon turning on the set.
Please let me know what you will find to assist you further.
Jdvillanueva
Nov 05, 2011 | Toshiba 65HM167 65" Projection Television
I turn the power buttin on....after about five
When was the projection lamp last change?If the tv,projection lamp inside the tv at last change was 1/ 1/2 or 2 years ago,and the tv is on,an in use at lest 4 or 5 hours day.The projection lamp life,it over should be change the projection lamp.Now tv turn on LED light "LAMP" indication light up or flashes?Yes,the projection is dead,hear alot of clicking too?The Ballast board it also dead,should be change too.The Ballast board,this board job,it help to ignite the projection lamp.
Jul 23, 2010 | Toshiba TP61H60 61" Rear Projection...
Sony wega kdf42we655 power led blinking red
If lamp light is on at tv front then replace lamp as existing lamp sounds dead/ broken.
Lamp replacement procedure would be written in user manual of tv.
And if lamp light is not on but standby light is blinking then let me know how many times it is blinking to find out problem cause as standby light blinking is an error code.
Mar 25, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Optoma EP755 new lamp when power standby button
you need to reset the lamp timer, usually done by holding some buttons while turning on
Mar 10, 2009 | Optoma EP750 Multimedia Projector
Please help!!! Problem with JVC DLP TV
You need to replace the power supply board. The new ones have a bigger heat sink - obviously JVC knows about the problem because they made the new ones bigger. It cost $250 from JVC and I installed it myself - took about 3 hours to do. If you are not tech savvy call a repairman. Hope this helps.
Feb 03, 2009 | JVC HD-52G786 52" Rear Projection HDTV
How old is your TV?
Lamps in DLP TV has specific working hours and physically lamp will look good but won't give light ( actually consume more current and protection circuit stops power supply)
Thank you.
Dec 04, 2008 | JVC HD-52G786 52" Rear Projection HDTV
Hello i have a JVC model # HD56G786 DLP TV. The problem i have is that the set will not turn on. Whe i try to boot the set up it starts as normal as the blue power light stays on and the small red...
I would agree with you on that the power board could be at fault. The best course of action would be to get the board/TV checked out professionally. It could be the dry joints, resistors or capacitors.
Dec 04, 2008 | Televison & Video
JVC HD-52G786 52" Rear Projection HDTV Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
