Question about Uniden BCT8 Base Scanner
Please Provide Basic Instructions For Programming My Scanner
Hello. I appreciate any help that is offered to me. I recently my scanner as a gift. I am having great difficulty understanding how to use it. I think I programmed the trunked frequencies because when I chose srch the ids flashed on the screen. The next confusion is creating IDS. The manual describes everything in a complicated way. I was wondering if anyone could send basic instructions from all the steps. Thank you very much for your help. Alisa
  • Anonymous Dec 15, 2007
    same problem need to reprogram
  • candy123 Feb 06, 2008
    I can't figure out how to program in the freqencies, it keeps coming up error.
How to program bct8 scanner
Posted on Apr 02, 2009
  • opnearing Apr 02, 2009
    show how to program
  • 120 Answers
Go to www.radioreference.com and find the forum for that brand scanner and you will find many people who will help you, then sit back and enjoy listening
Posted on Jan 02, 2009
How do I program my bearcat 144xl scanner?
The BC144XL is one of the few scanners that I haven't been able to locate a manual for, but programming it is fairly straight forward. Here's some guidance from Uniden:
Here are basic instructions for programming nearly all of the older scanners that Uniden produced. When the scanner is turned on press the MANUAL key, then press the channel number that you want to program first, then the MANUAL key again. This will stop the scanner from scanning and hold it on the channel that you want to program.
Then you enter the frequency (be sure to use the decimal point in the right area when entering in the frequency) and then press the E or ENTER button to save the frequency on the channel. You are now finished programming the channel. To advance to the next channel simply press the MANUAL key and enter your next frequency the same way that you entered it on the previous channel (as described at the beginning of this paragraph).
I hope this helps.
Jan 01, 2010 | Uniden BC248CLT Base Scanner
How do i reset frequencies on a scanner /delete frequencies
You listed your question in the PRO-2096 section, so this response applies to that model. If you have a different scanner, please let us know the make and model.
The PRO-2096 is an advanced scanner capable of monitoring both single frequency conventional systems and advanced trunking radio systems. Programming methods are detailed and lengthy and cannot be reproduced here. For specific programming instructions, please see the scanner's operating manual, which can be downloaded/printed here:
http://pdf.textfiles.com/manuals/SCANNERS-F-R/Radio%20Shack_PRO-2069%20Wideband%20Scanner-Reciever_Manual.pdf
If you have questions regarding a specific feature or problem with the scanner, please let us know.
Dec 20, 2009 | Radio Shack Pro-2096 Base Scanner
I need a manual with programming instructions for a Uniden BC278C
You can download/print your scanner manual here:
http://www.uniden.com/pdf/BC278CLTom.pdf
For a comprehensive database of active frequencies in your area, visit
www.RadioReference.com
If you have any other scanner problems or questions, please let us know.
Dec 12, 2009 | Uniden Radio Communications
I need a manual with programming instructions for a scanner
Please contact us again if you have any more scanning questions.
I need to know how to program this scanner. Radio shack pro-2055
The programming instructions are too detailed and lengthy to post here, so here's a link to the manual for your scanner. It will walk you through the programming process.
For an extensive database of active frequencies and systems in your area visit
or
www.CityFreq.com
If this response helps, please take a moment to post a rating. "Very Helpful" would be appreciated.
Dec 04, 2009 | Radio Shack Pro-2055 Base Scanner
How do i program a uniden bc144xl scanner
I couldn't locate a manual for this one, but here's some programming guidance from Uniden:
I hope this helps.
Oct 15, 2009 | Uniden BC248CLT Base Scanner
Need manual for uniden scanner bc155xl
I couldn't find a manual for this oldie, but here's programming guidance from Uniden:
I hope this helps.
Sep 15, 2009 | Uniden BCD996T Base Scanner
I am having trouble programming in Frequencies
Hello there:
if you can go to www.uniden.com and search for your model number there is a programing section in there along with a downloadable users manual that will be able to help you out also if you know how to enter basic frequencies just go to www.scannerlive.com this will give you hundreds of scanner frequencies. ok
hope this helps you out please dont forget to give me a rating.
best regards mike
(usn retired)
Aug 04, 2009 | Uniden BC244CLT Base Scanner
Visioneer One Touch 8700 USB Scanner lock mechanism problems
Not sure if your problem is the same as mine, but I encountered the same error and only to find that I plugged in a wrong power adapter so it didn't have enough power to advance the scanner head (My moving caused this mixup). Check your power adapter OUTPUT is 12V (or whatever is specified on the scanner itself, usually found on the label on the bottom or rear).
Jul 25, 2008 | Visioneer One Touch 7600 USB
Unable to unlock scanner
sounds like it has lost its programming,
try reprogramming a frequency.
UPSO 506
Dec 28, 2007 | Uniden BC60XLT-1 Handheld Scanner
Uniden BCT8 Base Scanner Logo
317 people viewed this question
Top Uniden Radio Communications Experts
eradiostore
eradiostore
Marvin
Marvin
Van Allen II
Van Allen II
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
