Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Side by Side Refrigerator Always dispenses crushed ice regardless of setting
Hello all, I have a GE TFX28FBDA model refrigerator, ~10 yrs old. It only dispenses crushed ice even if the setting is for ice cubes. I opened the freezer door and removed the tray. It took a few minutes but I noticed that that there is a long metal rod that runs from the front of the ice tray to the rear which needs to be engaged for the ice to bypass the ice crushing blades. I have done some research online and found that there is a solenoid which engages this bar when the cubed ice option is chosen. The hole where this metal bar fits in the back of the refrigerator has ice coming out of it (not a lot but enough to surround the plastic piece). I chipped the ice away and the solenoid began to work (I held the door button down making it think the door was closed). I saw the solenoid engage. I placed the ice tray back in the freezer and I GOT ICE CUBES to come out instead of crushed ice. I thought it was fixed. The problem is that the plastic piece that engages the metal rod was again "frozen" and not engaging the next morning. Can someone tell me if there might be a solution to this icing problem? Does the refrigerator just need to be defrosted? Any ideas are greatly appreciated. Thank you.
  • Anonymous Apr 01, 2014
    crushed ice has plastic pieces in it.
You need a new defrost heater strip.
Posted on Jun 10, 2008
Just jam that solenoid thing on top of that white piece in the back and the cubes should stay on cubed
Posted on Jun 05, 2007
    Problem Solver:
  • 7 Answers
Chech the ice dispencer solonoide and thet the ice leaver is inserted into the holder and not underneath
Posted on Feb 22, 2007
I have the same problem. I had a service guy replacer the solenoid and still no cubes. He thinks i need a new circuit board. The other main problem I have is the fan behind the panels in the freezer half has ice build up and make a loud noise till i manually defrost the freezer. Ive done this every 4- 7 days for the past month and the ice still comes back. Any ideas??
Posted on Feb 08, 2007
  • 237 Answers
I know it will be a pain but take it apart again and lube the metal shaft in the solenoid and the plastic slide with petrolium jelly, that should keep it from freezing up. It's what we do...
Posted on Dec 26, 2006
GE PSS25MGMA Crushed ice only, nothing else will select on panel.
Yes , replace the main board . Part number WR55X10656 . There is only partial communication between the main board and the dispensor board . This main board , is behind the 8 " X 10 " panel , on the back of the refrig . Do not replace the dispensor board . I have never come across a bad dispensor board yet . Always a first time though .
Sep 27, 2009 | GE GSL25JFPBS Side by Side Refrigerator
Our GE Monogram Icemaker will only dispense crushed ice
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components
Aug 29, 2009 | GE Monogram® ZISS420DMSS Side by Side...
Ice maker dispenses crushed ice in the cube setting. Water and crushed ice are fine.
Typical of a switch failure / control module failure so it sticks on the crushed ice setting or the crushing mechanism is u/s and wont turn off. Call a service engineer asap.
Aug 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
My water dispenser suddenly has stopped working.
Yes, it could be the water filter. Also check to make sure the water is turned on and that any lines to the refrigerator aren't kinked or crushed somewhere. It's also possible that you will not be making any ice as well if your appliance has an ice maker
Apr 06, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer wont dispense cubes, only crushed ice
I had this same problem for a few days. I opened the door & played with the ice dispenser hole and it ended up working again
Dec 19, 2008 | Frigidaire FSC23F7D Side by Side...
Ice/water maker won't dispense
Icemaker only dispenses crushed ice even when in cube position. Water/light work fine. Have already replaced control module circuit board.
Nov 17, 2008 | GE GSH25JSRSS Stainless Steel Side by Side...
GE Profile Refrigerator
Unplug it for around 30 mins. then plug it back in and see what happens. Try this before anything.
Dec 26, 2007 | GE Profile PSW26P Stainless Steel Side by...
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
370 people viewed this question
Top Refrigerators Experts
Sal De
Brad Goodale
Sometime Mechanic
