Question about Canon IMAGERUNNER 9070 Copier
On Canon Imagerunner 9070 have Error E000584-001
Need to clear this error, tried several times to restart with no luck same erro keeps coming back.
  • 168 Answers
Is there something in the way ot your finisher trays
Posted on Dec 07, 2008
I replace my machine for fuser flim unfortunately the screen shows 'E000000' How do I correct this error code?
  1. Try first to clear the error
    clearing the error may not fix the fault
    Press the *with a circle around it then press 2 and 8 at the same time then press *again /press copier touch button/function/clear/error/ok button then switch off m/c on hope it works
    also:
    Additional Functions: Click the Additional Functions button once. Do not hold down.
  2. Two and Eight Buttons: Click the 2 and 8 buttons at the same time once.
  3. Additional Functions Revisited: Click the Additional Functions button once again. Do not hold down.
  4. Copier Button: The System Management screen will open. Click the Copier button on the screen.
  5. Function Button: Click the Function button at the top of the screen.
  6. Clear Button: Click the Clear button on the screen.
  7. ERR Button: Click the ERR button to highlight it.
  8. OK Button: Click the OK button at the bottom of the screen.
  9. Power Off/Power On: Power the unit off and back on using the switch on the side of the unit. The error will be cleared.
  10. Restart eCopy:Once the unit is back up, restart the eCopy machine.
    https://www.question-defense.com/2008/11/10/canon-imagerunner-error-code-reset
Apr 14, 2016 | Canon imageRUNNER 2520 Laser Multifunction...
Erro code e000086-0000
CANON IR 105 ERROR CODE E000086-0000
May 26, 2014 | Canon Imagerunner Ir 105 Copier Printer...
E000003 0002 error
Check fixing thermister or heater then clear first 3 errors through *28*
Nov 18, 2013 | Canon imageRUNNER iR C2880 Color Copier
Error code e000002-0000
This is a standard Canon error code for the fixing assembly not getting hot. You will have to reset the error by clearing the error from the copier's memory. You have to press additional function key, then press 2 & 8 at the same time, then additioanl function key again. The display should change to the service mode with COPIER and other accessories being seen. Press COPIER then Function, then CLEAR, then ERR, then OK. Press reset a couple of times then power down the copier, then back on. If the error comes back then the fixing film assembly will have to be changed to make a more permanent fix. Good Luck.
Sep 18, 2012 | Canon imageRUNNER 2200
How to reset error code E00000-0010
This is the standard proceedure for the Canon ImageRunner Copiers and all that I'm sure will follow: Press the " Additional Function " key, then press " 2 & 8" at the same time, then the " Addtional Function " key again. You should now see the service mode screen. Press " COPIER ", then " FUNCTION, " then " CLEAR, " then " ERR ", then " OK. " This will clear the code out of the copier's memory. Please be careful in service mode becuase you can do very distructive things in this mode that may take a Canon qualified technician a long time to resolve. Power down the copier at the main power switch, wait a few seconds then turn the copier back on. If the error comes back then you have a fixing assembly problem that will have to be resolved before being able to use the copier. Good Luck.
Sep 13, 2012 | Canon imageRUNNER 5570 Copier
E000065-0000 error what is the problem
e65 is related the primary charger there is a leakage therefore check if it is in a pool of toner clean it nicely. e000 is related to the fixing assembly the thermistor problem causes the temperature not to increase to the trequired within the specified time frame, therefore check the thermistor and the lamp. Or ask a qualified technichain to clear the code for you.
Aug 01, 2011 | Canon IMAGERUNNER 9070 Copier
Sir i have a canon imagerunner 6570 model machine .it was coming an error code .that was e00004-103 . how to clear the error? pls give me a solution as early aspossible thank u srinivas
goto the service mode by pressing (additional function 28 additional function) .in there got to function then to clear and then clear the error by pressing ok and restart the machine
May 22, 2011 | Canon IMAGERUNNER 6570 Copier
E00020
Canon ir 9070 error 69
Dec 24, 2010 | Canon imageRUNNER 8500 Copier
Error msg E000001-0000 What can we do
that is a thermistor error code. there are several causes for this. the thermistors are dirty, the upper fixing roller is damaged or it might have paper wrapped around it, or the connecter on the back of the fixing frame has a hair line crack in it. now you can clear this code if you you think there isn't anything wrong with the afore mentioned items.
you have to get into service mode. first you will have to shut the copier off at the main power switch and turn it back on once the error code pops up on the screen you will need to get into service mode.
you hit the
additional funtions button
then the 2+8 at the same time
then additional funtions button again
once in service mode you will need to follow the following steps
hit the copier tab
then the funtions tab middle of screen across the top
then hit the clear tab
then the err tab and hit the ok button to clear error
now you only have like 30 seconds give or take to get into service mode and to clear the error code before the machine shuts down if you don't get in fast enough dont worry shut the copier off and turn it back on and keep trying till you get in and clear it. trust me it took me several tries my first time i realized this myself.
Aug 16, 2010 | Canon imageRUNNER 5000 Copier
Canon imageRUNNER 7095 copier has the error code E00057a-8003 ..... can you tell me what this means? can we fix it on our end? Let me know as soon as possible because our copier has been down for 3 days....
This Problem occured with a finisher V1/V1L attached to our Canon iR7095.
The staple unit didn'tmove back to it's initial position. After restarting the printer there was a really strange clattering sound coming from the staple unit.
Problem was solved by removing all trapped pages from finisher and copier. Probably you have to restart several times. The system should reset and move the staple unit back to initial position.
Aug 12, 2008 | Office Equipment & Supplies
236 people viewed this question
old marine
old marine
