Question about GE JVM1650 1000 Watts Microwave Oven
Exhaust fan A friend of ours gave us an above the range microwave and I was wondering do I have to vent this model or does the front vents do the job? KENMORE MICROWAVE MODEL-665.61622100 SEARS and ROEBACK 60179 any info would be great, Thanks you, Mary
  • GE Master
  • 9,098 Answers
You can download the owner's manual and installation guide free here.
This is a Sears partner Web site. While it's all free, they will ask you to register so they can keep you updated if needed.
Posted on Nov 23, 2008
GE Spacemaker JVM1640SJ Exhaust Fan Whines & Doesn't Do a Good Job
The vent fan assembly's blade assembly may be freewheeling on the motor shaft (which can be fixed with a couple of drops of super glue or epoxy) or there may be a foreign object or critter in the fan blades.
You will have to remove the oven from the wall to inspect and remove and inspect the vent motor. You can download the installation instructions here.
At my Web site, you can get details, plus I have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can order any needed GE parts from the Pros here, my favorite affiliated supplier.
For more free DIY and other help & advice, feel free to contact me via my site.
Please include FULL model number*, FCC ID number*, + detailed symptom information. ( * on the tag in cooking cavity or around door frame or control frame or on back)
William E. Miller, AS-EET
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 04, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Frigidaire gallery otr microwave vent not working
Hello Lori Wilson - Thanks for your post! Generally speaking, the vent is not very strong. Try to place a single paper towel on the underside of the microwave. With the vent on, it should suction the paper towel to the bottom of the microwave. If not, I personally recommend contacting the installer to verify that the vent fan is installed properly and the exhaust outer is correct.
Apr 04, 2013 | Frigidaire 1.6 Cu. Ft. Over-the-Range...
The fans on this microwave will automatically turn on when I have more than one burner on the gas range going. The fan is horrendously loud and will not allow me to shut off for 2-3 minutes regardless if I...
That's typically normal operation. The microwave has a thermostat which turns on the hood vent exhaust fan at a certain temperature to protect the controller.
Your owner's manual will cover vent fan operation.
If for some reason you don't have yours, you can download Whirlpool owner's manuals and installation instructions here.
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
If - above and beyond this - the fan has a problem, that could make it excessively loud. Some are just loud though, it's hard to judge without actually hearing it.
You can contact Whirlpool customer service with your model number via that link above and ask them about the loudness. They may be able to tell by listening over the phone if it's abnormally loud.
Apr 28, 2011 | Whirlpool MH7130XE Microwave Oven
Water comes out and drips all over my range
CHECK THE EXTRACTION VENTS FOR OBSTRUCTION IN THE CAVITY AND EXTERNALY
Feb 12, 2010 | Maytag Appliances Over-the-Range Microwave...
Exhaust fan doesn't work and blows air from top vent
Some microwaves have a adjustable fan. We have one that you can vent out the back, the back top or through the front top filters. The latter is what it sounds like you have. If you take the small back panel off and lift out the fan motor you'll see that you can place it in the direction you like.\\
KK
Jul 04, 2009 | Kenmore 60654 Microwave Oven
Vent fan high comes on automatically with cooking
Right, that would be MCO10UW and the owner's manual is here.
The owner's manual does say this, of course,
"To prevent overheating from taking place, the exhaust
fan is designed to automatically turn on at a low speed if
excessive temperatures occur. Should this happen, the
fan cannot be manually turned off, but it will
automatically turn off when the internal parts have
cooled. The fan may stay on for up to an hour after the
range and microwave oven controls have been turned
off."
That;'s standard on microwaves.
But these models do have a separate internal cooling fan (which should run any time you microwave) plus the hood vent exhaust fan, which should only run when you select it, or if there is an excessive stovetop or under-hood temperature.
So if it comes on whenever you microwave, that is incorrect.
When that happens, it's usually a defective vent thermal switch (a.k.a. hood TCO).
But since it's brand new, I would certainly contact Magic Chef about this. If it's in need of repair, they will fix it free, assuming the oven wasn't physically damaged.
For more help from Magic Chef / Ewave see here or their contact page.
For Magic Chef in Canada call 866.587.2002
Jan 08, 2009 | Magic Chef CMV1000B Microwave Oven
Exhaust fan
You can download the owner's manual and installation instructions here.
We're happy to help and we appreciate your thoughtful rating of our answer.
Mar 08, 2008 | Maytag MMV5000 Microwave Oven
Microwave problem
Is it possible that grease or moisture got into the controls? This can happen when cleaners are sprayed directly on the keypad; when boiling is done on the stovetop without the hood vent fan being on; when the hood vent filter is clogged; or due to restricted airflow in exhaust. The best way to check the airflow is to turn the hood vent fan on and use your hand to feel at the exhaust outlet outside the home. Moisture can cause the keypad or control board to short to some degreee, and produce odd results. It may clear up, but sometimes it requires that the keypad be replaced or that the board be professionaly cleaned. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk We also repair microwave control boards for customers nationwide for $39.95. Feel free to contact me there directly if you have further questions.
Jun 16, 2007 | Samsung SMH7174BC Microwave Oven
GE JVM1650 1000 Watts Microwave Oven Logo
142 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
