Softener not draining
My front loader is all of the sudden not draining the softener during the cycle. i've taken the tray out cleaned it numerous times, evan ran a cycle w/ just belach in all the compartments. nothing will work. how do i fix this?
  • tesoud Nov 25, 2008
    The softener dispenser is not draining.  If it is a problem with cold water not running through, what is the fix for that?
  • Washing Mach... Master
  • 3,463 Answers
Could be no cold water is coming into conditioner compartment, or you still have a blockage in dispenser. Remove the dispenser and fill the conditioner compartment with water. hold it level and the water should syphon out.
If it does not then it is blocked somewhere
Posted on Nov 22, 2008
Softener tray is not draining during wash cycle
This tray empties during the spin cycle not wash cycle. Is the agitator spinning during the spin cycle? If so, you are getting softener on clothes during this cycle as required.
Feb 17, 2015 | Kenmore HE3T Washer
My washing machine gets a sud error often during the cycle. I have cleaned the drain as suggested
Vinegar does a great job of cutting suds and bubbles. I would put it in the detergent, softener, and bleach reservoirs and run a cycle. Then make sure you read the detergent amounts. It's easy to overdo detergent on a front-loader.
Aug 17, 2013 | Kenmore HE3t Steam 4.0 cu. ft. Front-Load...
Clothes have lint on them when the washing cycle is finished is there a lint area i need to clean
The newer Whirlpool top-loaders have lint screens on the inner tub and not accessible. These are supposed to self-clean during the drain cycle. I've heard that liquid fabric softener and detergent build-up may clog the screens when lint sticks to the gooey screens. Try something that will cut the goo like vinegar or ammonia in a small load level without clothes. Without clothes in the washer, that is.
Older Whirlpool washers have lint filters located above the tub, on the lid opening.
Good luck from Detroit, MI.
Jul 18, 2011 | Whirlpool 3.2 cu. ft. Plus Washer
Fowl odor in front loader
Clean out the small holes in the gray door gasket (at the bottom) to allow water to drain back into tub. Open access door at bottom left on front of machine, use small hose to drain remaining water from machine, remove and clean out filter there. Re-install. Run washer on the tub clean cycle if you have that cycle, or if not, use the longest, hottest cycle you can, but make sure to use a commercial washer cleaner like Affresh, Washer Magic, Whirlaway hot tub cleaner, etc., with no clothes in the washer. After cleaning tub, make sure you only use one tablespoon of HE detergent per cycle, and only one teaspoon of fabric softener per cycle if you use softener.
Feb 13, 2011 | LG WM-2277HW Front Load Washer
Washing machine will not draw fabric conditioner
The Solution: Top up the softener tray with extra water so that it is up to the 'max level' mark.
The softener tray works by a siphon action. Thus, the reason the tray does not empty is that not enough water is added by the machine during the softening cycle, so that the machine does not completely fill the softening tray; only when the softening tray is filled beyond the 'max' mark does the siphon action works. A partially filled tray will never empty - it's impossible due to the siphon.
The reason that not enough water is added to the tray during the softening action is that the water inlet of the machine is partial blocked (you can try to fix that) but it is simpler to just added more water to the conditioner tray.
Thus, the easiest way to ensure that the softener tray empties every time (after adding the softener to the softener tray of course) is to top up the softener tray with extra water, top it up to the 'max level' line (keep a bottle of water by the machine). That way, even if only a little water is added to the softener tray during the softening cycle by the machine it is enough to trigger the siphon action and the tray will empty!
Works for me every time, and no need to remove any parts - I used to take the tray out, clean it, scrub the outlet holes that fill the tray etc, but they used to gum up again quite quickly!
Hope that helps
Aug 23, 2009 | Bosch Washing Machines
Bosch Classixx 1000: Won't drain
Hope that helps
May 26, 2008 | Bosch Classixx WFL 2066 Front Load Washer
LG front loader not draining properly
My LG front loader is stopping during the drain cycle (making a humming sound as if it is trying to drain, but can't....What can I do?
Nov 02, 2007 | Kenmore 44102 Front Load Washer
Fabric softner
Remove the dispenser tray. Inspect the area just above the fabric softener portion of the dispenser. There should be a series of holes where water feeds into the tray during the rinse cycle. Sometimes these holes become clogged with fabric softener residue. If the holes are clogged, water will never dispense the fabric softener out and it will stay in the tray. If you take some cotton swabs and meticulously clean all the holes out, I bet your problem will go away. Let me know if this was helpful to you.
Oct 05, 2007 | Frigidaire GLTF2940ES Front Load Washer
Open Questions:
Kenmore Elite HE4T Washing Machine Diagnostic Test Didn't complete and clothes aren't spun as dry as in the past I have a Kenmore Elite HE4T washing machine and I noticed that recently it isn't getting all of the clothes completely dry from the final spin cycle. Thus, the dryer has to run through two cycles to get the clothes dry. I did a bunch of research and made sure there weren't any kinks or blockages in the drain lines; and opened up the bottom of the washer and cleaned out the drain cleanout. I found a few pennies, but everything seemed to be working ok. I ran a load and had the bottom open so that I could make sure the motor, drain and belt were all working properly. The drain does get the water out of the washer, so the clothes aren't sitting in water, they just don't seem to be spun as fast or as long as they used to. I always put it on the "extra high" spin setting no matter which type of load I run. So, I found a way to run the diagnostic test on the washer and it went through C0-C5 (the agitation step) and all worked great, until it wouldn't come out of C5 after at least 10 minutes and go thru C6-C8. I had to cancel the diagnostic test and hit the "drain and spin" button to get all of the water back out of the washer. BTW, the "drain and spin" seems to get the clothes a bit drier than when I have it run through the "normal" cycle with the "extra high" spin. If anyone has any other thoughts, I would really appreciate it. This unit is in a small space with the dryer attached so to take it out and do repairs is a pretty big hassle. It has had a new control board and two new fill valves in the 10+ years that I have owned it. Questions I have: 1.should I remove the entire drain pump to make sure there isn't anything lodged in it? 2. could it be the belt slipping slightly and keeping the spin from reaching its 1200 RPMs? 3. Anything else I may be missing???
Jan 17, 2017 | Kenmore Washing Machines
Washing Machines Logo
266 people viewed this question
Top Washing Machines Experts
Richard Roth
Richard Roth
