Question about Maytag MER6772 Gemini Electric Kitchen Range
Problem with left front eye
The left eye for some reason won't trip off. It continues to stay on. How do i sut it off?
This sounds dangerous! you can lift the top of the stove to access the burners source of electricity. Unplug one of the hot wires to the bad eye and conpletely cover it with electrical tape. NOTE: This is a temporary fix. consult Maytag Support @ 1-800-688-9900 For a better long term solution! Have a great day, Alan
Posted on Feb 13, 2007
  • 78 Answers
SOURCE: Forgot my username cant log into laptop, help
Posted on Sep 22, 2014
Left front brake grabbing and vibration at times. gets hot and smokes
This is in need of an eyes on inspection for brake issue like warped rotor or sticking brake caliper piston.
Feb 01, 2017 | Cars & Trucks
Garage door reverses for not reason even with the sensors disconnected
Ugh so after a half hour of trouble shooting this issue there was a small part of a leaf stuck to the bottom of the door. Sticking out just enough to trip the sensor right at the bottom. It was intermittent. Sometimes it would trip it sometimes not.
Sep 27, 2014 | Building Materials
Damaged grill and driver's side headlight assembly completely missing
Yeh, but who won?? All you need is an eye patch and dental work. Poor deer.
If you have the time and inclination, a trip or two or 3 to a salvage yard could get you all the parts to renew it, and save you a lot of money that a body shop would charge.
Jan 15, 2014 | 2002 Chevrolet TrailBlazer
GLTF1240ASO Front Door Won't Lock/Close
Most probably your door lock is damaged. You are not supposed to force it open, you have to wait for at least 2 minutes (or till the lock sign is off) after the wash is over to open the door, never force it.
You can just google your model number and search for parts to obtain it. It is quite possible you can change it yourself. See that the line is disconnected from the mains.
Jun 04, 2013 | Washing Machines
Admiral dryer super capacity dryer won't heat up and light doesn't stay on. It happened when we first brought it home years ago and the repair may said to reset some button but I don't kn
see this causes and fix it. God bless you
Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker.
Door Switch
If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Check for continuity you should have none with door open, and should have a reading when closed. If not replace the door switch.
Thermal Fuse / Thermal Cut out
On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel or behind the front panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing or is sometimes round and made of metal and plastic.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse this is the most common reason for blowing the fuse. (You can't re-set this type of fuse.)
Wiring
Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Sep 28, 2012 | Admiral Dryers
Dryer door won't stay open while removing clothes
Likely the feet to the dryer are not level. Grab a large level and check to ensure the top front is level across.
If your door opens to the right, raise the front left foot by screwing it counterclockwise. Check level, and repeat.
Mirror the operation for a door that swings to the left.
Jan 25, 2012 | General Electric WCVH6400J Front Load...
Our SHE33M02UC dishwasher won't stop pumping and won't continue to the drying part of the cycle.
Hello Frank,
The reason the pump continues to run and no other function will work is because the flood leak detecter has been tripped and thusly their is water in the base frame and until time their is no more water in the base frame the pump will keep running. The things that could cause water to be in the base are;Oversuddings so suds have entered base a drain problem so to much water was in tub causing some of it to enter from vent into tuba leak in any of the components or hoses in the basea overfill so again water entered the base through the vent
In an case the service panel below the main door panel can be removed and water sopped up with rags/towels/sponges ect and when water is out the dishwasher will operate normally.....if soon it only starts pumping only the reason why water is in the base would need to be determined
Good luck,GENE
Sep 25, 2011 | Bosch Evolution 300 SHE33M02UC Built-in...
My cigarette lighter, and display on my factory stereo went out at the same time. Could this be a fuse? If so, where would it be located?
On my old XL7 these features would go out, and the cruise too. The fuse was in the fuse panel, left of your left knee as you drive and was the lowest in the front most rank. Note that fuses go out for a reason, that reason is too much current is passing through them. So unless you fix the bad component, it will continue to blow out. On my XL7 the problem was a bad lighter, suppose the prior owner had kept jambing something in it. Once I replaced the lighter the fuse stayed intact.
Jul 22, 2011 | 2001 Suzuki Xl 7
I see double image unless I take the lens as close as the binoculars can go
thats how binoculars are. Yours in this case is really strong. the closer you are to something, looking at it, the more magiflyed you going to be. try view things far a distance, really far away. no more double right?
Everything you need to know to become an expert:
on this website: http://www.chuckhawks.com/binocular_basics.htm
It is surprising how many people do not know how to focus binoculars correctly. There are two common focusing systems used in binoculars.
The first is individual eyepiece focus. This system is simple to understand, and easy to manufacture. It also lends itself well to sealed optical tubes, and thus is usually the focusing system used for waterproof binoculars. Individual eyepiece focus means that to focus the binoculars to your eyes, you simply focus the left eyepiece to your left eye and the right eyepiece to your right eye. There is no centrally located focusing mechanism. It is done like this. Look at something in the distance. Close the right eye (or cover the front of the right binocular), and focus the left eyepiece to your left eye. Close the left eye (or cover the front of the left binocular), and focus the right eyepiece to your right eye. You are finished, until you need to look at something at a different distance, in which case you need to repeat the process.
Because individual eyepiece focus is time-consuming, center focus is more common. Unfortunately, very few people understand how to correctly use center focus binoculars. Here is how it is done. Aim your binoculars at something in the distance. Close the right eye (or cover the front of the right tube), and focus the left side of the binocular to your left eye using the center focus control, which is concentric with the pivot shaft between the binoculars. (Note: the left eyepiece itself does not focus on center focus binoculars.) Next, close your left eye (or cover the front of the left tube), and focus the right eyepiece to your right eye. DO NOT touch the center focus control while you are focusing the right eyepiece to your right eye. Now you are finished. What you have just done is adjust the binoculars for your individual eyes. (Practically everybody's left and right eyes are different.) From now on, you only need to adjust the center focus control when you look at things at different distances. Center focus is faster and easier to use than individual eyepiece focus, once you have initially set the binoculars for your eyes.
Binoculars are commonly described by using a pair of numbers, as in "7x50" or "8x25." The first of these numbers refers to the magnification offered by the binocular. Magnification is why most people buy a pair of binoculars. In the examples above, "7x" means the binocular makes whatever you look at appear seven times closer than it does to the unaided human eye. "8x" means the binocular makes whatever you look at eight times closer than the unaided human eye. "10x" makes things look ten times closer, and so on. The first number used to describe binoculars always refers to their magnification. Common binocular magnifications are 6x, 7x, 8x, 9x, and 10x.
There are also variable power (zoom) binoculars, such as 7-21x50. These almost always perform much better at the low power setting than they do at the higher settings. This is natural, since the front objective cannot enlarge to let in more light as the power is increased, so the view gets dimmer. At 7x, the 50mm front objective provides a 7.1mm exit pupil, but at 21x, the same front objective provides only a 2.38mm exit pupil. Also, the optical quality of a zoom binocular at any given power is inferior to that of a fixed power binocular of that power. In general, zoom binoculars are not the bargain they seem to be.
Remember that everything (including movement) is magnified when you look through a pair of binoculars, especially your own shakes and tremors. So the higher the power, the harder it seems to hold the binoculars steady. 6, 7, or 8 power binoculars are easier for most people, even those with very steady hands, to hold reasonably still. The higher powers sound like a good deal, but often result in jiggly, blurred views. This is why 7x binoculars are chosen by so many experts, including the military.
Power affects brightness. Other things being equal, the higher the power, the dimmer the view. And power also affects the field of view of the binoculars. Again, everything being equal, the higher the power, the smaller the field of view. So, as you can see, power must be balanced against other desirable characteristics when choosing binoculars.
May 09, 2011 | Bushnell 240842 Binocular
Frigidaire smooth top electric stone eye stuck on high!
Yes,the switch controlling the burner is bad and must be replaced.
Oct 31, 2009 | GE Kitchen Ranges
Maytag MER6772 Gemini Electric Kitchen Range Logo
108 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
freddyfox
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
