Question about RCA HD52W59 HDTV Projection Television
NO POWER rca hdtv R52WH74YX61
I read in post about a blow fuse and would like to check it before I call for a tec,Can you tell me were to locate it
Thanks
    Sergeant:
    Champion:
  • 346 Answers
Check fl231 around the flyback area
Posted on Nov 23, 2008
RCA R52WH74YX61
Send your email address to me, and get a copy of the user manual to your device, by return mail.
Jul 24, 2012 | Televison & Video
Rca hd52w59 hd tv blown .5 fuse, keeps blowing, screen looks like 3d when this happens
If your fuse keeps blowing you have a shorted parts, if you have a multimeter and know how to use it you can check parts around power supply like diodes, IC's, regulator, and also check the horizontal output or you can call your nearest tech around your area to help you out. if you need more information about tv troubleshooting tips, try this site.
www.my.electronicshelponline.com
hope this help.
Apr 11, 2010 | RCA HD52W59 HDTV Projection Television
Rca hd56w66 no power not even the green light power board looks good suggestions to find the problem?
Check the fuse. Its located on the right side looking in the rear of the TV its the small board where the power cord plugs into. The fuse is on that board.
Jan 01, 2010 | RCA HD56W66 56" HDTV
if the fuse you took out at first was fried black as cool, how do you know it was .6a
now the fl231 as I told you before is close to the flyback transformer
Go to google search -type in flyback transformer --enter
scroll down to get video results for flyback
click on the picture
now you will see what a flyback looks like
you should not try to fix tv if you have no idea of tv repair.it is very cmplicated and fatal .there is serious high voltage in tv sets
Nov 23, 2008 | Televison & Video
RCA HDTV R52WH74YX61 blown fuse
there are 3 small red rectangular shape objects to the right of the flyback transformer these are fuses the fl231 most time goes bad .fl231 is the location number under the green circuit board. the location number can also be wriitten on top(brown side of the cicuit board)
you may have to put back the .6a you took out was it ok?
TRITRONIC ELECTRONICS sell parts . cathray 416 241 1106 sells also
Nov 22, 2008 | Televison & Video
Fl231 fuse compatibility
yes, thats the replacement fuse for your set. However unless you have replaced the convergence power supply also chances are the fuse will blow again, as the power supply shorting is what causes the convergence to get out of alignment and it will then blow FL231 thereby removing the convergence option from the menu.
Sep 02, 2008 | RCA HD52W59 HDTV Projection Television
RCA D52W20; no power
If its the regular glass fuse, radio shack should have a replacement for that just bring the old fuse with you so you can get the correct amp fuse. If it blows again, let me know and I will try to assist you as usually fuses blow for a raeson. Please respond to this same post when replying.
Aug 01, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W20 52 Fuse problem
Well you could always use a bigger fuse but I would not advise to do it, it could and most likely will blow tv not fuse. Fuses ussually blow from a short or power surge. If it is new or under warranty I would return it for replacement or repair.
Jul 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA HDTV Fuse location
There are 3 small rectangles that are on the right side of the flyback, they are micro fuses FL231 is the center one. I am not sure if radio shack has them, may have to order from RCA
Jun 30, 2008 | RCA R52WM24 52" HDTV Projection Television
Convergence power supply fuse
the fusable link... can be check with continutiy.. or a ohm meter......u need a meter that can do this when you put a meter across it it will read o ohms if good and infinate if bad some meter beep when it has near zero ohms meaning good... if you have any question. i can be reached at willie AT fordtv.com.... from your desciption it does sound like the fuse... However when you replace the fuse you have to make other repairs or it will fail again...falty solder connections is what cause this
May 03, 2008 | RCA HD52W59 HDTV Projection Television
RCA HD52W59 HDTV Projection Television Logo
171 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
