The sound is real low an the picture just flick
Resetting to Factory Settings
To reset to the default factory settings, follow these steps.
1. Press the MENU button on the remote control to
open the OSD.
2. Press the Navigation (UP/DOWN) buttons to
select the Options menu.
3. Press OK to open the menu.
4. Press the Navigation (UP/DOWN) buttons to
select Factory Preset.
5. Press OK.
6. Press EXIT to close the OSD
the user manual here:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/I-LC23Q1_Manual.pdf
or phone customer service please call
regards
Check all connections on the tv. check for any loose wire connections on the the tv input.
the unit must be check and service, some part have to be tested for any problem causing it.
You can try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Good luck..
the sound is very low picture flick have dirtv
did not work
that did not work
I LIVE IN NEW ORLEANS LA. IS THERE A REPAIR SERVICE YOU CAN GIVE ME?
thank,s but you have not helped
