Question about Cal Flame 5-Burner
6 burner Cal Flame in counter grill won't work
We have a 5 burner Cal Flame propane grill. This grill is about 5 years old but it has not worked properly for about 3 years. The knobs get so hot you cannot touch them when you are grilling. The knobs will hardly turn on and off you need a lot of wrist strength to even turn them at all. Many of the knobs have gotten so hot the fiber inside the knob has melted and I cannot buy these fiber inserts , according to Cal Spa you have to buy the whole knob. The latest thing is the grill will not even turn on at all , one burner will light but it acts as if there is no gas going to the other burners.......This thing has been a piece of **** for almost 3 of the 5 years we have had it. It looks like brand new but it just doesn't work...I am going to replace it but my son is buying his first house and if it can be fixed I would give it to him...Do you think there is any hope for it or should I just chuck it.Thanks for you time. Jim
  • joe-carrie Mar 01, 2009
    My issue is almost the same the burners wont all light on my Cal 5 Burner. Im not sure how to clean it and Cal is no help at all. They say find someone who repairs grills. Well good luck finding that. I only had mine about 2 years and half the burners wont light. Can anyone please help?
2 Suggested Answers
  • 63 Answers
SOURCE: cal flame gas conversion
hi my name is mark, there are several possablitys why it can not be converted, one could be the orifice is pressed in manifold, another is it might require a different burners with air shutters and a regulater. it was problably designed for propane only, to save cost.
Posted on Mar 14, 2009
Grill won't start
if your sure the propane tank is full, and the valve is open, (counter clockwise, and the control knob is on? you should not only smell it after 20 seconds, but if you put your ear near the grill you should hear a sound like air leaking.If you hear nothing and smell nothing, good chance there is a blockage in the line, or the burner holes are filled with drippings. First off, get a wire brush and scrub the burners where you see the small holes that the flame normally comes out of, then try the grill again, if still nothing (and your 100% sure the tank is full, the tank is on, and the control knob is on high) you may need to start taking apart the grill, looking for a blockage, many times its below the control knob where you will see an adjustable screen, spider webs and such will get in there and block the flow. Remember to not do any of that with the tank on the grill, remove the tank first.;
Jul 27, 2012 | Weber Q 320 Propane Grill
Only left side of burners working
If you have the Cal Flame burners that are straight, cast brass burners, there is a slot under neath the burners on the back end of the burners. This slot allows the flame to move from the left side of the burners to the right side of the burners. This slot in the burner will corrode shut and not allow the flame to move from the left to the right side. Sometimes you can scrape out the corrosion, and sometimes you can not. If you can't get the slot open, then you have to replace the burners. Cal Flame burners also have a reputation for warping.
Mar 04, 2012 | Cal Flame 4-Burner Drop-In Grill
Burner won't ignite it is a cal flame have to lite with a match
Linda, changing the battery in the electronic ignition will probably solve the problem. To change it, unscrew the ignitor button cap and remove it. The battery will be in the holder inside. Take note of which way the old, burned battery is facing, because that's the way you want the new battery facing, when you install it. While the old battery is out, check inside the battery holder for corrosion on the terminals. If you see any, use a Q-Tip & WD40 to clean the corrosion off.
Hope this helped you troubleshoot and solve the problem. Happy Grilling!!
Jul 02, 2011 | Cal Flame Grilling
New propane tank. Burner will not light, no gas flow. This was a replacement grill from coleman because they couldn't get the regulator. Starting to get very disgusted with this product.
jcw - It sounds like the regulator is locked up from turning on the gas tank valve. Happens a lot with the new OPD Valves on the grill tanks.
1. Turn the tank valve OFF and disconnect the hose from the tank.
2. Turn the burner(s) ON for 1 Minute, Then turn them OFF.
3. After 5 minutes reconnect the hose to the tank and open the valve VERY, VERY, SLOWLY (Slow
motion, slow).
4. Once the tank valve is fully open light one burner and turn it to HIGH. Did the burner light and
does the flame height look correct? Id so, light the remaining burner the way. Did it light and the
flame height look correct? If so, you solved the problem (with a little help).
If the above didn't solve the problem, the Hose/regulator Assembly needs to be replaced. What happened was this, when you turned the tank upside to "burp" the tank. The OPD Valve shot a hot load of gas to the regulator, when you opened it as you normally would and permanently locked up the grill's regulator. That "burping" trick used to work with the old style tanks. Won't work with the new ones. You can get a new hose/regulator assembly at any home center or hardware store, that sells grills and accessories. They run about $30.00. Take your old one with you for comparison purposes. Once you install the new one and connect it to the tank. Open the Valve Very, Very Slowly, until it is fully open. Or you may have the same problem again.
Hope this helped to solve the problem. Happy Grilling!!
Jun 18, 2011 | Coleman RoadTrip 9928-A50 Propane Grill
I have a ducane 5 burner grill, its about 7 yrs old. it wont light up it seems that there is some kind of blockage from the propane tank to the burners. i tried bleeding the sysyrem but it didnt work....
The Propane tank is equipped with an OPD (Overfill Protection Device). More often than not it has locked of the grills regulator. (I'm assuming you have already checked and cleaned the burners) To solve the regulator problem do the following:
1. Turn the tank valve OFF.
. Disconnect the hose from the tank and wait 5 minutes.
. After 5 minutes, reconnect the hose to the tank.
. Turn the tank valve ON VERY, VERY SLOWLY (Slow Motion, slow), until the valve is fully open.
5
. Light the burner that's farthest from the tank first and turn it to it's highest setting. Does the flame
height look correct? If so, light the remaining burners the same way. Have all flame heights
returned to normal? If so, you solved the problem.
Remember, after turning the tank OFF for any reason, always turn the tank back ON Very, Very Slowly.
If that didn't solve the problem, you need to replace the grill's hose/regulator assembly. You can buy one at any home center or hardware store that sells gas grills and accessories. Take your old one with you for comparison purposes.
I hope all of this helped you troubleshoot and solve the problem. Please let me know and Happy Grilling!
May 04, 2011 | Ducane Grilling
We need to replace the flexible propane line that goes from the knob to the infrared burner. It has sprung a leak. Help BBQ874P
Cal Flame should carry the part you need. Call Customer Service @ 800-225-7727 or try your closet Cal Flame dealer, where you purchased the grill. Be sure that you have the correct model number when you call.
Apr 15, 2011 | Cal Flame BBQ874P
Need photo of how to replace the 5 "V" shaped
The 'V' shaped metal bars are the flavorizer, flame tamer or whatever Weber wants to cal them. They go over top of each burner from front to rear, setting on the ledge of the interior of the grill, just above the burners. make sure that cover each burner equally. Now's a good time to clean them if they have a lot of grease on them.
Since the grill was blown off your deck ... make sure all the burners are intact are not damage and there are no gas leaks from tank to the grill.
Feb 11, 2011 | Weber Spirit? E-310 Propane Grill
Cal flame gas conversion
Mar 13, 2009 | Cal Flame 5-Burner
Veranda gas grill - won't light or low flame
One of the major problems with propane gas grills, including the Masterbuilt Veranda, is the pressure regulator. They get to where they do not release enough propane. Some, most, have an adjustment screw that will let you correct these problems. I think I replaced my Veranda regulator with another older pressure regulator from an old grill. Makes you crazy if you don't know this.
Mar 08, 2009 | Masterbuilt SBMPG3 Veranda Steel Grill
Cal Flame 5-Burner Logo
265 people viewed this question
Top Cal Flame Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
richie46
Are you a Cal Flame Grilling Expert? Answer questions, earn points and help others
