I have a dimplex electralog model cs4416 and it is still heating but will not blow the heat out what can i do
  • ring2late Dec 21, 2008
    i have electralog model cs 4416 also and usually the heat setting doesn't work at all. other times the heater and blower work ok. can i fix this on my own or can i bring to a local repair place?
  • Anonymous Feb 21, 2009
    Got the same problem but no one has a solution it seems.
I beleive the heater and fan switch are a dual unit. Mine has a AUOne ST 360. I pulled the part outand it the copper is very pitted and corroded. The problem I have found is that this switch is made in China and I have had no luck finding a US distributor.Electralog/Dimplex... has an toll free number but it is hard to get through. 1-888-346-7539. If anyone gets through on thier problem, please ask about price and delivery and where to order. I would love to see this posted.
Posted on Jan 03, 2013
2 Suggested Answers
kevin000
  • 1847 Answers
SOURCE: dimplex heater model no -CHT20 will
did you try it on a different wall socket.Chk the power supply fuse
Posted on Aug 09, 2008
Heat stops working after a few minutes
A manufacture name and what type of heater would be helpful.
Mar 30, 2014 | Electralog Home
Dimplex electralog is making an intermittent squeaking sound?
When it is switched off try spraying WD40 around end of spindles. Try heater again after about an hour.
Nov 30, 2013 | Dimplex Compact Electric Flame Stove...
No visual fire - did the lightbulb burn out?
Yes - Replace bulb per your owner's manual instructions.
Make sure to use the recommended bulb type & wattage to ensure proper flame effect.
Jan 26, 2013 | Dimplex CS4416 Electric Compact Heater
On my electralog heater, after about 5 minutes running the heat stops,fan is still running. Adjusting thermostat makes no change
From what you have described. it sound like the heating element is overheat and the automatic over heating sensor is shut it down. One of the primary reason these heaters overheat is that the become clogged with dust, lint & pet hair. Cleaning the heating element. may solve your problem. A vacuum cleaner (especially a Shop Vac) that has a hose, a brush attachment and a crevice tool, works well well in cleaning the heating element. Be sure the unit is OFF and unplugged, before attempting any cleaning.
Hope this helps you solve the problem.
May 19, 2011 | Dimplex Compact Electric Flame Stove...
My heater motor stoped turning and blowing but the heat strip kept heating and melted the rotating fan . It is a 20406D7F 077 can I order a whole complete replacement unit
Yes, you probably can. Plus, Dimplex should be made aware of this. Contact Dimplex Technical Service 888-346-7539, Monday -Friday, 8a -4:30p ET. Have the model number, serial number and proof of purchase, handy when you call.
Hope this helps you get the parts you need.
Apr 26, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I have a Dimplex Small Electralog Stove Fireplace CS1205, it's two years old but barely used until this winter. A couple months ago, the flame stopped working and now the heat keeps turning off after 5...
More than likely, the interior of the unit needs to be cleaned. When it's in operation, it sucks dust and link into the fan and heater elements. When it's not, spiders love to go into and build nests. If badly clogged, it can cause the heating element to over heat and shut off. Carefully, removing the back panel of the stove will give you access to just about everything. As far as the flame is concerned, the bulbs may need replacing. Although, it's unusual for all of them to go bad at one time. You or your nephew can replace them after the unit is cleaned. A vacuum that has a hose, brush attachment and crevice tool, will work well in the cleaning of the interior. Be sure to turn the Master ON/Off Switch to OFF & Unplug the unit, before attempting and maintenance on it.
If after performing all of the above, the unit still doesn't work properly, contact Dimplex USA, Technical Service 888-346-7539, for further advice.
Hope this helps to solve your problem. Please let me know.
Mar 17, 2011 | Dimplex Compact Electric Flame Stove...
Heater fan stop working after a couple of muinutes
Dimplex Electralog Model 6901050600 Ser 17807D2F - 048 Blower and Heater Works fine, Flame has quit working. How do you find and replace the Bulb? Email cairoeichard@gmail.com
Jan 02, 2009 | Dimplex Compact Electric Flame Stove...
Heating & Cooling Logo
731 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
