Question about Bushnell Banner Dusk & Dawn 3.5-10x36 AO BDC .17 and .22 Riflescope (cat713510) Telescope
Elevation cap The elevation cap on my Bushnell Banner is broken. I would like to find a parts list.
  • 112 Answers
Need vertical cap for bushnell scopechief vi bdl 4x12x40?
I have a Bushnell Scopechief VI 4x12x40 bdc that was missing the vertical elevation dials. I called bushnell and spoke to a woman in the parts department who was able to help me out. She did a quick search of her inventory and stated, "that they had HUNDREDS in stock"! I quickly ordered 2 of each dial ($4.50 each) and 2 of there turret screws ($2.50). Shipping was $4.80. Definitely give them a call and good luck!
Feb 25, 2015 | Bushnell Optics
My Bushnell Banner rifle scope 3x9x40 ia at max elevation and shoots low The scope is used on a marlin 1894c underlever rifle and attached to a weaver rail how can i fix this problem
you might be able to buy a weaver rail adapter that can change your elevation aswell as lift up your scope a bit just to make it a bit easier to see out of. try something like this maybe http://ant-supplies.co.uk/DovetailtoWeaverAdapters.aspx
Feb 27, 2011 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
I HAVE LOST ONE OF THE CAPS OFF THE ELEVATION AJUSTMENT
for this you will need to send the unit into their repair at 8500 marshall drive lenexa ks 66214 4-6 week turnaround and put your name address and telephone number inside the package. if there is a cost they will send an estimate.
Oct 31, 2009 | Bushnell Banner 6-24x40 Mill Dot Reticle...
I aser bore sight my Bushnell banner. I need to
if it is verry tight back it off a little bit you dont want to break the seal.i have never been a big fan of the laser bore sighters.i have had a cpl and both were inaccurate.BSA makes a good bore sighter for 49 bucks.try a cpl shots with it and find out how far you are truely off.remember 1 click is 1/4 inch.in 100 yrds.in the army we had all the ammo we needed to sight our rifles in.but here in the real world with ammo prices so high a good bore sighter is the way to go.
Oct 19, 2009 | Bushnell Velocity Speed Gun
Elevation cap srew broke, Bushnell Banner, 20 yrs old 3x9x38
Take it to a well stocked hardware store and see if they have a screw that will work.
Aug 25, 2009 | Bushnell Banner Dusk & Dawn 3.5-10x36 AO...
Scope elevation adjusted allthe way up & still shoots low
Bushnell sells nylon inserts for scope rings that fit inside of the scope rings and will affect the height of the ring to correct the problem. If you install them on the front scope ring, it will correct it and realign the rings correctly. It appears that the front ring towards the muzzle is not as high as the rear ring near the breach. This is why that even though the scope's adjustment is elevated as high as it will go, it is still hitting low because it is actually pointing down because apparently the rear ring is higher off the barrel than the front ring. The Bushnell inserts can correct this.
Aug 23, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Bushnell banner elevation maxed out
It sounds as if your Scope rings are out of alignment or the front ring is lower than the rear ring. You may be able raise the bottom of the front ring by inserting a shim under the front ring base.
Aug 08, 2009 | Optics
Cannot sight in riflescope for elevation, adjustment is maxed out
Try reversing the rings. Move the back one to the front, and the front one to the back. Turn your elevation adjustment, back to -0-, and start again.
Feb 01, 2009 | Bushnell BANNER RIFLE SCOPEPower: 3-9X40 /...
Scope out of elevation adjustment
If you are sure that the scope was mounted correctly to begin with, ie plenty of elevation left THEN you can install a slanted rail that will increase you elevation potential. Of course, that comes at the cost of having less elevation at the lower end.
A second solution is rings, like those by Burris with the plastic inserts. They have an accessory insert kit for these Signature Zee rings that will let you increase your elevation. Rings are ca 30 and the kit'll be ca 10, so 40 total.
If you're just missing a wee bit of elevation you could just lightly shim the scope in your current rings.
Nov 16, 2008 | Bushnell Banner Dusk & Dawn 6-18x50...
Bushnell Banner Dusk & Dawn 3.5-10x36 AO BDC .17 and .22 Riflescope (cat713510) Telescope Logo
245 people viewed this question
Top Bushnell Optics Experts
Marvin
Marvin
George Merkley
George Merkley
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
