Question about Cornea CT1702T 17 in. LCD Television
Volume My speakers dont work when i use the tv as my computer monitor. When used as a tv, the sound works fine. Its not my computer because when i plug in my headphones, the sound still works. The volume is up. Help!
Your computer sound "out" jack has to be connected to the sound "in" jack at the back of the monitor(next to the vga input). To do this you need about a 3 foot stereo jumper cable with male connectors on both ends.
Posted on Mar 13, 2008
My view sonic monitor has no sound
Troubleshooting Sound Issues Verify that the audio cable is connected to the AUDIO OUT or LINE OUT output on the Sound Card and plugged into the AUDIO IN or LINE IN of the Monitor.   Make sure there are no cables connected to the Headphone Jack (located next to the AUDIO IN port) on the monitor. If there is, please disconnect that cable and try the speakers again. Connecting a cable to the Headphone Jack disables the speakers. If there is no cable connected into the Headphone Jack, test a pair of headphones into that jack to see if you can hear sound out of the headphones. If you are able to hear sound out of the headphones, disconnect the headphones and try the speakers again.   Verify that the Mute on the monitor is not on or the Volume is not turned down.    Verify that the Mute on the computer is not on or the Volume is not turned down.<    If there is still no audio from the monitor's speakers, connect the Audio cable to another audio source like a portable CD player or tape player headphone output. If audio can be heard through the monitor's speakers, then there may be an issue with the computers sound card.    Connect another set of computer speakers (if available) or headphones to the AUDIO OUT or LINE OUT output on the Sound Card. If NO audio can be heard then there is an issue with the sound card. Verify with the computer's manufacturer for additional assistance.   LCD TVs Troubleshooting No Sound from a LCD TV No Sound when using RGB (when connected to a PC) Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the computer. Note: On the N1700W use the GREEN mini-jack; on this model Audio is SHARED between DVI and RGB, there is only 1 audio channel for data connections. The N1700w is designed to take a 1.0v RMS audio signal for optimal sound quality.   Confirm that both the LCD TV Mute and Windows Mute are off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the monitor or remote to confirm the Volume is not set to zero.   Confirm that PC volume is sufficient by using Windows/Macintosh Volume adjustment settings.   Try plugging another audio source such as a CD or Cassette Player directly into the Audio port on the LCD TV to confirm the speakers work, or try plugging headphones or external speakers into the sound card on the Computer. If the Headphones or External Speakers do not work, contact the manufacturer of your Computer for further support. No Sound when using S-Video/Composite/ Component Video Confirm the audio cable is plugged into the Audio in on the LCD TV and the audio out on the S-Video, Composite, or Component Video device.   Confirm Mute is off. A general message will be displayed on screen to indicate status of Mute (On or Off).   Press the Volume Up Button on the LCD TV or Remote to confirm the Volume is not set to zero.   Try plugging headphones or external speakers into the audio port on the S-Video, Composite, or Component Video device. If the Headphones or External Speakers do not work, contact the manufacturer of your S-Video, Composite, or Component Video device.   Note: Some ViewSonic monitors do not include speakers.
Nov 23, 2010 | ViewSonic E70f 17" CRT Monitor
The two speakers dont work.One of them does not
check the cable may be cable from first mall speaker problem
May 13, 2010 | Altec Lansing BXR1121 2 Speakers
Hi. I connected a 26 inch Insignia TV to a Dell
Check the master volume of the computer by double clicking the speaker icon or going to the control panel. THere should be an option for all aspects of the volume and see if there are items set to a minimum. Try another speaker if it helps if not, have the sound card inspected in the device manager. The error code should tell if it is a driver issue or may just need reinstalling.
Dec 07, 2009 | Computers & Internet
Hp w2207 monitor has no sound
Does the moniter have internal speakers? If so then there is a volume controller option on the moniter or else you have to use external speakers.
Jun 14, 2009 | HP w2207 Monitor
Monitor speakers stopped working
Make sure that the audio cable from the computer is in the correct audio output (small green socket) and connected into the monitor. You can test the monitor speakers with an MP3 player or a smartphone. Also check that the volume on the monitor is up.
Jan 28, 2018 | BenQ FP71G 17" LCD Monitor
Packard Bell speakers screeching sound
Are they plugged in to correct sound socket on back of computer
even if they are on monitor
Jul 05, 2008 | Packard Bell Speaker Computer Speakers
No Sound
DO I HAVE TO GET NEW SPEAKERS FOR VISTA TOWER
THEY WORKED FINE ON MY OLD COMPUTER
NOW NOTHING
I HAVE IT TURNED UP HIGH ON THE MONITOR SCREEN BUT NOTHING.
Feb 23, 2008 | Logitech X-540 Computer Speakers
Built in monitor speakers not working
Did u check with the volume button on the side of the monitor.
Also pls check the connections and also the volume settings in windows.
If they dont work, then try with external speakers to find out if it is a problem with the mionitor or the speakers.
Jan 30, 2008 | Proview PX 780 Monitor
Polaroid FLM-323B LCD TV with no sound
Same issue....went to bed last night Polaroid tv worked fine....woke up NO VOLUME>>>
Jan 13, 2008 | Polaroid FLM-3232 Television
Compaq wf 1907 monitor speakers--no sound
No sound from monitor speakers
If the built-in speakers on the monitor do not produce sound, perform each step that follows, testing for sound after each step, until you can hear sound:
  1. Close the software program you are using that is experiencing the sound problems. Test for audio using another software program.
    If the volume is adequate using another software program, the issue is with the computer, not the monitor. If the volume is still low, continue with this procedure.
  2. Check the cable connection. If the monitor-to-computer connection is a VGA cable (usually blue on both ends), an additional audio cable is needed between the monitor and the computer. Check that the audio cable is connected properly.
  3. Try to adjust the volume higher using the monitor front-panel volume button.
  4. Using the buttons on the monitor, navigate through the onscreen display (OSD) menu to find audio or speaker settings and enable the speakers.
  5. Click Start c01292216.gif , Control Panel , and then click Sounds and Audio Devices .
  6. From the Volume tab, check the Device volume, and make sure it is not muted.
  7. From the Audio tab, in the Sound playback field, click the Volume button. Make sure the audio device is not muted and the volume outputs are at adequate levels.
  8. If the monitor-to-computer connection is an HDMI cable, an additional audio cable might be needed, depending on the setup and configuration of the system. To find out whether an additional audio cable is needed, go to
HP and Compaq Desktop PCs - Using HDMI Audio with a Desktop Computer
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector.
HDMI sends both audio and video through the same connection. If you want to hear audio from an HDMI connection, HDMI audio must be set through Windows . For example, if a computer is connected via HDMI to a monitor or TV and the proper HDMI audio settings are made, both audio and video will be sent to the display device.
Use the following steps to activate HDMI audio on your computer:
    NOTE: If you are setting up your computer for the first time, it may be easier to use a DVI connection or DVI-to-VGA adapter connection for the initial setup. Then, if you want to use an HDMI connection to connect a TV or monitor, activate sound for the HDMI connector using the steps that follow before connecting the HDMI cable to the TV or monitor.
    NOTE: After recovering the computer using the Recovery Manager, repeat this procedure to activate sound for the HDMI connector.
Step 1: Enabling HDMI sound in the BIOS
To hear audio through the HDMI connector to a monitor or display, enable the Onboard Audio setting in the computer BIOS settings by completing the following steps.
    NOTE: If you choose the default BIOS Setup options or upgrade the BIOS, you must repeat this procedure to enable audio for the HDMI connector.
  1. Turn off the computer.
  2. To enter the BIOS, turn on the computer and press the F10 key repeatedly until a BIOS Setup screen opens.
    A BIOS Setup screen opens.
  3. Press the right arrow key on the keyboard to select the Advanced tab.
  4. Press the down arrow key to select Onboard Audio , and then press the Enter key.
    Figure 1: Example of Onboard Audio menu
    An option window opens.
  5. Press the down arrow key to select Enabled , and then press the Enter key.
    Figure 2: Onboard Audio Enabled
  6. Press the F10 key. Select Yes to save the default settings, and then press the Enter key.
  7. The computer restarts. HDMI sound is now enabled.
Jan 03, 2008 | HP Compaq WF1907 Monitor
Cornea CT1702T 17 in. LCD Television Logo
91 people viewed this question
Top Cornea Televison & Video Experts
Marvin
Marvin
Are you a Cornea Televison and Video Expert? Answer questions, earn points and help others
