Question about Compaq Presario 700 470024-192 Notebook
Operating system not found
Screen went blank after trying to load a file in cd tray. i tried to use quick restore several times but no luck. nothing happens even after it says it has downloaded the restore cd. screen always goes back to operating system not found.
  • Compaq Master
  • 32,281 Answers
This message means that the hard disk was not detected, this is due to either the BIOS setting was changed or the hard disk has failed.
Try booting up with a DOS disk and run FDISK, and see if it detects the hard drive, if possible run a diag test program.
Posted on Nov 23, 2008
I have a dell espirion desktop. When I turn it on it prompts me to start it in safe mode and two other options. Tried each option and nothing happens. Screen goes blank. Nothing. Days ago, computer was...
Try using the Windows operating system reinstall cd and perform a repair installation.
Boot up the computer using the operating system reinstall cd, press F12 and select the cd/dvd drive
When setup loads, and you go to install windows, you can press R to repair the current installation
Dec 20, 2010 | Computers & Internet
My Window Xp on my mini note book a file has been corrupt file missing so it wont load windows
Try booting in safe mode.
Switch on you note book, while its booting press F8 several times, this should bring up a black screen with several boot options, choose "Safe Mode"
This will load windows shell programme.
Once loaded click on Start - All Programmes - Accessories - System tools - System Restore.
Select a restore point prior to when you first had a problem and let your pc do the rest.
If you can't do a system restore for what ever reason, you'll have to do a system recovery, this tends to dump your data.
Nov 13, 2010 | Computers & Internet
I need to recover/reboot my emachine but don't have a disc? What can I do because it is saying corrupt files.
Try booting in safe mode - Switch on as normal, while you pc is booting press the F8 key several times until several boot options appear, one being "Start in safe mode" select said option and wait, with luck, a windows shell will start up.
Click on Start - All programmes - Accessories - System Tools - System restore. (This is XP, Vista & Win7 will be slightly different)
And restore to a date before your problems arose.
If that doesn't work we're into re-installing an operating system, which will clear everything off your hard drive. So before you do that, down load and create the Ultimate Boot For Windows CD:-
http://www.ubcd4win.com/downloads.htm
This will boot up with a windows type shell with loads of diagnostic tools etc, but which may help you retrieve data from your HDD.
Finally, if you don't want to pay for an operating system like widows, try Ubuntu, its free :- http://www.ubuntu.com/getubuntu/download
Good luck.
May 08, 2010 | E-Machines eMachines Desktop PC
Gateway laptop reset
Gateway Direct systems went "media-less" back in September 2004. In the event of a system crash users could either 1) restore their systems from the Recovery Partition OR 2) from the backup media that they were prompted to create on first power-up -- which would provide them with up to 5 blank CD-R discs depending on their system's configuration.
On the factory load of the hard drive, the recovery partition will not contain operating system files. It only contains application and driver files.
The first time the recovery partition is used, it prompts the user to insert their System Recovery CD/DVD to copy files from the CD to the recovery partition.
The Drivers and Applications CD is not bootable and does not contain Operating System files.
The System Recovery CD/DVD is bootable but does not contain any application or driver files.
If the end-user erases the hard drive and restores the computer using the System Recovery CD/DVD and an Applications and Drivers CD, the recovery partition is not recreated.
This means that you will need the operating system restore disc FIRST then the recovery partition will work for you
Mar 14, 2010 | Computers & Internet
I want to factory restore my dell dimensions 3000.
There are three methods available.
1) Use Windows XP System Restore.
If you cannot access Windows XP, the following two methods are available.
2) Use the Dell Operating System CD, and the Dell Resource CD.
If you do not have these restoration CD's,
3) Use Dell Restore by Symantec
With this method all personal files you have, and any programs, or applications you have installed, or downloaded, will be GONE.
(Personal Files: My Pictures, My Music, My Videos, and personal files you have created)
Turn the computer on. AS SOON as you see -
www.dell.com, appear in the blue bar, Press -
the CTRL key, AND the F11 key -
AT THE SAME TIME. (Not shouting)
If you do not press both keys at the same time, and in time, let the computer load. It may stop at a blank screen, with a blinking cursor.
It's okay. Now press the CTRL key, ALT key, and DELete key at the same time.
This will restart your computer. Try again when you see the www.dell.com logo.
If upon pressing the CTRL key, and F11 key, you go to the next screen, left-click on - Restore
On the next screen click on - Confirm
Takes about 6 to 10 minutes.
After the restoration has stopped, click on Finish.
Your computer will now reboot.
Should you need help with Windows XP System Restore, or using your Dell restoration disks, please state so in a comment.
Jan 31, 2010 | Dell Dimension 3000 PC Desktop
I am working on my friends gateway mx6450 laptop when you turn it on it goes to a blank screen after the welcome screen. I have tried to run on safe mode. It goes to a blank screen with the safe mode...
1. Refresh the screen: Right-click on the desktop and select [refresh]
The icons will appear.
if not,
Boot to the Safe Mode screen and select "Start in Last Known Good Setting"
Nov 13, 2009 | Gateway MX6450 Notebook
Gateway screen comes up; optical and (new) hard drive spin up, both drive lights light up during this time, fan spins up and air moves out of the side vent continously but still nothing but a blank screen....
If you have an operating system disc that came with your computer try putting it is and see if you can load the disc. If you can go to the repair screen after it loads all files. When you are at command prompt type: chkdsk /r
It will try to repair operating system. When done type "Exit" and restart. If you can't load the operating system disc you might be having a graphics card problem. Go to the manufacturer's website and check on their forums for your problem. Hope this helps
Jul 05, 2009 | Gateway MX6931 Notebook
Screen is whiting out/striping
It has gotten worse: the laptop took a tumble in the middle of the second full system restore and now there is not OS on the laptop! I am trying to use a secondary usb cd drive to start up from the OS disk, but no luck...argh!
May 19, 2009 | Gateway 450ROG Notebook
PS3 Screen is blank
No i think your ps3 froze or your settings r 4 hmdi and not snail cables next time reset your tv sometimes the hdmi freezes
Jan 27, 2009 | Sony Playstation 3 (PS3) Console
Compaq Presario 700 470024-192 Notebook Logo
136 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
