Question about Zenith D60WLCD 60" Rear Projection HDTV-Ready Television
Blur This Zenith rear projection screen is ten years old and the picture is very blurry, lack of focus. Is this a convergence issue, fluid, or what? Anyuthing I can do?
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 208 Answers
Most likely a unit this age with start showing signs of weak crts. These crt's hava a life of 7 to 10 years and your discription is failing crts. I am afraid it is time to move to a new unit.
Posted on Feb 11, 2008
SOURCE:
I have a philips 60pp9202 model tv . it about .9yrs old the letters shows doubled on the screen.i have changed the convergence ics, it still doing the same. the screen also shows blur. can you help...
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 26, 2011 | Zenith R60V26 60" Rear Projection...
I HAVE A HITACHI 53WX10B TV AND THE SCREEN IS BLURRED. I HAVE TRIED THE MAGIC FOCUS BUTTON AND THE SHARPNESS BUTTON. ANY OTHER IDEAS?
Magic focus button don't work or datas never reaches 100%.Tv have a problems,known as a convergence problems,it dead.Tv have colors lines R,G,B mis alingments,have colors shadows pictures or a 3D pictures look alike?The tv have a dead convergence board.The tv convergence board have 2 STK convergence ICS and some or all of it resistors are dead too.These parts on the tv convergence board,must be replaced to solved the tv convergence pictures problems.The shop,will cost like $300-350 for parts and labors.
Dec 04, 2010 | Hitachi 53SWX10B 53" Rear Projection...
Blurry picture on left side double image right side is ok....
Ur convergence is dead,need convergence kit.
U know how to solder right?Tries these websites for convergence kit.Tv Repair World.com,Shopjimmy.com,Ebay.com or Partstore.com
Sep 25, 2009 | Zenith IQB50M90W 50" Rear Projection...
Odd picture....
Yes, your convergence is off. There is a function in the menu for adjusting these propoerties. It is supposed to be done monthly but rarley is. If it is ten years old or more, the cooling fluid in the projection tubes can get low, causing fish bowl effect. Not a cheap job and time intense. Try adjusting the convergence first. It gives you three screens to aling each color then save. Good luck!
Jul 25, 2009 | Televison & Video
48" rear projection hazy/bad picture
most fluid changes would fix that. I recommend doing all three but that's just me. Also make sure the crt's are full as this would cause the set to be out of focus. also make sure you don't move the yokes too much because you can knock the convergence out pretty bad and also have a blurred pix
Jan 09, 2009 | Televison & Video
Blurred picture and it's also dark rear projection zenith Z52Z95D
I'd get the lamp replaced for sure. If it has a ballast - change that at the same time. However, a Zenith repair center should be able to tell you whether it's worth doing or not.
Jan 05, 2009 | Zenith Z52Z95D TV
Auto Focus Stoped Working
If the convergence is very far off the convergence ICs are bad and need to be replaced first. If the convergence is close and it wont correct it might just be an insect or some dust on the sensors at the 12, 3, 6 and 9 o'clock posistions behind the screen.
Jun 04, 2008 | Akai PTH5498 54" Rear Projection...
Zenith rear projection tv 56"
You have a convergence problem. Go to the convergence menu or consult the owners manual on the convergence procedure and try to correct i if you can.. However if the red image is bowed and or not linear you will probably need to call a technician to repair your set. Most likely the red convergence output chip has failed. This is a common problem with all CRT ( picture tube) rear projectors. Good Luck. Happy Easter
Mar 23, 2008 | Zenith R56W36 56" Rear Projection...
The convergence is way off. You may be able to adjust it thru a service mode menu. You'd need to get the model number first.
How old is the set?
Thanks,
SF in Vermont
Jan 29, 2008 | Zenith IQB50M90W 50" Rear Projection...
Poor color issues.
try adjusting the convergence. good luck and happy valentine!
Feb 14, 2007 | Sony KP-53S65 53" Rear Projection...
Zenith D60WLCD 60" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
